16f877 with LM335 problem - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
  1. #41
    SWITZERLAND (french speaking)
    Default Re: 16f877 with LM335 problem
    So this is where I am right now.
    First, here's my hardware. What you won't see on the schema is the serial comm lead connected to PIC's PORTB.7 .
    Name:  freezer temp sensor hw.jpg
    Here's the code:
    ' PIC 16F690 Fuses
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_HS_OSC &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    '_______________________________________________________________________________
    ' Registers   76543210
    OPTION_REG = %10000000 'OPTION REGISTER
    ANSEL      = %00000100 'Select analog inputs Channels 0 to 7
    ANSELH     = %00000010 'Select analog inputs Channels 8 to 11
    ADCON0     = %00000001 'A/D control register
    ADCON1     = %00000000 'A/D control register
    CM1CON0    = %00000000 'Comparator1 Module
    CM2CON0    = %00000000 'Comparator2 Module
    INTCON     = %00000000 'INTerrupts CONtrol
    TRISA      = %00000100 'Set Input/Output (0 to 5)
    PORTA      = %00000000 'Ports High/Low (0 to 5)
    TRISB      = %00000000 'Set Input/Output (4 to 7)
    PORTB      = %00000000 'Ports High/Low (4 to 7)
    TRISC      = %10000000 'Set Input/Output (0 to 7)
    PORTC      = %00000000 'Ports High/Low (0 to 7)
    ' Defines
    DEFINE ADC_BITS 10
    ' Variables
    LM35_Vout       var word ' AN2 PORTA.2
    LM35_VGND       var word ' AN9 PORTC.7
    Temperature     var word
    DataVar         VAR WORD(12)
    DataTemp        var WORD
    Counter_A       var WORD
    ' Program
    MAIN:
        ' LM35_Vout
        FOR counter_A = 0 to 11
            adcin 2, DataVar(counter_A)
        next counter_A
        Counter_a = 0
        GOSUB SORT
        LM35_Vout = DataTemp
        ' LM35_VGND
            adcin 9, DataVar(counter_A)
        next counter_A
        Counter_a = 0
        GOSUB SORT
        LM35_VGND = DataTemp
        Temperature = (LM35_Vout - LM35_VGND) * 100
        GOSUB DISPLAY
    Goto main:
    ' Subroutine
    DISPLAY:
        Serout2 PORTB.7,84,["Temp.: ", dec4 temperature,"  LM35_Vout: ", dec4 LM35_Vout,"  LM35_VGND: ", dec4 LM35_VGND,13]
    ' Subroutine
    SORT:
    ' Melanie NEWMAN's array sorting routine
    '    Aquire 12 values, delete 4 lower and 4 top values, average 4 remaining values
        If DataVar(counter_A + 1) < DataVar(counter_A) then
            DataTemp = DataVar(counter_A)
            DataVar(counter_A) = DataVar(counter_A + 1)
            DataVar(counter_A + 1) = DataTemp
            If Counter_A > 0 then Counter_A = Counter_A - 2
        Counter_A = Counter_A + 1
        If Counter_A < 11 then GOTO SORT
        ' Average four middle values
        DataTemp = 0
        For Counter_A = 4 to 7
            DataTemp = DataTemp + DataVar(counter_A)
        next Counter_A
        DataTemp = DataTemp / 4
    And here is the reading I get right now, knowing the temperature sensor is on my desk close to three other thermometers showing 21°C. Promised, I won't forget to format the "Temp." display in the final version (i.e. "9456" => "94,56°C")
    Name:  values displayed.jpg
    What's wrong with it?
    I have set and defined a 10 bits ADC result. How can I get values over 1023?
    I might be wrong with the ADCON0.7 setting but I'm not used to modify it so I'm not sure about that.
    Any other idea?
    Roger
  2. #42
    That's because you have left justified the ADC result in ADRESL and ADRESH.
    Set the adcon0 to %10000001.
    Also you have this calculation:
    What about LM35_Vout being less than LM35_VGND?
    I expected you would do this and noted in earlier post (#33)
    The simplest way is to have an if-then check first like this:
     if LM35_Vout >LM35_VGND then
     if LM35_Vout <= LM35_VGND then
           Temperature = (LM35_VGND - LM35_Vout) * 100
  3. #43
    ...What about LM35_Vout being less than LM35_VGND?
    Sorry, I forgot this one . I was focused on the "mysterious" values I was reading.
    Quote Originally Posted by me
    I changed to ADCON0.7 = 1 and the values I read look much better. Still the Temperature value has to be divide by 2 to give the correct reading.
    Name:  Correct values.jpg
    Even if it's not the main subject here, can you shortly explain what the difference between ADCON0.7 = 0 and ADCON0.7 = 1 is?
    The temporary code is now:
    ' PIC 16F690 Fuses
    ADCON0     = %10000001 'A/D control register
    TRISA      = %00000110 'Set Input/Output (0 to 5)
    ' Defines
    DEFINE ADC_BITS 10
    ' Variables
    DataTemp        var WORD
    Counter_A       var WORD
    ' Program
    MAIN:
        ' LM35_Vout
        next counter_A
        Counter_a = 0
        GOSUB SORT
        ' LM35_VGND
        next counter_A
        Counter_a = 0
        GOSUB SORT
            Temperature = ((LM35_Vout - LM35_VGND) * 100) / 2
            Temperature = ((LM35_VGND - LM35_Vout) * 100) / 2
        GOSUB DISPLAY
    Goto main:
    ' Subroutine
    DISPLAY:
        Serout2 PORTB.7,84,["Temp.: ", dec2 (temperature/100),",",dec1 (temperature/10),"°C  LM35_Vout: ", dec4 LM35_Vout,"  LM35_VGND: ", dec4 LM35_VGND,13]
    ' Subroutine
    SORT:
    ' Melanie NEWMAN's
    ' This subroutine sorts, in this example, 12 elements,
    '   MyData array in sequence placing the smallest value into MyData[0] and
    '   the largest value into MyData[11]...
        DataTemp = 0
        next Counter_A
    Roger
  4. #44
    Jan 2013
    Texas USA
    Roger,
    Check out section 9.1.6 "Result Formatting" of the Datasheet.
    It shows the difference in the two formatting options.
    In essence Right Shifted will place the 10-bit value in bits 9 through 0 (MSB is bit9).
    Left Shifted will place the 10-bit value in bits 15 through 6 (MSB is bit15)
    So if your ADC reading is 250 then here would be the values.
    Right Shifted = 250 (%0000 0000 1111 1010)
    Left Shifted = 1600 (%0011 1110 1000 0000)
    TABSoft
  5. #45
    Thanks Tabsoft,
    I already read that chapter may times but I just can't understand what this feature is meant for.
    Why would one choose either option?
    I need an example of both usage, maybe this could help
    Roger
  6. #46
    If you want to use only 8 bit (may be it is enough for specific application) then the left justified result will give yout the number in the ADRESH directly. No shifting or dividing required.
    But for the full 10 bit results you have to right justify the bytes in the ADRESH-ADRESL to be correct.
    Default ADC - left or right justified result
    Okay, I think, I've got it now. Next problem: I need to remember it
    Roger
  1. 16F877 HSERIN problem with 3th party software
    Last Post: - 11th March 2009, 17:11
  2. LCD problem with 16F877
    By alexx_57 in forum General
    Last Post: - 25th July 2007, 13:47
  3. problem using 16f877
    By yrch in forum mel PIC BASIC Pro
    Last Post: - 20th February 2006, 18:58
  4. 16F877 20MHz problem
    By swordman in forum mel PIC BASIC Pro
    Last Post: - 31st July 2004, 10:02
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
