SERIN2 = ok, HSERIN = no!
Results 1 to 29 of 29
    SWITZERLAND (french speaking)
    Default Re: SERIN2 = ok, HSERIN = no!
    Yup! Adding "DEFINE HSER_CLROERR 1" has solved the "hanging" problem.
    As I previously set the RCSTA.1 = 1, I wrongly thought this would handle the automatic overrun. I should have noticed the "Read-Only" flag on this bit in the datasheet.
    BTW, what exactly does "DEFINE HSER_CLROERR" 1 do? Where can I find information about what other DEFINE commands do?
    NB: my apologise Demon; I missed your advice for a pull-up in an early post
    Final working code is HSERIN-EUART-test_18F2420.zip
    Roger
    Final working code is Attachment 6366
    From the book "As the hardware buffer only has 2 byte input buffer, it can easily overflow if charactors are not read from it often enough. When this happens, the USART stops accepting new characters and needs to be reset. This error can be reset by toggling the CREN bit in the RCSTA register. A DEFINE can be used to automatically clear this error. However you will not know that an error has occured and characters may have been lost."
    Quote Originally Posted by Archangel View Post
    ...However you will not know that an error has occured and characters may have been lost.
    Ah, and this must be where a checksum comes it to play?
    ...Where can I find information about what other DEFINE commands do?
    Can someone please tell?
    Roger
    Believe it or not but they are actually listed in the manual. I know - who would've thought... ;-)
    In my 2.60 book they are in Appendix B and in the PBP3 book they are in section 8.7
    And, DEFINE is not a command in that it does not execute at runtime. It's a compiler directive that tells the compiler how and what code to generate. This means that you can not use DEFINE to change a setting (like for example the parity for the USART) at runtime.
    Thanks ;-)
    Roger
