WS2811 and WS2812 One-Wire Communication Assembly Help
Results 1 to 25 of 25
    Default Re: WS2811 and WS2812 One-Wire Communication Assembly Help
    Yes, I understand what your goal is and want to try your code out. I have a 8x8 neopixel to run it on.
    I referenced the other thread for the op who said he wasn't great at assembly code.
    Quote Originally Posted by mark_s View Post
    I would love to hear how you get on
    Richard I gave the code in post #2 a try. I don't have a 12mhz crystal so I am having problems configuring 4550 for 48mhz internal osc. My test board has a 10mhz resonator. The usb pre-scale stuff is throwing me off. If you could help me with the configurations for internal osc 48mhz or 40mhz using the pll and the 10mhz resonator. I may have it set ok I'm getting the signal on portc.0
    Also as posted the code makes one pass and stops. Is this the way it is intended to function? The neopixel did nothing so I added "goto aloop"
    above "stop" and get continuous pulse train on c.0. A few of the leds light. Unable to try your other code because I don't have that pic. Tomorrow I will give it another go.
    aloop:
         p_pc=nows    ;set number of leds to load
         @ Flash2Ram  _pixels,_rw1' Get a String from flash memory
         p_pc=nows     ;set number of leds to show
         call showpix
      goto aloop '????????????????
         stop
    the pll input needs to be 4MHz if you are going to use it . a 10MHz resonator
    cant be divided down to 4MHz using plldiv to keep pll input within specs .
    the xtal/res needs to be a multiple of 4 for correct use, my board has a 20MHz xtal
    out of spec operation may be possible but may lack stability required for this use
    yep that's all that code did , you should see a white "R" , a loop serves no
    purpose here, the other examples are more elaborate
    if you want text scroll
    aloop:
     for  p_offset=0 to 1536 step 24
         call showpix
         pause 200
      next
     goto aloop
         stop
    rw1:
      @ DW  0,0,0, 0,0,0,    0,0,0,    0,0,0,    0,0,0,    0,0,0, 0,0,0, 0,0,0
      ;192
      @ DW  0,0,0, 50,50,50, 50,50,50, 50,50,50, 0,0,0,    0,0,0, 0,0,0, 0,0,0 ;23
      @ DW  0,0,0, 50,50,50, 0,0,0,    0,0,0,    50,50,50, 0,0,0, 0,0,0, 0,0,0 ;47
      @ DW  0,0,0, 50,50,50, 0,0,0,    0,0,0,    50,50,50, 0,0,0, 0,0,0, 0,0,0 ;71
      @ DW  0,0,0, 50,50,50, 50,50,    50,50,50, 50,0,0,0, 0,0,0, 0,0,0, 0,0,0 ;95
      @ DW  0,0,0, 50,50,50, 0,0,0,    0,0,0,    50,50,50, 0,0,0, 0,0,0, 0,0,0 ;119
      @ DW  0,0,0, 50,50,50, 0,0,0,    0,0,0,    50,50,50, 0,0,0, 0,0,0, 0,0,0 ;143
      @ DW  0,0,0, 50,50,50, 0,0,0,    0,0,0,    50,50,50, 0,0,0, 0,0,0, 0,0,0 ;167
      @ DW  0,0,0, 0,0,0,    0,0,0,    0,0,0,    0,0,0,    0,0,0, 0,0,0, 0,0,0 ;191
      ;384
      @ DW  0,0,0, 0,0,0,    50,50,50, 50,50,50, 50,50,50, 0,0,0, 0,0,0, 0,0,0
      @ DW  0,0,0, 0,0,0,    0,0,0,    50,50,50, 0,0,0,    0,0,0, 0,0,0, 0,0,0
      ;576
      @ DW  0,0,0, 50,50,50, 0,0,0,    0,0,0,    0,0,0,    0,0,0, 0,0,0, 0,0,0
      ;768
      @ DW  0,0,0 ,50,50,50, 0,0,0,    0,0,0,    50,50,50, 0,0,0, 0,0,0, 0,0,0
      @ DW  0,0,0, 50,50,50, 50,50,50, 50,50,50, 50,50,50, 0,0,0, 0,0,0, 0,0,0
      ;960
      @ DW  0,0,0, 0,0,0,    50,50,50, 50,50,50, 0,0,0,    0,0,0, 0,0,0, 0,0,0
      ;1152
      ;1344
      @ DW  0,0,0 ,50,50,50, 50,50,50, 50,50,50, 0,0,0,    0,0,0, 0,0,0, 0,0,0
      ;1536
    Richard
    I changed the crystal to 20mhz and added the scroll code above. It's now working, so thanks for your efforts.
    I'll study the other code and see what I can do.
    Mark
    Similar to WS2811/2812 is the APA102C led chip, produced as a strip too.
    The Datasheet is unclear of the timing specs.
    I tried many hours to make it work but in vein. No led so far is under my control. Any ideas, welcome.
    An example code is this:
    arraywrite leds,[0,0,0,0,$f0,128,128,128,255,255,255,255]
    shiftout led_data,led_clock,1,[leds[0],leds[1],leds[2],leds[3],leds[4],leds[5],leds[6],leds[7],leds[8],leds[9],leds[10],leds[11]]
    Lcdout  $fe,$1,"Stoped"
    stop
    Any help?
    this may help
  1. PIC to WS2812B / WS2811 IC
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 19th January 2018, 20:37
  2. ws2812 - pic12f1822
    By richard in forum Code Examples
    Last Post: - 12th January 2016, 10:52
  3. Assembly
    By Normnet in forum mel PIC BASIC Pro
    Last Post: - 19th March 2007, 04:44
  4. How do you do this in Assembly
    By ice in forum mel PIC BASIC Pro
    Last Post: - 10th May 2005, 07:47
  5. Assembly?
    By Dwayne in forum General
    Last Post: - 4th January 2004, 19:18
