WS2811 and WS2812 One-Wire Communication Assembly Help
Results 1 to 25 of 25
    Miami, Florida USA
    Default WS2811 and WS2812 One-Wire Communication Assembly Help
    Hi all,
    I'm working on a project with the WS2812B LED lights. The PIC needs to send 24 bits for every LED that is connected in series. The 1st byte being for the green, the 2nd byte being for the red, and the 3rd byte being for the blue component. The 24 bits for the first LED look like this,
        '###### WS2812 HIGH BIT (1 CODE) ######
        PORTD.0 = 1         'WS2812 DRIVE LINE
        '####### T1H #######
            nop    ; ~97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
        PORTD.0 = 0         'WS2812 DRIVE LINE
        '####### T1L #######
            nop
            nop
            nop
            nop    ; ~97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; ~97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; ~97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; ~97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; ~97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; ~97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; ~97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
        '###### WS2812 LOW BIT (0 CODE) ######
        '####### T0H #######
            nop    ; 97 nSecs
            nop
            nop
        '####### T0L #######
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop    ; 97 nSecs
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
            nop
    Here, I'm sending [255,0,0] for a pure green output. As you can see this code is not the most effective one. Specially, when you need to send data to 100+ WS2812B LEDs. If you add any FOR..NEXT, or IF...ENDIF loops, the precise timing of the HIGH and LOW bits is messed up. Actually, I think that any PICBasic command wouldn't help with the timing. Any help to implement this code in assembly would be appreciated. I'm using a PIC18F4550 at 48MHz.
    Thank you,
    Anonymous
    Default Re: One-Wire Communication Assembly Help
    basic looping structures are the very essence of good programing ,try this
    its based on one of those 8x8 ws2812 panels and sends data TO 64 leds
    it can handle upto 256/3 leds , and can take the data from sram and/or the flash rom
    Miami, Florida USA
    Thanks. Assembly is not something that I'm very familiar with. I'll go over this code. It seem to do what I need.
    Anonymous
    Default WS2811 One-Wire Communication Assembly Help
    I am after such a project too. Unfortunately Assembly is not too friendly.
    I found this AN from Microchip, AN1606 that uses the CLC module on some new chips, like the 16F1509.
    After a cryptic analysis of the timing using TMR, PWM and CLC modules, the AN claims that can produce the strict timing required for the WS2811 chip.
    Well, only the setting is shown and not the use of this settings on the PIC.
    Anyone has any idea how to use the PIC for sending the RGB data?
    Following is the settings for the 1509 registers to obtain the correct timing on the RC4/CLC4 port pin #6, based on the slow mode of WS2811.
    ' Initialize PIC16(L)F1509 CLC2, CLC4, Timer2, and MSSP
    ' for WS2811 signal transmission protocol
    ' Loading SSP1BUF register sends that data byte out the RC4/CLC4 pin
    ' PWM1 routed straight through CLC2
    CLC2GLS0 = $20
    CLC2GLS1 = $00
    CLC2GLS2 = $00
    CLC2GLS3 = $00
    CLC2SEL0 = $00
    CLC2SEL1 = $06
    CLC2POL = $0E
    CLC2CON = $82;
    ' (SPI SDO & SPI CLK) || (nSPI SDO & SPI CLK & PWM1)
    ' PWM1 comes through CLC2
    CLC4GLS0 = $44
    CLC4GLS1 = $10
    CLC4GLS2 = $80
    CLC4GLS3 = $20
    CLC4SEL0 = $50
    CLC4SEL1 = $05
    CLC4POL = $01
    CLC4CON = $C0
    ' Adjust Timer2 period for desired baud rate
    ' One bit period is two Timer2 periods
    T2CON = $04
    PR2 = 5
    ' Adjust PWM1 duty cycle for desired "0" data-bit duty cycle
    ' ‘1’ data-bit duty cycle is automatically 50%
    PWM1CON = $E0
    PWM1DCH = 2
    PWM1DCL = 0
    ' MSSP configured for SPI master with Timer2_Period/2 clock
    SSP1CON1 = $23
    ' Output on RC4/CLC4
    TRISC = $EF
    Any help appreciated.
    Default Re: WS2811 and WS2812 One-Wire Communication Assembly Help
    interesting find ioannis.
    the an seems to lack many details not just how to use it ,I tried it out on a pic16f1619 and discovered that the an description of the clc cells setup is quite misleading
    the reality is they are set like in these images
    I'm not sure I have this exactly correct but it looks to work
    i have included my working example it spits out data for 64 leds [192 bytes] in 2mS.
    I cant see much advantage to it over my earlier routine you only have a few uS between bytes barely enough time for a pbp style dt interrupt
    a small refinement
    CLC1 can be released from use its not needed with a 16f1619
    by
    CLC2SEL1 = $0E; in lieu of 04
    Hello all,
    here is, if someone interested my simple one (or more) neopixel driver. In demo it fades through basic RGB colours. Code is simply modifiable to lit up any kind of colour. Only changing the NeoRed, NeoGreen, NeoBlue variables.
    '*  Name    : One_Neopixel_driver                               *
    '*  Author  : Louis                                             *
    '*  Notice  : Copyright (c) 2019                                *
    '*  Date    : 1. 12. 2019                                       *
    '*          : 12F1840                                           *
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    DEFINE OSC 32       ; Use internal clock 32MHz
    OSCCON  = %11110000 ; 8 MHz internal x 4
    OSCTUNE	= %00000000	; Internal osc tunning
    WHILE !OSCSTAT.3	; Wait for stable OSC
    WEND
    TRISA = 0
    ANSELA = 0
    OPTION_REG.7=1      ; disable internal pull-ups
    ADCON0 = 0
    ADCON1 = 0
    ;------------ Variables ---------------------
    NeoGreen    VAR BYTe
    NeoBlue     VAR BYTE
    NeoRed      VAR BYTE
    NeoPixel    VAR BYTE
    BitCount    VAR BYTE
    DataBit     VAR byte
    Cnt         var byte
    n           var byte
    Flag        var bit
    ;------------ ALIAS -------------------------
    NeoPin      VAR porta.2
    ;-----------  Initialization ----------------
    Clear   ; Clear All
    ;------------ Main program ------------------
            pause 10
            if flag = 0 then
                n=n+1
                n=n-1
                  if n=0 then
                     flag = 0
                     cnt = cnt + 1
            if n = 254 then flag = 1
            if cnt > 2 then cnt = 0
                if cnt = 0 then
                NeoGreen = n     ; value 0-254 for green color
                NeoGreen = 0
                if cnt = 1 then
                Neoblue = n      ; value 0-254 for blue color
                Neoblue = 0
                if cnt = 2 then
                Neored = n      ; value 0-254 for red color
                Neored = 0
            gosub NeoDraw
    GOTO Main
    ;------------ Extract bites ---------------
    NeoDraw:
            FOR BitCount = 7 TO 0 step -1
                DataBit = NeoGreen.0[bitcount]
                GOSUB NeoBit
            NEXT
                DataBit = NeoRed.0[bitcount]
                GOSUB NeoBit
            NEXT
                DataBit = NeoBlue.0[bitcount]
                GOSUB NeoBit
            NEXT
    ;------------ Pulse generator ---------------
    NeoBit:
        IF DataBit = 1 THEN
            ;generate 800ns pulse
            NeoPin = 1
                nop
                nop
                nop
                nop
                nop
            NeoPin = 0
            ;generate 400ns pulse
            NeoPin = 1
                nop
                nop
            NeoPin = 0
  1. PIC to WS2812B / WS2811 IC
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 19th January 2018, 19:37
  2. ws2812 - pic12f1822
    By richard in forum Code Examples
    Last Post: - 12th January 2016, 09:52
  3. Assembly
    By Normnet in forum mel PIC BASIC Pro
    Last Post: - 19th March 2007, 03:44
  4. How do you do this in Assembly
    By ice in forum mel PIC BASIC Pro
    Last Post: - 10th May 2005, 06:47
  5. Assembly?
    By Dwayne in forum General
    Last Post: - 4th January 2004, 18:18
