38Khz IR carrier - best way to turn it on and off
Results 1 to 17 of 17
    Aug 2003
    Default Re: 38Khz IR carrier - best way to turn it on and off
    Have you tried turning it off and on again?
    MAIN:
    	HPWM 1, 127, 38000
            pauseus 1000
    	HPWM 1, 0, 38000
            pauseus 1000
    	GOTO MAIN
    Strictly speaking of course, the HPWM takes some instructions so the loop takes longer than 2ms to execute,
    but you could make your own time wasting routine for accurate delay, so that shouldn’t be a problem.
    I mentioned that since I noticed you had more accurate timing before using HPWM only once.
    But you have a scope, you don’t even have to do the math to calculate a time waste routine.
    Frequency
    is the desired frequency of the PWM signal. On devices with 2
    channels, the
    Frequency must be the same on both channels. Not all frequencies
    are available at all oscillator settings. For the non-long versions of PBP (PBP and
    PBPW), the highest frequency at any oscillator speed is 32767Hz. The lowest
    usable HPWM
    Frequency at each oscillator setting is shown in the following table.
    quote from the pbp3 manual
    did you actually check the resulting freq, it can be done manually of course
    would a pull down resistor (say 1k) make the trace look better
    Here's what had worked for me. Richard is right, you cant use HPWM for frequencies above 32.768khz.
    Set the registers as follows.
    TRISC.2 = 0 ' CCP1 (PortC.2 = Output)
    PR2 = 25 ' Set PWM Period for approximately 38KHz
    CCPR1L = 13 ' Set PWM Duty-Cycle to 50%
    CCP1CON = %00001100 ' Mode select = PWM
    T2CON = %00000100 ' Timer2 ON + 1:1 prescale
    This would give you a continuous 38khz on the pwm pin, at 50% duty cycle.
    Now, toggle TRISC.2 between an input and an output at 1ms.
    Hope it works! If it does, thanks go to Bruce Reynolds. If doesnt, brickbats to me!
    Regards.
    that would be for fosc=4
    for my money I'd say :
    CCPR1L = 52 ' Set PWM Duty-Cycle to 50%
    {mister_e pic multi-calc}
    As Ardhuru said, credit to Bruce Reynolds for publishing some great projects.
    Maybe you can gets some ideas here.
    http://wayback.archive.org/web/20120...com/remote.htm
    Jan 2012
    Grid EN19MV
    From what I understand of what was quoted, 32768Hz was maximum WITHOUT using longs. I'm using an 18F2550, and when I compile, I get the following message:
    '[MESSAGE]pic18f2550.pbpinc(285): LONG Variables enabled (PBPL used)'
    It seems like it used longs because of the frequency I specified, and it seemed happy. Anyway, the problem is solved, see my last post.
    Thanks for the help!
    -Stephen Hawking
    Jan 2012
    Grid EN19MV
    Default Re: 38Khz IR carrier - best way to turn it on and off - SOLVED
    Thanks Everyone!
    It worked!
    The answer was a pull down resistor. It got rid of that slope. I tried a few, and worked out that 4.7K was the highest value I could use. That gave me a final voltage about 4.2V which should be fine.
    Then I had to play with the frequency I specified to get exactly 38 pulses in 1mS. Even though the scope's measurement function still reports it as 38.46KHz - I told you it was a cheap scope!
    Here are two images of what I have now.
    Thanks again!
    Andy
    Attachment 8114
    -Stephen Hawking
    the scope is actually correct.
    38.462KHz is as close as you can get to 38KHz hpwm with a 4MHz osc
    Jan 2012
    Grid EN19MV
    I'm using the 8Mhz internal oscillator. I'm curious how you figured that out though, could you educate me?
    What if I used a 10 or 16Mhz crystal? I have both on hand.
    -Stephen Hawking
    Jan 2012
    Grid EN19MV
    Well, the scope has measurement functions. Again, this is NOT an expensive scope ($75), but it was reporting 38.46KHz and 26uS period......both right in the ballpark of what I was looking for.
    And that was the answer! See my last post for images.
    Thank you!!
    -Stephen Hawking
    Jan 2012
    Grid EN19MV
    MAIN:
    	HPWM 1, 127, 38000
            pauseus 1000
    	HPWM 1, 0, 38000
            pauseus 1000
    	GOTO MAIN
    Hmm, tried it, but I couldn't get the frequency up high enough due to the 'setup time' of HPWM. See below though.....got it looking great now.
    Thanks Art,
    Andy
    -Stephen Hawking
  1. How to setup 38kHz PWM with PIC18F1330
    Last Post: - 7th March 2015, 12:35
  2. 38Khz Modulator
    By Gord11 in forum mel PIC BASIC Pro
    Last Post: - 28th September 2011, 08:14
  3. Turn me on
    By AvionicsMaster1 in forum General
    Last Post: - 16th November 2010, 14:04
  4. turn-off lcd and turn-on again
    By mehmetOzdemir in forum mel PIC BASIC Pro
    Last Post: - 5th September 2009, 12:57
  5. Generated square wave 19Khz and 38Khz
    By blinkstar88 in forum mel PIC BASIC Pro
    Last Post: - 9th August 2007, 16:40
