RFM12 with picbasic_pro
Results 1 to 18 of 18
    Feb 2010
    USA, New England
    Default Re: RFM12 with picbasic_pro
    Ambrogio and lyoung298,
    Glad you like it. I'm pretty happy with the RFM22 and I'm glad others are using them too.
    Best Regards,
    Paul
    Jun 2008
    Varese , Italy
    Paul,
    just a question: what is the max operative range of those RFm22 devices ?
    I do have a couple of RFM12b but one is broken ( shipment problem ! ) so at the moment i can not test them.
    Ambrogio
    Quote Originally Posted by prstein View Post
    Best Regards,
    Paul
    Sep 2011
    The datasheet for the RFM22 reads sensitivity of -121dBm. So line of sight range of 3000ft should be possible. Similar modules from Linx has a typical receiver sensitivity of -112 dBm. Baud rate also can effect range. Higher baud rates normally decrease range.
    Feb 2010
    USA, New England
    The choice of antenna makes a huge difference as well. My RFM22s are 916MHz and I'm using a tiny little antenna (here). I've only tested to about 30 meters but under awful conditions (through trees and several walls). That was also after setting the transmit power low enough to comply with the U.S. FCC requirements.
    Best Regards,
    Paul
