Single PIC to Blink 5 LEDs Independently?
Results 1 to 40 of 69
    Default Re: Single PIC to Blink 5 LEDs Independently?
    On the 12F683, the CCP1IF bit is PIR1.5.
    Why they have to change things all the time ... I don't know.
    CCPIF         VAR PIR1.5
    Both the OSCCON and CMCON0 values don't have enough digits.
    added: CMCON0 won't matter cause it's still 7, but to keep things consistent ...
    OSCCON   = %01110000        ' 8Mhz
    CMCON0   = %00000111	    ' Turn off comparators
    Not sure how this got changed, it should be ...
    FOR x = 0 to (LEDcount - 1)           ; Load the periods from EEPROM
    Apr 2011
    Welches, Oregon
    Again, not wholly sure what your trying to do... I have trouble following someone else's code (even my own sometimes), but a PWM output tied to one input of each (yes, 5) "AND" gate, the other input to each I/O. Toggling I/O then controls modulated output. I am thinking of IR communications where a serial data stream and 38K PWM are "ANDed" for IR transmission.
    Quote Originally Posted by Amoque View Post
    I was initially intending to make the brightness of the LEDs controllable via PWM, but now the chips are moving off the main board to another PCB that will be buried deep within my model where they will only have +5V & GND wires. These boards are too small to add any other components (even SMTs) so I'll just have to breadboard them with various series-limiting resistors to get the right brightness.
    Your suggestion is something I will investigate for the rest of my circuit where I do intend to provide brightness control on the main board. Right now, I'm daisy-chaining 2 NPNs which someone on SparkFun suggested but I haven't breadboarded it yet to see if it works.
    Quote Originally Posted by RossWaddell View Post
    BTW, what software is that you are using to test out the code?
    It's Proteus Design Suite from Labcenter Electronics.
    I was initially intending to make the brightness of the LEDs controllable via PWM, ... so I'll just have to breadboard them with various series-limiting resistors to get the right brightness.
    That can be done in software using MIBAM.
    The blinky's timer will have to be changed, but it's doable.
    Spent a very happy afternoon reading up on MIBAM - can't wait to try it out (is there a later version of the .pbp code or is the v1.0 you posted on the melbas page the one I should use?).
    In preparation for that, I converted the now-workiing code to use Timer2. I think that since Timer2 is 8-bit (versus 16-bit for Timer1) that I don't need to worry about using the Least Significant register as you did with Timer1 but can just use TMR2:
    CCPR1val      CON EXT      : @CCPR1val = (OSC*1000000/4)/ BLINKYFREQ
    ;CCPR1         VAR WORD EXT : @CCPR1 = CCPR1L
    Timer2        VAR WORD EXT : @Timer2 = TMR2
    CCPIF         VAR PIR1.5
    And then this to turn it on:
    ;-- setup CCP1 and Start Timer2 --
    CCPR1   = CCPR1val          ; set compare value
    CCP1CON = %00001011         ; compare mode, special event
    Timer2  = 0                 ; clear Timer2
    T2CON.0 = 1                 ; start Timer2
    Is that it?
    Or maybe not. The PIC12F683 data sheet seems to indicate that the Compare mode uses only Timer1, and if that's needed for MIBAM then I don't think I can use that on a PIC12F683 with this blinky code.
    One little obstacle and ... it can't be done???
    The CCP with Capture mode was just a simple way to get a wide range of constant periods without interrupts/reloading timers etc.
    Since it seems that you are only using the original 10mS periods, it doesn't really need that "Wide Range".
    10mS periods can be generated with another Timer, and you don't need the CCP module.
    In this example, I'm using Timer0 ...
    MIBAM uses Timer1.
    The EEPROM data labeled Brightness controls the intensity of each LED.
    I have 3 LED's with 330 ohms, and 2 LED's with 100 ohms. The existing values equalized their brightness (to my eyes).
    ;{PIC=12F683}
      __config  _INTOSCIO & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_OFF & _FCMEN_OFF
    DEFINE OSC 8
    OSCCON   = %01110000       ; 8MHz internal osc
    ANSEL = 0                  ; All Digital
    CMCON0 = 7
    OPTION_REG = %00000110     ; Timer0 prescaler 1:128
    TMR0IF   VAR INTCON.2      ; Timer0 Overflow bit
    TRISIO = 0                 ; all OUTPUT
    ;----[ MIBAM Setup ]--------------------------------------------------------
    wsave       var byte    $70     SYSTEM  ' Alternate save location for W
    ssave       VAR BYTE    BANK0   SYSTEM  ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM  ' location for PCLATH register
    BAM_COUNT CON 5                     ; How many BAM Pins are used?
    ;DEFINE BAM_INFO 1
    INCLUDE "MIBAM.pbp"                 ; Mirror Image BAM module
    Bright  VAR BYTE[BAM_COUNT]
    Br0     VAR Bright[0]
    Br1     VAR Bright[1]
    Br2     VAR Bright[2]
    Br4     VAR Bright[3]
    Br5     VAR Bright[4]
    BAM_LIST  macro                     ; Define PIN's to use for BAM
         BAM_PIN (GPIO,0, Br0)          ;   and the associated Duty variables
         BAM_PIN (GPIO,1, Br1)
         BAM_PIN (GPIO,2, Br2)
         BAM_PIN (GPIO,4, Br4)
         BAM_PIN (GPIO,5, Br5)
      BAM_INIT  BAM_LIST                ; Initialize the Pins
    ;----[Setup Blinky parameters]-----------------------------------
    DEFINE BLINKYFREQ 100                ; 10mS periods
    LEDcount    CON 5                    ; Number of LEDs on the PORT
    OnTimes     DATA  50, 22, 38,75, 5   ; default periods for each Output
    OffTimes    DATA 150, 45, 38,95,34
    Brightness  DATA 150,150,150,80,80
    #DEFINE USE_RANDOM_SEQUENCE     ; comment for contiuous Sequence
    #IFDEF USE_RANDOM_SEQUENCE
        RND     VAR WORD : RND = 13864
        MIN_ON  CON 50                  ; Minimum random ON time
        MAX_ON  CON 500                 ; Maximum random ON time
        MIN_OFF CON 50                  ; Minimum random OFF time
        MAX_OFF CON 500                 ; Maximum random OFF time
        RandPeriod VAR WORD[LEDcount]
        RandPeriods DATA WORD 1000, WORD 1250, WORD 1500, WORD 1750, WORD 2000
    #ENDIF
    ;----[Variables used only by Blinky]-----------------------------
    LoopLED    VAR WORD[LEDcount]
    OnTime     VAR WORD[LEDcount]
    OffTime    VAR WORD[LEDcount]
    x          VAR BYTE
    ;----[Initialize]------------------------------------------------
    FOR x = 0 to LEDcount - 1         ; load the periods from EEPROM
        READ OnTimes+x, OnTime(x)
        READ OffTimes+x, OffTime(x)
            READ RandPeriods+(x<<1), WORD RandPeriod(x)
        #ENDIF
    NEXT X
    ;----[Main Program Loop]----------------------------------------
        x = (x + 1) // LEDcount
        IF LoopLED(x) < OnTime(x) THEN
            READ Brightness + x, Bright(x)
            Bright(x) = 0
        LoopLED(x) = (LoopLED(x) + 1) // (OnTime(x) + OffTime(x))
            RandPeriod(x) = RandPeriod(x) - 1
            IF RandPeriod(x) = 0 THEN
                RANDOM RND
                OnTime(x) = (MAX_ON - MIN_ON)* RND.HighByte / 255 + MIN_ON
                OffTime(x)= (MAX_OFF - MIN_OFF)* RND.LowByte / 255 + MIN_OFF
        #ENDIF
        IF x != (LEDcount - 1) THEN Main
    Waiting: IF !TMR0IF THEN Waiting
        TMR0 = 99
        TMR0IF = 0
    GOTO Main
    And yes, I posted a MIBAM version 1.1 several years ago ... but it seems to be gone, or I just can't find it..
    Here's the latest version.
    CCPIF         VAR PIR1.5
    Thank you SOOOO much, Darrel!
  1. Single button function
    Last Post: - 4th April 2020, 18:33
  2. How to blink 8 LEDs at different rates- concurrently?
    By rmteo in forum mel PIC BASIC Pro
    Last Post: - 26th April 2010, 23:47
  3. single sided PCB
    By schu4647 in forum General
    Last Post: - 10th December 2008, 18:22
  4. Can't Blink 2 LEDs
    By dfort in forum mel PIC BASIC
    Last Post: - 5th March 2008, 22:36
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 14:55
