help with 4 x 20 LCD
Results 1 to 15 of 15
    OK
    Default Re: help with 4 x 20 LCD
    Each line has its own address in the HD44780.
    Line 1 = $80
    Line 2 = $C0
    Line 3 = $90
    Line 4 = $D0
    You would need RS = 0 to send a command and send your line address, then RS = 1 and send the string.
    Line 1 = $80
    Line 2 = $C0
    Line 3 = $90
    Line 4 = $D0
    I'm sorry. I'm not following. I think I understand how to move the cursor around. But what is RS? The register select bit? I'm not getting it to display anything even on lines 1 and 2. What would you do differently here to get it to display "hello" on line 1 and then "world" on line 2?
    Lcdout $fe, 1   ' Clear screen
         Pause 500       ' Wait .5 second
         Lcdout "Hello"  ' Display "Hello"
         Lcdout $fe, $c0, "World" ' Move to line 2  and display "World"
    Oct 2009
    Quote Originally Posted by keithv View Post
    You forgot to designate the line one position
    LCDOUT  $FE,1
    lcdout  $FE,$80,"Hello"
    lcdout  $FE,$C0,"World"
    LCDOUT $FE,1
    the $FE,$80 is tolally unnecessary , the $FE,1 not only clears the screen it homes the cursor to
    line 1 pos 0 too
    LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250 ' Initialize LCD
    is a waste of code space and indicates that the power on lcd wait may be too short
    Pause xxx ' Wait for LCD to start up
    LCDOUT $FE,1
    is adequate , I have had displays that need the pause xxx to be as long as 500mS
    its also possible that the default config settings in your pic16f887.inc file don't match your setup
    can you blink a led at defined rate correctly ?
    I added the address for good measure. No luck. I increased the start up wait time. No luck still. I added a blinking LED and that works - on for half a second, off for 1 second. Stuff highlighted in RED is what was added/changed.
    TRISB = %00000000
    mainloop:
         Lcdout $fe, $80, "Hello"                                ' Display "Hello"
         PORTB.7 = 1                                      'LED on
         PORTB.7 = 0                                      'LED off
    Goto mainloop                                    ' Do it forever
    wiring ?
    contrast setting ?
    unused data pins on lcd are grounded not left floating ?
    Oct 2009
    The following code works for me with a 4 x 20 LCD
    ;----[LCD ]---------------------------------------------------------------------
    DEFINE LCD_DREG  PORTB           ' LCD Data port
    DEFINE LCD_DBIT  0               ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB           ' LCD Enable port
    DEFINE LCD_EBIT  5               '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB           ' LCD Register Select port
    DEFINE LCD_RSBIT 4               '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4               ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4               ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000        ' Command delay time in us
    DEFINE LCD_DATAUS 50             ' Data delay time in us
    Obviously change the port/pin assignments to match your hardware
    To inform the LCD which line to start displaying text on use;
    $fe,$80,
    $fe,$C0,
    $fe,$94,
    $fe,$d4,
  1. Using a parallel LCD(44780 based) as a serial LCD
    By mikejp56 in forum mel PIC BASIC Pro
    Last Post: - 30th October 2015, 01:56
  2. Replies: 36
    Last Post: - 14th March 2011, 18:38
  3. Replies: 2
    Last Post: - 5th November 2009, 17:07
  4. LCD and PIC18F2685 - Weird LCD behavior
    By Castor in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 09:55
  5. to convert LCD // hd 44780 --> serial LCD
    By in forum mel PIC BASIC Pro
    Last Post: - 15th March 2003, 12:37
