Found label after column 1 : Unsucessful Installation ?
Results 1 to 6 of 6
    Default Re: Found label after column 1 : Unsucessful Installation ?
    There is no problem with the code. It has been working perfectly with previous versions of sofware 7 years ago (2.5 or something like that). I tried it with and without spaces: the result is the same.
    Now I have reinstalled MCS and have bigger problems: I have to point to proper folder for PBC compiator every time, 16F88 has dissapeared from dropdown menu and only 16F628 left etc.
    Quote Originally Posted by truffaldino View Post
    There is no problem with the code..
    Perhaps. But study the 2 pictures I have posted, only difference is a whitespaceName:  noerrconfig.png
Size:  24.4 KBName:  errconfig.png
    Thanks a lot Archangel!
    It is not the installation problem indeed: picbasic has changed since I have used it for the last time. In the newest version we have to use the following type of config for 16f88!
    __CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_ON & _WDT_OFF & _INTRC_IO
    __CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
    Yea the configs I showed were for earlier versions, I missed the PBP3 in your post. The whitespace problem upsets ver 3 too, it's not a PBP issue, as pbp compiles fine but mpasm gets a little upset by it, as the config statements are really strictly Assembly code.
  1. Installation. Include file not found?
    By thronborg in forum General
    Last Post: - 18th March 2011, 20:46
  2. MPLAB ICD2 progammer installation problem
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 8th February 2011, 04:33
  3. Replies: 27
    Last Post: - 7th December 2007, 23:28
  4. ic prog installation
    By sakthi in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 15:01
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 04:56
