Looking for a 10K linear slide potentiometer
Results 1 to 9 of 9
    Default Re: Looking for a 10K linear slide potentiometer
    I suppose, if the product is not very well made, manufacturers might hide some of the specs!
    For a pot most will think it is not too much important to know such details...
    Putting a label like that "DO NOT PUT IN DIRECT SUNLIGHT, OR UNDER UV LAMPS OR ANYTHING THAT CAN DEGRADE PLA PREMATURELY" I am pretty sure would go viral!
    ...Putting a label like that "DO NOT PUT IN DIRECT SUNLIGHT, OR UNDER UV LAMPS OR ANYTHING THAT CAN DEGRADE PLA PREMATURELY"
    I am pretty sure would go viral!...
    I'm not sure I'd like to go viral for that reason.
    Well, I found even better than buying from AliExpress. A manufacturer just offered me a deal at my exact specs 17.5 times less expensive than North American prices.
    :O
    She reduced her MOQ because I already bought SR25 rotary switches from them.
    I really hope that these pots are in fact true linear B1 curve ones.
    Nice offer!
    I hope so. She gave me a chart and it's pretty much in line with what Bourns offers for straight B taper.
    If you look at their PTL and PTA datasheets, Bourns has a taper chart, but nothing in the PTB datasheet. It took Bourns something like 2 weeks to send me that chart.
    Name:  PTB Series Taper.png
    By the way, I was in talks with one manufacturer that identified their slide pots by PTB. I didn't go with that one; their price was just a bit higher than "the chosen one".
    Big companies, big delays!
    Hope that the chinese one works as it should be. Wish you luck.
  1. Linear acceleration ramp
    By pxidr84 in forum mel PIC BASIC Pro
    Last Post: - 15th May 2012, 07:27
  2. How to realize storing Data 10k-20kb
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 7th August 2007, 16:34
  3. Implementing a linear function...
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 25th July 2007, 15:54
  4. Linear to S Curve conversion
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2007, 15:15
  5. Rx433 linear and digital output
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 29th October 2006, 22:26
