Connect two PICs?
Results 1 to 4 of 4
    Jan 2012
    Grid EN19MV
    Default Connect two PICs?
    I have a situation where I need to connect two PICs. One is the 'master' and one is the slave. An output on the master goes to an input on the slave (weak pull-up enabled) and I only need to signal two states.
    My question is: Do I need a current limiting resistor on that line? I keep vacillating between the two answers, and thought I'd ask the experts.
    Andy
    -Stephen Hawking
    Default Re: Connect two PICs?
    As long as you don't switch the slave pin to output you don't need a current limit resistor.
    Jan 2012
    Grid EN19MV
    That's kind of what I was leaning toward.
    Thanks Henrik
    -Stephen Hawking
    Personally I would place a 4.7k resistor in series with each line connecting the two. That will limit the current to approx. 1 Ma. incase of the software or other malfunction you will not short ether processor pin to +5 volts or Ground.
    EN82fn
  1. connect two pics
    By soki in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2008, 07:29
  2. connect 2 PICs
    By drama in forum mel PIC BASIC
    Last Post: - 4th October 2007, 17:55
  3. how can i connect the speaker
    By pcbb in forum mel PIC BASIC Pro
    Last Post: - 7th April 2007, 19:28
  4. XPort or Connect Me help???
    By ccsparky in forum mel PIC BASIC Pro
    Last Post: - 26th November 2005, 17:37
  5. Which is the best way to connect..
    By dtit in forum Schematics
    Last Post: - 19th January 2005, 11:02
