LOOKUP2 not working?
Results 1 to 8 of 8
    Default Re: LOOKUP2 not working?
    MPLAB X for testing
    OH NOOOooooooooo......
    Just use the MPLAB that shipped with PBP and save yourself the headache.
    Dec 2010
    I honestly think I am doing that.
    But this is a very strange error... My next step is to try to recreate the fault without Darrel's code, but first I need to learn about LOOKUP2.
    LOOKUP2 is just the big brother of LOOKUP, so here are a couple of examples.
    http://melabs.com/samples/PBP-mixed/lookup.htm
    And this will place the value of a string into a variable
    BUFFERQ  VAR BYTE[13]
    B0          VAR BYTE
    B1          VAR BYTE
    FOR B0 = 0 TO 12
        LOOKUP B0,[" MACKRACKIT",10,13],B1
        BUFFERQ(B0) = B1
        NEXT B0
    Dec 2010
    I have now noticed a second error in my posting - the undefined Symbol is actually "LOOK2". (NOT LOOKUP2). I really need less coffee, I think.
    I did a search of my code, and Darrel's code, and there is no LOOK2.
    I removed the include for Darrel's code and the problem goes away; however if I add a statement containing "LOOKUP2", even if it's not executed, the error returns, so it's a library problem, and not a coding problem, It seems that somewhere in the compile process, "LOOKUP2" gets changed to "LOOK2" and bombs.
    The search continues...
    Dec 2010
    Well, after poking a bit, I realized I had modified this library about a year ago to support "LCD Any Pin". I put the original back and that solved the problem. I'll have to do some digging to figure out what mistake I made, but it's clearly my issue so thanks for thinking about it and I'll take it from here. I have not noticed it in all this time, likely because I've been using 18 series parts, which don't use this lib.
    Thanks also to Darrel for the gentle hint around the place to start looking.
  1. SERIN Not Working, SEROUT Working
    By cc1984 in forum Serial
    Last Post: - 26th October 2010, 20:16
  2. LOOKUP2 please help
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 00:13
  3. lookup2?
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 28th February 2009, 13:26
  4. Lookup2 & Lookdown2
    By saladlee in forum Serial
    Last Post: - 4th February 2008, 21:41
  5. Lcd Not Working..
    Last Post: - 15th June 2005, 11:36
