Using floating point
Results 1 to 9 of 9
    Default Re: Using floating point
    So you have a raw reading which you want to divide by 1.64, is that correct? Or do you want to multiply the raw value by 1.64?
    TempC = TempC ** 39961 ' Multiplu by 0.60976 which is the same as dividing by 1.64
    or
    TempC = TempC */ 420 ' Multiply by ~1.641
    or
    TempC = TempC + (TempC ** 41943) ' Multiply by 0.64 and add result to previous value.
    If neither of these works can you give us a bit more details about how the raw values correlates to actual temperature. Ie what raw value do you get at 0 temp and what raw value do you get at max temp (500 degrees in this case).
    Jan 2012
    Grid EN19MV
    or
    or
    Divide by 1.64. I found that the meat thermocouple in boiling water required me to divide by 1.64 to get 100C. The cooker thermocouple was a similar (but slightly different) number. In reality, I have a calibration routine that determines the number then it is stored in COOK_ADJUST or MEAT_ADJUST. This is so I can easily correct if a new thermocouple is installed.
    After reading Jerson's post, I changed C_TEMP and M_TEMP (the cooker and meat raw ADC values, respectively) to LONGS. I came up with the following that I will try when I finish building the new board:
     	C_TEMP = C_TEMP * 1000
    	C_TEMP = C_TEMP / COOK_ADJUST 'ADJUST * 1000
    	C_TEMP = C_TEMP + (C_TEMP << 3) ' mul by 1 x + 8*x = 9x
    	C_TEMP = C_TEMP / 5 ' div by 5
            C_TEMP = C_TEMP + 320 ' add 32 with 1 decimal accounted for
    	M_TEMP = M_TEMP * 1000
    	M_TEMP = M_TEMP / MEAT ADJUST
    	M_TEMP = M_TEMP + (M_TEMP << 3) ' mul by 1 x + 8*x = 9x
    	M_TEMP = M_TEMP / 5 ' div by 5
            M_TEMP = M_TEMP + 320 ' add 32 with 1 decimal accounted for
    		           'CT:nnn.nF  MT:nnn.nF
    	LCDOUT $FE, $80, "CT:", DEC3 (C_TEMP / 10), ".", DEC1 (C_TEMP MOD 10), "F"
    	LCDOUT $FE, $80 + 9, "  ", "MT:", DEC3 (M_TEMP /10), ".", DEC1 (M_TEMP MOD 10), "F"
    I think this will work. Opinions?
    -Stephen Hawking
    Jan 2012
    Grid EN19MV
    Henrik, I just had a thought. How is the fact that I changed my temperature value to a long going to affect your PID routine? Specifically, pid_error and my set point are words, the actual temperature is a long.
    I've never used longs before, can you mix them with words? And I guess that I will have to use C_TEMP / 10 to get the integer portion in the equation: pid_error = setpoint - temperature?
    -Stephen Hawking
    Bombay, India
    Andy, your code looks workable. To simplify things, I use a tool from http://www.miscel.dk called miscellaneous electronic calculations. In that you will find an integer math module that tells you 1.64 is same as 41/25 if you want to use 8 bit math. It's a nice tool to augment your collection and I suggest you give it a try
    It doesn't really matter as long as you make sure that you don't overflow the pid_Error variable. And remember that pid_Error is a two's complement variable so anything above 32767 is considered negative.
    Yes, a LONG minus a LONG can still fit a WORD or even a BYTE. There MAY be some differences when it comes to multiplications because LONGs are signed while WORDS and BYTES are not - I'd take a look at the manual in case it's mentioned there.
    The general rule is to have the PID routine work with your raw numbers as long as the raw numbers aren't big enough to risk overflowing. There's no need for "empty resolution". The PID routine is just crunching numbers, it doesn't know what the numbers mean or represent so there's no need to have the values scaled to degrees C or whatever. As long as YOU remember to have the setpoint and actual temp variable scaled equally when you calculate pid_Error it'll be fine - then you can scale those value up or down all you want for humans to be able to make sense out of them ;-)
  1. Using floating point
    By andywpg in forum PBP3
    Last Post: - 24th February 2015, 17:42
  2. Floating point math
    By Glenn in forum mel PIC BASIC Pro
    Last Post: - 5th January 2009, 04:47
  3. Getting out of floating point
    By jcb344 in forum General
    Last Post: - 5th August 2008, 22:18
  4. Floating Point
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 15th May 2005, 15:19
  5. help floating Point!
    By Eric in forum mel PIC BASIC Pro
    Last Post: - 7th December 2003, 22:18
