Dht11 - 16f877a
Results 1 to 15 of 15
Thread: Dht11 - 16f877a
    Mar 2014
    Default Dht11 - 16f877a
    Picbasic code for DHT11 ?
    Mar 2014
    Default Re: Dht11 - 16f877a
    Hello, I want to measure the humidity in an incubator.
    I have the PIc 16F877A. Osc:20MHz.
    Does anyone know the code to DTH11 in pic basic pro.
    thank you
    Feb 2014
    I have not done it with PBP, but in another life I did it with PICAXE BASIC.
    After being queried, the DHT11 returns 41 Bits of Data. The first bit is an ACK and can be ignored. The next 16 bits are Humidity bits. ONly the first 8 of these bits are used wth the DHT-11. The next 16 bits are Temperature bits and again only the first 8 are used. The next 8 bits are the checksum.
    First Bit - Ignore or use for interrupt
    Bit 1 - 8 Humidity MSByte
    Bit 9 - 16 Hymidity LSByte (Only used with DHT22 - Ignore - All zeros
    Bit 17 - 24 Temperature MSByte
    Bit 25 - 32 Temperature LSByte (Only used with DHT22 - Ignore - All zeros
    Bit 33 = 40 Checksum - use if desired
    The protocol is such that each bit starts with a 50us low, followed by either a 27us high Pulse or a 70us high pulse,where 27us = "0" nd 70us = "1"
    These pulses can be read with pulsin and then tested with an IF statement to determine if a pulse is a 1 or a 0.
    There is only 50us between bits so the PIC only has 50us to read the bit & determine if a 1 or 0 before the next bit arrives.
    I am not going to write & debug the code for you if that is what you are looking for. However, below is a link to the Picaxe Basic code that may be helpful. You should not need the 555 timer or 74HC221 since PBP it is compiled code and runs much, much faster than Picaxe Basic interpreted code.
    http://www.picaxeforum.co.uk/showthr...ighlight=DHT11
    Mar 2014
    Unhappy Re: Dht11 - 16f877a
    Quote Originally Posted by cyberroth View Post
    Thank you very much, but I have not dealt with picaxe.
    This link explains how these sensors work
    http://ruijc.webnode.com/products/le...sensor-reader/
    Show us your code and doubts so we can help you.
    Rui
    Mar 2014
    Smile Re: Dht11 - 16f877a
    Informative article, thank you very much.
    Mar 2014
    After reading related articles ... I did test the code below forum member
    Making use with: PIC16F877A, OSC: 20Mhz ...... I could not get it to work ..... if anyone has a solution to Picbasic Pro let's publish.
    http://www.picbasic.co.uk/forum/showthread.php?t=16196
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by Thanasis View Post
    Publish the code you tested please.
    Mar 2014
    Quote Originally Posted by EarlyBird2 View Post
    Hi, thank you for the response, code that tests are:
    @ errorlevel-306
    INCLUDE "modedefs.bas"
    Define OSC 20 ' 20MHz
    Define    ADC_BITS    10    ' Set number of bits in result
    Define    ADC_CLOCK    3    ' Set clock source (3=rc)
    Define    ADC_SAMPLEUS    50    ' Set sampling time in uS
    dht var byte[32]
    humidite var byte
    haut var byte
    bas var byte
    temp var byte
    x var byte
    dht11 var portb.0
    start:
    TRISB.0 = 0 '
    high  dht11
    pause 2000 ' wait 2 sec
    low dht11  : pause 18' send 20ms low
    high dht11  : pauseus 30 ' send 40us hi
    TRISB.0 = 0
    PulsIn PORTB.0, 1, haut
    if haut < 15 then goto start
    for x = 31 to 0 step-1
    PulsIn PORTB.0, 1, dht[x] ' 1
    next x
    For x = 31 to 0 step-1
    if dht[x] > 9 then
    dht[x]=1
    dht[x]=0
    next x
    humidite=dht[31]*128+dht[30]*64+dht[29]*32+dht[28]*16+dht[27]*8+dht[26]*4+dht[25]*2+dht[24]*1
    temp=dht[15]*128+ dht[14]*64+dht[13]*32+dht[12]*16+dht[11]*8+dht[10]*4+dht[9]*2+dht[8]*1
    SEROUT2 PORTC.5,16468,["Humidite = ",#humidite,"% ",10 ,13]
    SEROUT2 PORTC.5,16468,["Temperature = ",#temp,"C ",10 ,13]
    goto start
    Jan 2004
    Thessaloniki , GREECE
    Ηι! Τhanasis
    My friend if you want to use my program -as is- you have to use 4Mhz crystal. Ιf you use 20Mhz you have to change pulse measurements values as the resolution from 10us goes down to 2us with crystal at 20Mhz!
    Robotics , aeromodelling r/c , picprogramming , Retro Computer Collector
    Jan 2004
    @Thanasis ...if you want to keep 20Mhz try to change
    if pulse(x)>=2 and pulse(x)<=4 then p(x)=0 'if pulsewidth between 20 and 40uS then read as '0'
    if pulse(x)>=6 and pulse(x)<=8 then p(x)=1 'if pulsewidth between 60 and 80uS then read as '1'
    to this one
    if pulse(x)>=9 and pulse(x)<=21 then p(x)=0 'if pulsewidth between 20 and 40uS then read as '0'
    if pulse(x)>=29 and pulse(x)<=41 then p(x)=1 'if pulsewidth between 60 and 80uS then read as '1'
    and let me know
    Oct 2014
    Below is code that will work to communicate with a DHT11 humidity sensor. The code is only for the humidity integer value. I don't measure the temperature or checksum, but this can easily be done by expanding the number of bits read.
    I found that certain routines, like the for/next that some people have used, probably don't run fast enough with a 4MHz clock. 20MHz works well. Using a different scheme I can read the DHT1 with a 4MHz clock.
    Also remember that pulsin doesn't measure in usec but rather in increments of microseconds depending on the clock speed. For example, at 4MHz each count on pulsin represents 10usec. So a count of 7 is actually 7 x 10 = 70usec. Likewise for 8MHz it is 8usec/count (7 x 8usec = 56usec) and at 20MHz is is 2usec/count (7 x 2usec = 14usec). Similarly, at 20MHz to read 70usec you need 70/2 = 35 counts, tho I'd look for >=30 counts to give some leeway.
    '*  Name    : DHT11_test.BAS        *
    '*  Author  : [select VIEW...EDITOR OPTIONS]                                                    *
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS]                          *
    '*          : All Rights Reserved        *
    '*  Date    : 3/28/2015        *
    '*  Version : 1.0        *
    '*  Notes   :        *
    '       PIC16F688
    '       Running at 20MHz but code also shown for 4MHz
    '       The configuration bits for the 16F688 I set in MPLAB manually.  Depedning on your processor you will have to
    '       determine and set your own bits.
    DEFINE  OSC 20                              '20 MHz clock frequency, need a fast clock for this to work best
    define  HSER_RCSTA 90h                   'enable the serial port receiver
    define  HSER_TXSTA 24h                   'set up the serial port, enable transmit for fast clock
    define  HSER_BAUD  9600                  'select the baud rate, run slow for the RF xmitter
    define  HSER_CLROERR 1                    'automatically clear the buffer overrun error
    i              var byte
    rhdata      var byte
    hum         var byte[8]
    humidity    var byte                          'humidity data byte
    humid       var byte
    dbit0 var byte
    dbit1 var byte
    dbit2 var byte
    dbit3 var byte
    dbit4 var byte
    dbit5 var byte
    dbit6 var byte
    dbit7 var byte
    togl    var     portc.0                       'not used except to add delay
    rhpin   var     portc.2                       'relativity sensor data bit
    TxD     var     portc.4                      'transmitted data
    RxD     var     portc.5                       'received data
    CMCON0 = %00000111                      'comparator off
    OSCCON = %01110110                      '   external 20  runs at 4 MHz internal clock
    ADCON0 = %10000000                       'ADC is disabled
    ANSEL  = %00000000                        'all digital
    TRISA  = %11111111                        'set up port A where 1 = input, 0 = output
    TRISC  = %11101011                        'set up port C where 1 = input, 0 = output
    '       This routine below works but needs a clock faster than 4MHz or the For/Next loop isn't fast enough.  This might be what is causing
    '       people consternation if they run at the common 4MHz clock.
    rhpin = 1                                             'initial condition
    pause 2000                                          'wait for the DHT to start up
    mainloop:
    trisc.2 = 0                                            'now set portc.2 (the DHT11 I/O pin) to output mode
    rhpin = 0                                              'set rhpin = portc.2 low
    pause 30                                              'wait 30 msec, must wait at least 18 msec for DHT11 to detect the signal
    trisc.2 = 1                                            'now make portb.2 an input. Since this line is pulled high with an R rhpin becomes high
                                                              'rhpin stays high 20-40usec until DHT pulls it low (actually ~13usec measured on scope)
    pulsin rhpin, 0, rhdata                             'execute an active low pulse measurement
                                                              'When the pulse goes back high it stays for 80 usec and goes low followed by data
    if rhdata > 50 then goto subloop              'if this takes way over 100 usec then error  (50 x 2usec/pulsin count = 100usec)
    rhdata = 0                                           'clear rhdata.  Since < 130 usec then get ready for data which will be next low to high
    pauseus 30                                          'delay makes sure the next pulse is a high going data pulse. Probably isn't needed.
    For i = 7 To 0 Step -1                              '8 bits (1..8)
        Pulsin rhpin, 1, rhdata                         ' receive pulses from sensor. 8 bits of integer part of data come first, ignore rest
        If rhdata >= 30 Then                          ' A "1" is defined for a bit width of 70usec, a "0" for bit width <30 usec.
                                                              'Remember, Pulsin counts increments depending on the clock frequency.  At 20MHz clock
                                                              ' frequency 30 rhdata counts =>  30 x 2usec = 60usec.  Rhdata >= 30 counts == data = 1
            hum[i] = 1                                    ' if >50 usec then logic 1
            Else
            hum[i] = 0                                    ' if not >=50 usec then is a 0
    next i
    pause 500                                           'not needed, was added during testing for readability of printout
    humidity = hum[7]*128+hum[6]*64+ hum[5]*32+hum[4]*16+ hum[3]*8+hum[2]*4+ hum[1]*2+hum[0]*1
    hserout ["A", 9, dec3 humidity, 13]          'serial output
    pause 2000                                          ' wait for the rest of the DHT timing
    '       The scheme below will work with a 4MHz clock, but the timing number to check dbit is shown for 20MHz.  For 4MHz compare dbit
    '       to 6 not 30.
    humid =  0
    trisc.2 = 0                                             'now set portc.2 to output
    trisc.2 = 1                                             'make portb.2 an input. Since this line is pulled high with an R rhpin becomes high
    toggle togl                                             'use to add some delay here.  Pauseus can't be < 24 usec at 4MHz clock
    luupy:
    if rhpin = 1 then goto luupy                      'wait for the DHT pin to go low then delay until the DHT is ready
    pauseus 130                                         'this delay ignores the first high going DHT pulse for initializaion and instead
                                                              ' moves ahead to wait for first dat abit high transition.
    pulsin rhpin, 1, dbit7                              'measure the pulsewidth of the DHT transmitted bit.  Low ~ 26-28usec, high ~70usec
    pulsin rhpin, 1, dbit6                              'measure the pulsewidth of the DHT transmitted bit.  Low ~ 26-28usec, high ~70usec
    pulsin rhpin, 1, dbit5                              'measure the pulsewidth of the DHT transmitted bit.  Low ~ 26-28usec, high ~70usec
    pulsin rhpin, 1, dbit4                              'measure the pulsewidth of the DHT transmitted bit.  Low ~ 26-28usec, high ~70usec
    pulsin rhpin, 1, dbit3                              'measure the pulsewidth of the DHT transmitted bit.  Low ~ 26-28usec, high ~70usec
    pulsin rhpin, 1, dbit2                              'measure the pulsewidth of the DHT transmitted bit.  Low ~ 26-28usec, high ~70usec
    pulsin rhpin, 1, dbit1                              'measure the pulsewidth of the DHT transmitted bit.  Low ~ 26-28usec, high ~70usec
    pulsin rhpin, 1, dbit0                              'measure the pulsewidth of the DHT transmitted bit.  Low ~ 26-28usec, high ~70usec
    hserout [13]                                        'the dbits can be printed if desired.  This is used to check the data.  Not needed.
    hserout ["C", 9, dec2 dbit6, 9, dec2 dbit5, 9, dec2 dbit4, 9, dec2 dbit3, 9, dec2 dbit2, 9, dec2 dbit1, 9, dec2 dbit0, 13]  'optional
                                                            '100% humidity = 0110 0100.  Don't need to add bit 7
    if dbit6 >= 30 then                                 'check each bit to see if greater than 60 usec (30 x 2usec).  If so the bit is a 1 so
        humid = 64                                       '  add its decimal equivalent to the humidity byte to get he rh value
    if dbit5 >= 30 then
        humid = humid + 32                              'NOTE:  if using 4MHz clock then test dbit for >=6  (6 x 10usec/pulsin count = 60 usec)
    if dbit4 >= 30 then
        humid = humid + 16
    if dbit3 >= 30 then
        humid = humid + 8
    if dbit2 >= 30 then
        humid = humid + 4
    if dbit1 >= 30 then
        humid = humid + 2
    if dbit0 >= 30 then
        humid = humid + 1                               'at this point the humid value is the humidity value
    hserout ["D", 9, dec3 humid, 13]                  'serial output
    hserout [13]                                            'linefeed for better output readability.  This isn't needed.
    pause 2000                                             'need to wait at least a second before repeating this data read sequence
    GoTo mainloop
    subloop:
    hserout ["Sensor not ready", 13]
    GoTo mainloop
    Aug 2003
    That’s about how I would have gone about it i.e. reading it with timing, and looking at the buffer later,
    It looks like a job for portb.0 interrupt so the code doesn’t have to spend most time waiting.
    It’s a shame there isn’t an option in PBP to carry the bit after rotating a byte like humid to wrap it in a loop.
    For the last part the timing doesn’t matter anymore. There’s more than one way to skin a cat.
    bb var byte ‘ bit index
    ii var byte ‘ counter
    dbit var byte[7] ‘ declare the array of bytes representing received bit times
    humid = 0 ‘ reset humid!
    bb = 1 ‘ set intial index value
    for ii = 0 to 6 ‘ address each bit
    if dbit[ii] > 29 then
    humid = humid + bb ‘ set the bit
    bb = bb + bb ‘ multiply index by 2 each step
    next ii
  1. DHT11? Code/Schematics?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 12th June 2013, 10:35
  2. DHT11 Temperature/Humidity sensor
    By mircogomiero in forum mel PIC BASIC Pro
    Last Post: - 26th January 2013, 13:37
  3. 16F877a - Please Help
    By tarexpanda in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2007, 09:28
  4. 16f877a
    By alaaodeh in forum mel PIC BASIC Pro
    Last Post: - 7th February 2007, 00:38
  5. I need help with 16F877A
    By valerij in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 18:05
