Possible to correct this error on board layout?
Results 1 to 7 of 7
    Dec 2012
    Tennessee
    Default Possible to correct this error on board layout?
    using a 16F688, my board got made with a led hooked to pin 4 instead of pin 2, it needs to light on pin high but since #4 is a in only.... future boards will be corrected but on the ones I have now there is no place to cut trace and jumper, what is available is to jumper pins 2 & 4. NOW I am not using MCLR and the program doesnt access pin 4 for anything. So...
    Can I send lows and highs out on pin 2 (shorted to pin 4) with #4 connected to LED+ ?
    code was already written for Pin 2 to LED.
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    Default Re: Possible to correct this error on board layout?
    I'd cut pin 4 and bridge a single-strand wire to pin 2 (the leads cut off a LED work nicely for short hops).
    Like the time I forgot the resistors on 2 columns of LEDs, d'uh! I cut the traces and bridged the resistors. Not elegant but it worked.
    Short answer; whatever works.
    Dec 2012
    Tennessee
    thanks, I cant cut pins, customer would notice. I am using a IC socket, so I was going to use circuit trace repair strips to jumper 2 & 4 under the socket. hidden by socket and chip. and its not really modifying the existing board, its just adding to it. this is a example circuit to show my work, I dont wanna show any errors if possible. I was just wondering what would happen if the MCLR pin, even though MCLR is disabled, would cause the code/program to do weird stuff.
    I dont want to turn it on till I know for sure as I only have 1 of this chip right now.
    Chris
    As long as MCLR is disabled I can't see any problems doing that once the circuit is in its normal operating mode.
    However, if you're programming the PIC in circuit it might be a problem since MCLR is also the Vpp pin which you now have jumpered to a "normal" pin. I don't know for sure if this would be a problem but I think it might.
    The internal protection diode on "the other pin" would clamp the voltage applied to the MCLR-pin by the programmer to just above Vdd which would prevent the PIC from entering programming mode. Using a diode as the "jumper" from RA5 to MCLR would protect RA5 from the high voltage applied to the MCLR-pin during programming. Or, perhaps, use Low Voltage Programming - I've never used it though.
    Obviosuly, if you're NOT programming the PIC in circuit then I can't see any obvious issues.
    May require some investigation/testing.
    Henrick,
    wdmagic said he is using a socket. I think that means he can do his programming off board. You are correct that ICSP would not work with the programming pin jumpered to another pin. I know from experience. A Pickit 2 programmer will stop and send an error message when attempting to program with jumpered pins.
    Quote Originally Posted by wdmagic View Post
    of course you can ... moreover if pin 4 never can turn into an output !
    I remember some Genuine Microchip reference designs using this feature ... ( especially the " 50 Mhz frequ. counter " using a 16F84 ... )
    Dec 2012
    Tennessee
    Ok thanks everyone, yes this circuit is programmed offboard. and the new boards dont have this issue just this one. thanks for the info.
    and thanks for the info on ICSP I forgot about that, its good Im not using that
    Chris
  1. PCB Layout Services
    By jmgelba in forum Adverts
    Last Post: - 4th July 2017, 15:09
  2. USB Electrical Layout?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 11th March 2013, 12:04
  3. PCB layout question
    By Christopher4187 in forum Off Topic
    Last Post: - 2nd January 2013, 01:06
  4. ERROR IN 200QL Development Board
    By sangaboy in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2012, 10:57
  5. PCB Layout Service
    By alex1202 in forum Adverts
    Last Post: - 23rd August 2007, 22:50
