I2C SDA not going to zero! 3.3V --> 1.14V !
Results 1 to 12 of 12
    Miami, Florida USA
    Default Re: I2C SDA not going to zero! 3.3V --> 1.14V !
    Start replacing components. Start with the pull-ups resistors, then the sensors and the PIC. If the problem persists then trash the board .
    Anonymous
    Sep 2009
    South Wales (UK)
    Many thanks for your reply. I'll try replacing the pull up res' but the sensors/PIC will be tricky. I don't think it's the res as the line is going high to 3.3V. As you rightly point out, there's only so long one should spend on something like this before trashing it. I just like to know the root cause of the issue. Because everything is surface mount, there's always the danger of trashing the board when heat gunning components. All part of the fun I guess...
    Mar 2006
    China
    Should? maybe
    Will? Only a deep dive into the datasheet can be sure of that.
    PIC18F26J53 har PPS (periphial pin select or how it is spelled, menaing you can re-route HW functions to different pins)
    So what PIN on the device and what PORT-id do you use?
    I would not bet that all pics always gets all registers set up exactly the same everytime.. so there might be a conflict that is because of a register setting.
    Before I start pulling components I would advise you to give us more details about the device setup and configuration...and PPS register settings
    Have you verified the value of the pullup resistor? Perhaps it's 10ohms instead of 10k or whatever it's supposed to be. The PIC can only pull so hard on the pin, if the pullup is too stiff it won't be able to get it all the way to Vss.
    I was going to suggest to lift the pin in question and measure directly on the pin but with a QFN that won't be easy. Make sure you measure from the pin in quesion to adjacent pins, perhaps there's a solder bridge under the chip.
    Sep 2009
    Put your pin to input, then measure current between ground and pin.
    IF current is few mA THEN pic is problem
    IF current is much bigger THEN
    Remove pull up
    Measure again
    IF any current exist THEN
    Problem is in sensor or pcb
    Remove sensor
    measure current.
    pcb have short
    END IF
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 19:53
  2. TMR0 Interferes with I2C GLCD
    By prstein in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2013, 07:56
  3. PIC as I2C Slave
    By Mainul in forum General
    Last Post: - 5th January 2013, 14:23
  4. 16F1847 Usart and I2C
    By Seahound1 in forum Serial
    Last Post: - 18th December 2012, 21:41
  5. Strange I2C and serial behaviour.......
    By jimbostlawrence in forum General
    Last Post: - 30th October 2012, 02:02
