Hmmm....Answer = answer < 1Code:X = 8 Gosub Decode Answer will contain the requested value End Decode: Answer = 0 For i = 1 to X Answer = answer < 1 Next i Return
If the above is meant to be a shift left operation then what you want is Answer = Answer << 1
However, since Answer is set to 0 at the entry point of the routine shifting it left any number of times will still result in it being 0 when returning.
