This is totally untested but could serve as a starting point for a polled receive buffer. Short of this you need to use interrupts to receive the data in the background but I suspect that with your timing sensetive loop even that might cause to much problem.
/Henrik.Code:RC1IF VAR PIR1.5 'Alias to Interrupt request bit for USART1, double check against datasheet. RxData VAR BYTE[5] Value VAR WORD ByteCount VAR BYTE TestVar1 VAR WORD TestVar2 VAR WORD ByteCount = 0 ' Reset buffer pointer. Main: ' Main loop has to run faster than the bytes can arrive. If RC1IF THEN ' Is there a byte in the receive buffer? HSERIN[RxData[ByteCount]] ' Get it and put in the buffer array, RCIF will be cleared by the hardware. IF ByteCount = 4 THEN ' Do we have 5 bytes yet? GOSUB ProcessFrame 'If so go process them... ELSE ByteCount = ByteCount + 1 ' If not, get ready for the next. ENDIF ENDIF Goto Main ProcessFrame: ByteCount = 0 ' Get ready for next frame. ' Now convert the next 4 bytes from ASCII to a numeric value. ' Could probably use ArrayRead here instead. Value = (RXData[1] - 48) * 1000 Value = Value + ((RxData[2] - 48) * 100) Value = Value + ((RxData[3] - 48) * 10) Value = Value + (RxData[4] - 48) If RxData[0] = "A" THEN TestVar1 = Value ENDIF If RxData[0] = "B" THEN TestVar2 = Value ENDIF RETURN
