38Khz IR carrier - best way to turn it on and off
Results 1 to 17 of 17
Threaded View
  1. #3
    Jan 2012
    Grid EN19MV
    Default Re: 38Khz IR carrier - best way to turn it on and off
    [QUOTE=Art;135608]Does it happen with x10 attenuation probes and setting on the scope?
    Yes. Here is the image:
    I also had the thought that I did not have a decoupling capacitor on Vdd - no difference. I also tried hooking a regular LED up to the port as I only had the scope hooked up to the port before. No difference.
    I also realized that I did not have to keep turning the PWM on and off, all I had to do was the HPWM command once, and then change the port back and forth. No difference, but here is the code now.
    HPWM 1, 254, 38000
    MAIN:
        pauseus 1000
        TRISC = $FF
        pauseus 1000
        TRISC = $0
        GOTO MAIN
    You'll notice, I tried switching the whole port - no joy. This is getting frustrating, any other ideas?
    *Update* I had the bright idea that, maybe, if I turned a MOSFET on and off with another port and used the MOSFET to switch the pwm signal on and off, it would get better. Not really, its about the same, but as the MOSFET turns off, that slope has the pwm signal messing it up. So its worse. Back to the way it was - I guess I'll have to try it. Of course, I can't try it until after Christmas......
    Andy
    -Stephen Hawking
  1. How to setup 38kHz PWM with PIC18F1330
    Last Post: - 7th March 2015, 13:35
  2. 38Khz Modulator
    By Gord11 in forum mel PIC BASIC Pro
    Last Post: - 28th September 2011, 09:14
  3. Turn me on
    By AvionicsMaster1 in forum General
    Last Post: - 16th November 2010, 15:04
  4. turn-off lcd and turn-on again
    By mehmetOzdemir in forum mel PIC BASIC Pro
    Last Post: - 5th September 2009, 13:57
  5. Generated square wave 19Khz and 38Khz
    By blinkstar88 in forum mel PIC BASIC Pro
    Last Post: - 9th August 2007, 17:40
