Decimal variable input with HSERIN command
Results 1 to 9 of 9
    Question Decimal variable input with HSERIN command
    Hello,
    I would like to do a simple thing with the HSERIN command :
    I send from my computer the ASCII chain "A1234". What I want it's to store the number (1234) in a variable (for instance, "vartest").
    Also, if I send from my computer the ASCII chain "B0005", I want to store the number (5) into an another variable (let's say "vartest2").
    I think it's quite simple, but I don't know how to handle that within a loop.
    Default Re: Decimal variable input with HSERIN command
    Hello,
    Perhaps something like this
    CMD VAR BYTE
    TestVar1 VAR BYTE
    TestVar2 VAR BYTE
    HSERIN [CMD]
    Select Case CMD
      Case "A"
        HSERIN[DEC4 TestVar1]
      Case "B"
        HSERIN[DEC4 TestVar2]
    END SELECT
    Thanks a lot Henrik, it works fine.
    The only problem I got is that HSERIN hangs my loop...
    Yes, that's the way it works....
    If the loop time is less that 2 "byte-times" you can poll the receive flag each time thru the loop and get the byte(s) from the receive buffer. If the loop time is longer you need to use interrupts.
    Hmm right now I just want to retreive a 4-number decimal value in my loop, and put it in the "ref" variable. I don't even need a letter, I just send raw numbers (in ASCII) , like "0586" from my computer.
    The problem is that in my program I use very precise and quick timing interrupts so it's a bit annoying.
    Maybe there is a way to send not an ASCII number but directly a hex number, so 0586 will be 24A... max value is 1200 (4B0, so I use 2 bytes)
    I have no idea how to use the RX buffer...
    Sep 2009
    You can add timeout label. Then it won't hang forever..
    HSERIN 10,TimeOut, [CMD]
    Select Case CMD
      Case "A"
        HSERIN  10,TimeOut,[DEC4 TestVar1]
      Case "B"
        HSERIN 10,TimeOut,[DEC4 TestVar2]
    END SELECT
    TimeOut:
    Select Case CMD
      Case "A"
      Case "B"
    END SELECT
    TimeOut:
    I can't use that, too program time-consuming, my main timing interrupt is refreshing every 92µs or so...
    This is totally untested but could serve as a starting point for a polled receive buffer. Short of this you need to use interrupts to receive the data in the background but I suspect that with your timing sensetive loop even that might cause to much problem.
    RC1IF VAR  PIR1.5   'Alias to Interrupt request bit for USART1, double check against datasheet.
    RxData VAR BYTE[5]
    Value VAR WORD
    ByteCount VAR BYTE
    TestVar1 VAR WORD
    TestVar2 VAR WORD
    ByteCount = 0   ' Reset buffer pointer.
    ' Main loop has to run faster than the bytes can arrive.
    If RC1IF THEN              ' Is there a byte in the receive buffer?
       HSERIN[RxData[ByteCount]]    ' Get it and put in the buffer array, RCIF will be cleared by the hardware.
       IF ByteCount = 4 THEN           ' Do we have 5 bytes yet?
          GOSUB ProcessFrame              'If so go process them...
          ByteCount = ByteCount + 1    ' If not, get ready for the next.
    Goto Main
    ProcessFrame:
       ByteCount = 0   ' Get ready for next frame.
       ' Now convert the next 4 bytes from ASCII to a numeric value.
       ' Could probably use ArrayRead here instead.
       Value = (RXData[1] - 48) * 1000
       Value = Value + ((RxData[2] - 48) * 100)
       Value = Value + ((RxData[3] - 48) * 10)
       Value = Value + (RxData[4] - 48)
       If RxData[0] = "A" THEN
         TestVar1 = Value
       If RxData[0] = "B" THEN
         TestVar2 = Value
    RxData VAR BYTE[5]
    Value VAR WORD
    ByteCount VAR BYTE
    TestVar1 VAR WORD
    TestVar2 VAR WORD
    Goto Main
    ProcessFrame:
         TestVar1 = Value
         TestVar2 = Value
    Oh thanks Henrik, I will see what I can do with this.
    But I think I'm gonna to use preselected values, less complicated to handle for the PIC...
  1. Recieve decimal with HSERIN
    By mel4853 in forum Serial
    Last Post: - 12th February 2012, 04:43
  2. HSERIN for variable length string
    Last Post: - 19th February 2010, 06:58
  3. variable + decimal
    Last Post: - 18th August 2009, 15:21
  4. Midi input, using hserin?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 26th June 2007, 13:18
  5. Convert a word variable to decimal
    Last Post: - 4th December 2004, 21:02
