Control de puertos PIC16F877A / Port Control PIC16F877A
Results 1 to 10 of 10
    Aug 2012
    Comodoro Rivadavia - Patagonia Argentina
    Default Re: Control de puertos PIC16F877A / Port Control PIC16F877A
    aaaaaaaaaa but archangel opened my eyes a little file that rose ( machine tach.txt) ... What I'm going to study a little to see if it is what I play and commented glance
    Quote Originally Posted by martintorres View Post
    I wouldn't put too much on what you found in my machine tac, it's too slow for automotive I think, you would want a timer bases counter, given the sample rate of an auto ignition. As far as the question you asked : PortB = %11111111 should set all PortB to high state. I prefer binary as I do not get confused, you could use decimal or hex as well i e . . . portb = FF or portB = 255 .
    If you use the LM3914 as you mentioned you will have an analog tach with a digital display, with all the advantages and disadvantages of both.
    Sep 2010
    Las Vegas, NV
    If using hex don't you need the $ sign? For example Portb = $FF
    Quote Originally Posted by AvionicsMaster1 View Post
    Yup, oversight, my bad. $FF
