Looking for a 10K linear slide potentiometer
Results 1 to 9 of 9
    Default Re: Looking for a 10K linear slide potentiometer
    Well, I am sure that original pots from Mouser will be much more close to the specs than what are Ali stores sell. That justifies the price also.
    I had similar issues with rotary pots for amplifiers that were not tracking well (stereo pots for volume).
    Why not 3D print your own caps? These parts are becoming more difficult to find.
    Well, I am sure that original pots from Mouser will be much more close to the specs than what are Ali stores sell. That justifies the price also....
    I have no doubt the Mouser/Digikey/Newark parts are top quality, but in the end, I have a limited budget. I just don't need the built-in LED on the PTL Series. It's super cool, but I don't need it. I sent all 3 an email asking them for an ordinary 100mm B10K slide pot.
    I was also looking at the PTB Series, but it doesn't have any taper graph. It just says linear, audio in the specs at top left. And that's exactly how I got nailed with the taper B Behringers. I'm not falling for that again.
    https://www.bourns.com/docs/Product-Datasheets/PTb.pdf
    I also sent an email to Bourns, asking them for a taper chart for the PTB Series. I have no idea if/when they'll respond.
    I bet you had one of those taper B with a slight curve like B3, B4 and B5. Check the chart on page 4:
    https://www.bourns.com/docs/Product-Datasheets/PTL.pdf
    ...Why not 3D print your own caps? These parts are becoming more difficult to find.
    Generally, PLA plastic is not as solid as the plastic on commercial caps, and it degrades quicker under UV rays (lamps, sun, etc). I've seen reports PLA can start degrading in 1 month, to 12 to 18 years; all depending on environment. I can't take that sort of chance.
    I still have to study what other plastics I can use. ABS is extremely solid, but it's a bit more finicky to use, and requires adequate ventilation. I still haven't looked at the other plastics yet.
    If I can find a slide pot with a 4mm shaft, then I'm ok. I've seen a few 6mm caps on sale. But yeah, at worse I'll fabricate my own.
    I'm already fabricating my case, and most likely will be using ABS. So it seems like I'm not going to have much choice. It's not like I can put a warning DO NOT PUT IN DIRECT SUNLIGHT, OR UNDER UV LAMPS OR ANYTHING THAT CAN DEGRADE PLA PREMATURELY.
    I suppose, if the product is not very well made, manufacturers might hide some of the specs!
    For a pot most will think it is not too much important to know such details...
    Putting a label like that "DO NOT PUT IN DIRECT SUNLIGHT, OR UNDER UV LAMPS OR ANYTHING THAT CAN DEGRADE PLA PREMATURELY" I am pretty sure would go viral!
    ...Putting a label like that "DO NOT PUT IN DIRECT SUNLIGHT, OR UNDER UV LAMPS OR ANYTHING THAT CAN DEGRADE PLA PREMATURELY"
    I am pretty sure would go viral!...
    I'm not sure I'd like to go viral for that reason.
    Well, I found even better than buying from AliExpress. A manufacturer just offered me a deal at my exact specs 17.5 times less expensive than North American prices.
    :O
    She reduced her MOQ because I already bought SR25 rotary switches from them.
    I really hope that these pots are in fact true linear B1 curve ones.
    Nice offer!
    I hope so. She gave me a chart and it's pretty much in line with what Bourns offers for straight B taper.
    If you look at their PTL and PTA datasheets, Bourns has a taper chart, but nothing in the PTB datasheet. It took Bourns something like 2 weeks to send me that chart.
    Name:  PTB Series Taper.png
    By the way, I was in talks with one manufacturer that identified their slide pots by PTB. I didn't go with that one; their price was just a bit higher than "the chosen one".
  1. Linear acceleration ramp
    By pxidr84 in forum mel PIC BASIC Pro
    Last Post: - 15th May 2012, 07:27
  2. How to realize storing Data 10k-20kb
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 7th August 2007, 16:34
  3. Implementing a linear function...
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 25th July 2007, 15:54
  4. Linear to S Curve conversion
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2007, 15:15
  5. Rx433 linear and digital output
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 29th October 2006, 22:26
