Dht11 - 16f877a
Results 1 to 15 of 15
Thread: Dht11 - 16f877a
    Mar 2014
    Default Re: Dht11 - 16f877a
    After reading related articles ... I did test the code below forum member
    Making use with: PIC16F877A, OSC: 20Mhz ...... I could not get it to work ..... if anyone has a solution to Picbasic Pro let's publish.
    http://www.picbasic.co.uk/forum/showthread.php?t=16196
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by Thanasis View Post
    Publish the code you tested please.
    Mar 2014
    Quote Originally Posted by EarlyBird2 View Post
    Hi, thank you for the response, code that tests are:
    @ errorlevel-306
    INCLUDE "modedefs.bas"
    Define OSC 20 ' 20MHz
    Define    ADC_BITS    10    ' Set number of bits in result
    Define    ADC_CLOCK    3    ' Set clock source (3=rc)
    Define    ADC_SAMPLEUS    50    ' Set sampling time in uS
    dht var byte[32]
    humidite var byte
    haut var byte
    bas var byte
    temp var byte
    x var byte
    dht11 var portb.0
    start:
    TRISB.0 = 0 '
    high  dht11
    pause 2000 ' wait 2 sec
    low dht11  : pause 18' send 20ms low
    high dht11  : pauseus 30 ' send 40us hi
    TRISB.0 = 0
    PulsIn PORTB.0, 1, haut
    if haut < 15 then goto start
    for x = 31 to 0 step-1
    PulsIn PORTB.0, 1, dht[x] ' 1
    next x
    For x = 31 to 0 step-1
    if dht[x] > 9 then
    dht[x]=1
    dht[x]=0
    next x
    humidite=dht[31]*128+dht[30]*64+dht[29]*32+dht[28]*16+dht[27]*8+dht[26]*4+dht[25]*2+dht[24]*1
    temp=dht[15]*128+ dht[14]*64+dht[13]*32+dht[12]*16+dht[11]*8+dht[10]*4+dht[9]*2+dht[8]*1
    SEROUT2 PORTC.5,16468,["Humidite = ",#humidite,"% ",10 ,13]
    SEROUT2 PORTC.5,16468,["Temperature = ",#temp,"C ",10 ,13]
    goto start
    Jan 2004
    Thessaloniki , GREECE
    Ηι! Τhanasis
    My friend if you want to use my program -as is- you have to use 4Mhz crystal. Ιf you use 20Mhz you have to change pulse measurements values as the resolution from 10us goes down to 2us with crystal at 20Mhz!
    Robotics , aeromodelling r/c , picprogramming , Retro Computer Collector
    Jan 2004
    @Thanasis ...if you want to keep 20Mhz try to change
    if pulse(x)>=2 and pulse(x)<=4 then p(x)=0 'if pulsewidth between 20 and 40uS then read as '0'
    if pulse(x)>=6 and pulse(x)<=8 then p(x)=1 'if pulsewidth between 60 and 80uS then read as '1'
    to this one
    if pulse(x)>=9 and pulse(x)<=21 then p(x)=0 'if pulsewidth between 20 and 40uS then read as '0'
    if pulse(x)>=29 and pulse(x)<=41 then p(x)=1 'if pulsewidth between 60 and 80uS then read as '1'
    and let me know
    Oct 2009
    Quote Originally Posted by bitmaniac View Post
    and let me know
    OK an old post I know, but I received a DHT11 today and had a play. This works fine on an 18F2520 running with a 20mhz crystal.
      __CONFIG    _CONFIG1H, _OSC_HS_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    ' LCD (20 x 4) set up
    DEFINE LCD_DREG  PORTB                  ' LCD Data port
    DEFINE LCD_DBIT  0                      ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB                  ' LCD Enable port
    DEFINE LCD_EBIT  5                      '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB                  ' LCD Register Select port
    DEFINE LCD_RSBIT 4                      '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4                      ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4                      ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000               ' Command delay time in us
    DEFINE LCD_DATAUS 50                    ' Data delay time in us
    ' Defines Statements
    DEFINE  OSC 20                          ' 18F4520 / 18F2520, 20mhz crystal
    ADCON1 = $0F
    clear
    'Analog and Comparator settings
    ADCON0 = %00000000                      'AD converter module disabled
    ADCON1 = %00001111                      'All Digital
    ADCON2 = %00000000
    CMCON = 7                               'Disable Comparators
    'Port and Register settings  (interrupts)
    TRISA  = %00010111
    TRISB  = %00000011
    T0CON  = %11000111
    T1CON = %00000001                               ; free-running, 1:1 prescaler
    TMR1H = %11111111
    TMR1L = %11111011
    LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250 ' Initialize LCD
    dht var byte[32]
    humidite var byte
    haut var byte
    bas var byte
    temp var byte
    x var byte
    dht11 var portA.5
    start:
    TRISA.5 = 0 '
    high dht11
    TRISA.5 = 0
    PulsIn PORTA.5, 1, haut
    PulsIn PORTA.5, 1, dht[x] ' 1
    next x
    if dht(x)>=9 and dht(x)<=21 then dht(x)=0 'if pulsewidth between 20 and 40uS then read as '0'
    if dht(x)>=29 and dht(x)<=41 then dht(x)=1 'if pulsewidth between 60 and 80uS then read as '1'
    next x
    lcdout  $FE,1
    lcdout  $FE,$C0,"Humidite = ",#humidite,"% "
    lcdout  $FE,$80,"Temperature = ",#temp,$DF,"C"
    goto start
    I've used Port A, pin 5 as the data line as I used an EasyPIC5 development board, and has the readings displayed on an 4 x 20 LCD rather than serial out.
  1. DHT11? Code/Schematics?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 12th June 2013, 10:35
  2. DHT11 Temperature/Humidity sensor
    By mircogomiero in forum mel PIC BASIC Pro
    Last Post: - 26th January 2013, 13:37
  3. 16F877a - Please Help
    By tarexpanda in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2007, 09:28
  4. 16f877a
    By alaaodeh in forum mel PIC BASIC Pro
    Last Post: - 7th February 2007, 00:38
  5. I need help with 16F877A
    By valerij in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 18:05
