math function to change a value 1- 8 to a bit representation
Results 1 to 9 of 9
    Feb 2012
    PERTH AUSTRALIA
    Default math function to change a value 1- 8 to a bit representation
    it late and minds going dull
    looking for a math function to change a value 1- 8 to be bit 0 - 7 representation value
    value 1 = 1 ' bit 0
    2 = 2 ' bit 1
    3 = 4 ' bit 2
    4 = 8 ' bit 3
    5 = 16 ' bit 4
    6 = 32 ' bit 5
    7 = 64 'bit 6
    8 = 128 ' bit 7
    cheers
    Default Re: math function to change a value 1- 8 to a bit representation
    see the DCD operator
    Apr 2011
    Welches, Oregon
    DCD is exactly right, remember however that DCD sets all other bits to 0.
    If your intent is to change only a single bit: VAR.0[VALUE - 1] = 1
    Feb 2012
    PERTH AUSTRALIA
    would it be
    if value > 2 then VAR.0[VALUE - 1]
    cos if value below 2 would be incorrect bit ??
    May 2008
    Italy
    This snippet (not tested) should do the trick.
    X VAR byte
    Answer VAR byte
    X = 128
    Gosub Decode
    ' variable answer should contain your bit position
    Decode:
    Answer = 0
    If X < 1 then return
    Do while X <> 1
    Answer = answer + 1
    X = X > 1
    Wend
    Edited:
    Reading again your first post I realise you need the other way around:
    X = 8
    Gosub Decode
    Answer will contain the requested value
    Decode:
    Answer = 0
    For i = 1 to X
    Answer = answer < 1
    Next i
    Cheers
    Al.
    X = 8
    Gosub Decode
    Decode:
    Answer = 0
    For i = 1 to X
    Answer = answer < 1
    Next i
    Hmmm....Answer = answer < 1
    If the above is meant to be a shift left operation then what you want is Answer = Answer << 1
    However, since Answer is set to 0 at the entry point of the routine shifting it left any number of times will still result in it being 0 when returning.
    Apr 2011
    Welches, Oregon
    Quote Originally Posted by longpole001 View Post
    would it be
    I'm a noob myself, but no... The VAR.0[] syntax is a way of addressing each bit and, while it affects the value of the byte, the bits do not interact.
    Some examples:
    VAR= %00000000 : VAR.0[0] = 1 : 'VAR NOW EQUALS %00000001
    VAR= %00000100 : VAR.0[0] = 1 : 'VAR NOW EQUALS %00000101
    VAR= %10100001 : VAR.0[1] = 1 : 'VAR NOW EQUALS %10100011
    VAR= %11111100 : VAR.0[7] = 0 : 'VAR NOW EQUALS %01111101
    As you can see by the last example, turning "off" bits is the same, only assign a 0. Reassigning a bit, already set (or cleared) has no effect.
    May 2008
    Italy
    Just a typo! What else if not shift left.
    Cheers
    Al.
    Feb 2012
    PERTH AUSTRALIA
    yep it sorted a few less if then statements
  1. Logaritmic ADC representation
    Last Post: - 5th April 2010, 12:05
  2. 32 bit math
    By fnovau in forum General
    Last Post: - 13th February 2008, 00:55
  3. Averaging 16 bit values without using 32 bit math
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 5th October 2007, 23:18
  4. 32 bit math
    Last Post: - 28th August 2006, 14:34
  5. not quite understanding the MATH function
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 17th January 2006, 21:20
