PIC16F628A Will not run at all....
Results 1 to 14 of 14
    Default Re: PIC16F628A Will not run at all....
    Quote Originally Posted by aratti View Post
    I don't see the oscillator register settings. You have to turn off comparators (if any). Did you pulled up the MCLR pin?
    Cheers
    Al.
    Yes MCLR is 5V+
    Isn't that what _INTRC_OSC_NOCLKOUT is for?
    Is there a way to set the config bits using binary in pbp3? I have been searching for hours and its extremely frustrating to have so many different ways to do it apearantly, and none of them seem to work right. And the one I KNOW will work right, I can't find a damn syntax for....
    My pic has a 14 bit config and I want 10000111111000 but I cannot figure out the command to enter it....
    You could use assembler directives (if PBP allows them)
    Quote Originally Posted by thasatelliteguy View Post
    Yes MCLR is 5V+
    The config tells the PIC you want it to use the internal OSC, DEFINE OSC 4 tells PBP you are using 4 mhz so it knows how to adjust it's timing to agree with your intentions. I believe 4mhz is PBP default, but would not depend on defaults, period. Always define in your code what you expect, and the surprises (like not working) disappear.
  1. RTC run too fast
    By pedja089 in forum mel PIC BASIC Pro
    Last Post: - 14th December 2012, 20:17
  2. Run-Time Config
    By Darrel Taylor in forum PBP Extensions
    Last Post: - 1st February 2012, 17:26
  3. 16F628 does not run. I can't believe this
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2009, 16:41
  4. Intermittent code cannot run
    Last Post: - 8th November 2008, 03:45
  5. How to run program in parallel?
    By vanxn in forum mel PIC BASIC Pro
    Last Post: - 18th July 2006, 22:59
