Getting a 18F2525 to wake up from sleep with change of input
Results 1 to 3 of 3
    Mar 2004
    UK-Midlands
    Default Getting a 18F2525 to wake up from sleep with change of input
    Hi All,
    Been working on this all day and I must be doing something silly!
    I want to wake up the 18F2525 from sleep by a change in port B.
    Any help appreciated as I am quickly tearing my hair out.
    Bob
    DEFINE OSC 20
    INCLUDE "MODEDEFS.BAS"
    #config
    __CONFIG _CONFIG1H, _OSC_HS_1H
    __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOREN_OFF_2L & _BORV_2_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_16384_2H
    __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    __CONFIG _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L & _CP2_ON_5L
    __CONFIG _CONFIG5H, _CPB_ON_5H
    #endconfig
    T2 var byte
    LedG VAR PORTA.1 ' Green LED
    LedR VAR PORTA.2 ' Red LED
    BUZ VAR PORTA.3 ' Buzzer OP
    KeyLine VAR PORTA.5 ' keyline
    BPear1 var PORTB.4 ' Push 1 IP
    BPear2 var PORTB.5 ' Push 2 IP
    Bcall var PORTB.6 ' Call Button
    Bcancel var PORTB.7 ' Cancel Button
    LedR = 0 ' led off
    LedG = 0 ' led off
    Start:
    BUZ = 1 ' Buzzer off
    KeyLine = 1 ' transmitter off
    Slp: ' Now prepare for sleep
    INTCON=0 ' Disable all interrupt including tmr0
    INTCON2.7 = 0 ' Enable weak pull-ups
    PORTA=%00001000 '
    PORTB=%11110000 '
    PORTC=%00001000 '
    TRISA = %00000000 '
    TRISB = %11110000 '
    TRISC = %00000000
    T2=PORTB ' Read port to ensure no setting of flag
    INTCON=%10001000 ' Enable the global interrupt and enable the change on port b
    @sleep
    PAUSE 100 ' Sound buzzer and Led as indicator of sleep exit
    ledr=1
    BUZ=0
    ledr=0
    BUZ=1
    goto slp
    Default Re: Getting a 18F2525 to wake up from sleep with change of input
    try this
    DEFINE OSC 20
     #config
     #endconfig
        T2  var     byte
        LedR = 0                    ' led off
        LedG = 0                    ' led off
     Start:
        PORTA=%00001000         '
        PORTB=%11110000         '
        PORTC=%00001000         '
        TRISA = %00000000       '
        TRISB = %11110000       '
        TRISC = %00000000
        INTCON=%00001000        ' Enable the global interrupt and enable the change on port b
    @ sleep
    @ nop
        ledr=1
        BUZ=0
        ledr=0
        BUZ=1
     goto slp
    Mar 2004
    UK-Midlands
    Two small changes makes it work.
    Many thanks Richard I was going round in circles getting nowhere.
    Bob
  1. 10F222 Wake on pin change
    By AvionicsMaster1 in forum PBP3
    Last Post: - 9th January 2014, 19:14
  2. Cannot wake from SLEEP
    Last Post: - 21st May 2013, 07:47
  3. 16F181: can't wake up from sleep
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 04:33
  4. wake up from sleep
    Last Post: - 31st August 2007, 17:09
  5. ? about sleep/wake on pin change and WDT
    By kessral in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 23:25
