RFM12 with picbasic_pro
Results 1 to 18 of 18
    Jun 2008
    Varese , Italy
    Default Re: RFM12 with picbasic_pro
    Thanks very much for having reply to my mail,
    Yes, it will be very useful to me if you can post your code.
    My e_mail is : [email protected]
    Best regards,
    Ambrogio
    Quote Originally Posted by prstein View Post
    Hello Ambrogio,
    I've worked with the RFM22B, which I believe is similar. I can post some demo code if you think it is similar enough.
    Best Regards,
    Paul
    Feb 2010
    USA, New England
    Quote Originally Posted by iw2fvo View Post
    Here you go. Please let us know how it works out.
    '*  Name    : Transceiver.pbp                                   *
    '*  Author  : Paul R. Steinmeyer                                *
    '*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/02/2010                                        *
    '*  Notes   : Target uC:  16F88, using 18F1320                  *
    '*          : Interface with RFM22                              *
    '*          : Waits in RX Mode unless button is pressed, at     *
    '*          : which point it transmits the packet and returns   *
    '*          : to RX mode.                                       *
    '*          : At any valid packet reception the LED blinks      *
    '*          : Un-rem lines with SEROUT2 for debugging serial    *
    '*          : transmissions at 9600 baud                        *
    ' # Name          |I/O| Alias       | Var    | Description
    ' 1 RA0/AN0       |D 1| nButton     |        | Goes low when button is pressed
    ' 2 RA1/AN1       |D 0| LED         |        | LED on when high
    ' 3 RA4/T0CKI     |D 1|             |        | N/C
    ' 4 RA5/MCLR      |D 1|             |        | N/C
    ' 5 Vss           |   |             |        | Ground
    ' 6 RA2/AN2       |D 1|             |        | N/C
    ' 7 RA3/AN3       |D 1|             |        | N/C
    ' 8 RB0/AN4       |D 1| nIRQ        |        | Goes low on interrupt from RFM
    ' 9 RB1/TX        |  0| nSel        |        | Bring low to select RFM
    '10 RB4/RX        |D 1|SDO          |        | Input from RFM output
    '11 RB5/SS        |D 0|TX_ANT       |        | Selector for TX Mode
    '12 RB6/T1CKI     |D 0|RX_ANT       |        | Selector for RX Mode
    '13 RB7           |D 0|             |        | N/C
    '14 Vdd           |   |             |        | +3V
    '15 RA6/OSC2      |D 1|             |        | N/C
    '16 RA7/OSC1      |D 1|             |        | N/C
    '17 RB2           |D 0|SCK          |        | Clock signal to RFM
    '18 RB3           |D 0|SDI          |        | Output to RFM input
    'Be sure to REM out the line "__CONFIG    _CONFIG1H, _XT_OSC_1H" in the \PBP\18F1320.INC file!
    '@ __CONFIG    _CONFIG1H, _INTIO2_OSC_1H
    '@ __CONFIG  _CONFIG3H, _MCLRE_OFF_3H
    ' DEFINES
    ' CONSTANTS
    PacketSize    CON 3
    ' Hardware Setup
    'All Ports Digital
    'un-rem this line for 18F1320...
    ADCON1 = $7F
    '...or un-rem these two for 16F88
    'ANSEL = 0
    'CMCON = 7
    OSCCON = 100000    '4MHz
    PORTA = 110111
    TRISA = 000001
    PORTB = 000010
    TRISB = 010001
    ' ALIASES
    nButton VAR PORTA.0
    LED     VAR PORTA.1
    SDO     VAR PORTB.4
    SDI     VAR PORTB.3
    SCK     VAR PORTB.2
    nSEL     VAR PORTB.1
    nIRQ     VAR PORTB.0
    TX_ANT     VAR PORTB.5
    RX_ANT     VAR PORTB.6
    ' VARIABLES
    nAddress    VAR BYTE
    nOutData    VAR BYTE
    nInData        VAR BYTE
    nStatus1    VAR BYTE
    nStatus2    VAR BYTE
    i            var byte
    anRxBuf        var byte[35] 'at least 2x the packet length
    anTxBuf        VAR BYTE[PacketSize]
    nCheckSum    var byte
    ' Initialize Variables
    nSEL = 1
    LED = 1
    PAUSE 1000
    LED = 0
    for i = 0 to 34
      anRxBuf[i] = $ff
    next i
    for i = 0 to PacketSize-1
      anTxBuf[i] = $30+i
    next i
    'Initialize the RFM22 Registers
    GOSUB InitRFM
    'Set up to receive data
    GOSUB To_RX_Mode
    'Jump to the main program loop
    GOTO MainLoop
    ' HELPER FUNCTIONS
    'Write a single byte to the RFM22
    SPI_Out:
      nSel = 0        'Select the RFM22
      PAUSEUS 50  'Give it a moment
      nAddress.7 = 1    'Tell the RFM22 we're doing a WRITE transaction
      SHIFTOUT SDI,SCK,1,[nAddress,nOutData]  'Stuff the datum into the RFM22
      nSel = 1  'De-select the RFM22
      PAUSEUS 100  'Unnecessary?
    'Read a single byte from the RFM22
    SPI_In:
      nAddress.7 = 0    'Tell the RFM22 we're doing a READ transaction
      SHIFTOUT SDI,SCK,1,[nAddress]  'First, write the ADDRESS we want to read from
      SHIFTIN SDO,SCK,0,[nInData]    'Second, take in the datum
    'Send the data contained in the anTXBuf array
    To_TX_Mode:
      'SEROUT2 PORTA.3,49236,["Entering RX Mode...",13,10]
      NAddress = $07 : noutData = $01 : GOSUB SPI_Out  'Set READY mode in RFM22
      RX_ANT = 0 'Configure for transmission
      TX_ANT = 1 'Configure for transmission
      Pause 50   'Give it a moment
      nAddress = $08 : noutData = $03 : GOSUB SPI_Out   'Tell it we want to reset the FIFO
      nAddress = $08 : noutData = $00 : GOSUB SPI_Out   'Reset the FIFO
      nAddress = $34 : noutData = 64 : GOSUB SPI_Out    'Set the preamble = 64nibble
      nAddress = $3E : noutData = PacketSize : GOSUB SPI_Out     'Set the packet length
      nCheckSum = 0
      for i = 0 to PacketSize-2
        nAddress = $7F : noutData = anTXBuf[i] : GOSUB SPI_Out    'Write the data to the TX FIFO
        nCheckSum = nChecksum + antxbuf[i]                        'Calculate the checksum
      next i
      nAddress = $7F : noutData = nCheckSum : GOSUB SPI_Out       'Write the checksum as the last byte
      nAddress = $05 : noutData = $04 : GOSUB SPI_Out             'Enable the packet sent interrupt
      nAddress = $03 : GOSUB SPI_In : nStatus1 = nInData   'Clear interrupts part 1
      nAddress = $04 : GOSUB SPI_In : nStatus2 = nInData   'Clear interrupts part 2
      LED = 1  'Turn on LED immediatly prior to start of transmission
      nAddress = $07 : noutData = 9 : GOSUB SPI_Out  'Tell the RFM22 to start the transmission
      'wait for the interrupt to tell us the transmission is complete
      TXWait:
      if nirq = 1 then
          goto TXWait
      pause 100  'This pause exists only to make the LED blink long enough to see
      LED = 0    'turn off the LED
    'Set up RFM22 hardware to receive mode
    To_RX_Mode:
      RX_ANT = 0 'Turn off receiver
      TX_ANT = 0 'Turn off transmitter
      nAddress = $07 : noutData = $01 : GOSUB SPI_Out    'Set READY mode in RFM22
      pause 50    'Give it a moment
      RX_ANT = 1  'Configure for reception
      TX_ANT = 0  'Configure for reception
      GOSUB RX_Reset  'Configure RFM22 registers for reception
      PAUSEUS 10   'Give it a moment
    RX_Reset:
      'Set READY Mode (Xtal is ON)
      'Set the RX FIFO Almost Full interrupt level to 17 (same as the packet size)
      nAddress = $7E : noutData = PacketSize : GOSUB SPI_Out
      'Clear the RX FIFO and disable multi-packet
      'Second write to complete clearing FIFO buffers
      'READY mode set, RX on in Manual Receiver Mode
      nAddress = $07 : noutData = $05 : GOSUB SPI_Out
      'Disable extra/oddball interrupts
      nAddress = $06 : noutData = 000000 : GOSUB SPI_Out
      'Valid Packet Received interrupt is enabled
      nAddress = $05 : noutData = $02 : GOSUB SPI_Out
      'Read the interrupt registers (in order to clear them)
    'Initial configuration of RFM22 Registers
    InitRFM:
      'Disable Interrupts
      nAddress = $06 : noutData = $00 : GOSUB SPI_Out
      'Set READY mode
      nAddress = $07 : nOutData = $01    : GOSUB SPI_Out
      'cap = 12.5 pF
      nAddress = $09 : nOutData = $7F : GOSUB SPI_Out
      'Clk output is 2 MHz
      nAddress = $0A : nOutData = $05 : GOSUB SPI_Out
      'GPIO0 is RX data output
      nAddress = $0B : nOutData = $F4    : GOSUB SPI_Out
      'GPIO1 Tx/Rx data clk output
      nAddress = $0C : nOutData = $EF    : GOSUB SPI_Out
      'GPIO2 for MCLK output
      nAddress = $0D : nOutData = $00 : GOSUB SPI_Out
      'GPIO port use default value
      nAddress = $0E : nOutData = $00 : GOSUB SPI_Out
      'no ADC used
      nAddress = $0F : nOutData = $70 : GOSUB SPI_Out
      nAddress = $10 : nOutData = $00 : GOSUB SPI_Out
      'no temp sensor used
      nAddress = $12 : nOutData = $00 : GOSUB SPI_Out
      nAddress = $13 : nOutData = $00 : GOSUB SPI_Out
      'no manchester code, no data whiting, data rate < 30Kbps
      nAddress = $70 : nOutData = $20 : GOSUB SPI_Out
      'IF filter bandwidth
      nAddress = $1C : nOutData = $1D : GOSUB SPI_Out
      'AFC loop
      nAddress = $1D : nOutData = $40 : GOSUB SPI_Out
      'Clock Recovery
      nAddress = $20 : nOutData = $A1    : GOSUB SPI_Out
      nAddress = $21 : nOutData = $20    : GOSUB SPI_Out
      nAddress = $22 : nOutData = $4E    : GOSUB SPI_Out
      nAddress = $23 : nOutData = $A5    : GOSUB SPI_Out
      'Clock Recovery timing
      nAddress = $24 : nOutData = $00    : GOSUB SPI_Out
      nAddress = $25 : nOutData = $0A    : GOSUB SPI_Out
      'zero OOK counter
      nAddress = $2C : nOutData = $00 : GOSUB SPI_Out
      nAddress = $2D : nOutData = $00 : GOSUB SPI_Out
      'slicer peak hold
      nAddress = $2E : nOutData = $00 : GOSUB SPI_Out
      'TX data rate (4800 baud)
      nAddress = $6E : nOutData = $27 : GOSUB SPI_Out
      nAddress = $6F : nOutData = $52    : GOSUB SPI_Out
      'Data Access Control
      nAddress = $30 : nOutData = $8C : GOSUB SPI_Out
      'Header Control
      nAddress = $32 : nOutData = $FF : GOSUB SPI_Out
      ' header 3, 2, 1,0 used for head length, fixed packet length, synchronize word length 3, 2,
      nAddress = $33 : nOutData = $42 : GOSUB SPI_Out
      '64 nibble = 32byte preamble
      nAddress = $34 : nOutData = 64 : GOSUB SPI_Out
      '0x35 need to detect 20bit preamble
      nAddress = $35 : nOutData = $20 : GOSUB SPI_Out
      ' synchronize word
      nAddress = $36 : nOutData = $2D : GOSUB SPI_Out
      nAddress = $37 : nOutData = $D4 : GOSUB SPI_Out
      nAddress = $38 : nOutData = $00 : GOSUB SPI_Out
      nAddress = $39 : nOutData = $00 : GOSUB SPI_Out
      ' set tx header
      nAddress = $3A : nOutData = "h" : GOSUB SPI_Out
      nAddress = $3B : nOutData = "o" : GOSUB SPI_Out
      nAddress = $3C : nOutData = "p" : GOSUB SPI_Out
      nAddress = $3D : nOutData = "e" : GOSUB SPI_Out
      ' total tx 17 byte
      nAddress = $3E : nOutData = PacketSize : GOSUB SPI_Out
      ' set rx header
      nAddress = $3F : nOutData = "h" : GOSUB SPI_Out
      nAddress = $40 : nOutData = "o" : GOSUB SPI_Out
      nAddress = $41 : nOutData = "p" : GOSUB SPI_Out
      nAddress = $42 : nOutData = "e" : GOSUB SPI_Out
      ' all the bits to be checked
      nAddress = $43 : nOutData = $FF : GOSUB SPI_Out
      nAddress = $44 : nOutData = $FF : GOSUB SPI_Out
      nAddress = $45 : nOutData = $FF : GOSUB SPI_Out
      nAddress = $46 : nOutData = $FF : GOSUB SPI_Out
      'Reserved
      nAddress = $56 : nOutData = $01 : GOSUB SPI_Out
      ' tx power to Max
      nAddress = $6D : nOutData = $07    : GOSUB SPI_Out
      ' no frequency hopping
      nAddress = $79 : nOutData = $00 : GOSUB SPI_Out
      nAddress = $7A : nOutData = $00 : GOSUB SPI_Out
      ' Gfsk, fd[8] =0, no invert for Tx/Rx data, fifo mode, txclk -->gpio
      nAddress = $71 : nOutData = $22    : GOSUB SPI_Out
      ' frequency deviation setting to 35k = 56*625
      nAddress = $72 : nOutData = $38    : GOSUB SPI_Out
      ' no frequency offset
      nAddress = $73 : nOutData = $00 : GOSUB SPI_Out
      nAddress = $74 : nOutData = $00 : GOSUB SPI_Out
      ' frequency set to 434MHz
      nAddress = $75 : nOutData = $53    : GOSUB SPI_Out
      nAddress = $76 : nOutData = $64    : GOSUB SPI_Out
      nAddress = $77 : nOutData = $00    : GOSUB SPI_Out
      'NOTE:
      'The following 5 registers are listed as RESERVED in the RFM22B v1.1
      'datasheet.  Try remming them if problems are experienced
      nAddress = $5A : nOutData = $7F : GOSUB SPI_Out
      nAddress = $59 : nOutData = $40 : GOSUB SPI_Out
      nAddress = $58 : nOutData = $80 : GOSUB SPI_Out
      nAddress = $6A : nOutData = $0B : GOSUB SPI_Out
      nAddress = $68 : nOutData = $04 : GOSUB SPI_Out
      'Clock Recovery Gearshift Override
      nAddress = $1F : nOutData = $03 : GOSUB SPI_Out
      PAUSEUS 1000 'Let the settings settle
    ' END OF HELPER FUNCTIONS, BEGIN MAIN PROGRAM LOOP
    MainLoop:
      'nIRQ Pin Indicates that we have received a packet
      if nIRQ = 0 then 'Packet received
        'Clear the interrupt
        'Read in the data
          nAddress = $7F : GOSUB SPI_In : anRxBuf[i] = nInData
        next i
        nSel = 1 'unncecessary?
        'Calculate the checksum...
        nCheckSum = 0
          nCheckSum = nCheckSum + anRxBuf[i]
          'SEROUT2 PORTA.3,49236,[Ihex2 anRxBuf[i]," "]
          anRxBuf[i] = 0
        next i
        'SEROUT2 PORTA.3,49236,[13,10,"ChkSum=",Ihex2 anRxBuf[i],13,10]
        'Verify that the calculate checksum matches the last byte in the packet
        if  nChecksum = anRxBuf[PacketSize-1] then
          LED = 1
          'SEROUT2 PORTA.3,49236,["ChkSum MATCH!",13,10]
          PAUSE 500
          LED = 0;
        GOSUB rx_reset; // rx reset
      'Check for button press
      if nButton = 0 then 'the button is pressed...
        'SEROUT2 PORTA.3,49236,["Xmitting",13,10]
        'Here would be a good place to load the relevant data into anTxBuf
        gosub To_TX_Mode
        'and return back to RX_Mode
        GOSUB To_RX_Mode
    GOTO MainLoop
    Best Regards,
    Paul
    Jun 2008
    Varese , Italy
    Thanks a lot Paul: it is great !
    Best regards,
    Ambrogio
    Iw2FVO
    Sep 2011
    Thanks Paul. I was looking for something similar to this.
    Feb 2010
    USA, New England
    Ambrogio and lyoung298,
    Glad you like it. I'm pretty happy with the RFM22 and I'm glad others are using them too.
    Best Regards,
    Paul
    Jun 2008
    Varese , Italy
    Paul,
    just a question: what is the max operative range of those RFm22 devices ?
    I do have a couple of RFM12b but one is broken ( shipment problem ! ) so at the moment i can not test them.
    Ambrogio
    Best Regards,
    Paul
    Sep 2011
    The datasheet for the RFM22 reads sensitivity of -121dBm. So line of sight range of 3000ft should be possible. Similar modules from Linx has a typical receiver sensitivity of -112 dBm. Baud rate also can effect range. Higher baud rates normally decrease range.
    Oct 2011
    Hi Paul
    I Have bought some RFM22B's and connected up to a 16F883 Pic and connected up as per your setup and code.
    Everything seems to be working until I press the TX button It does transmit but, stays in that mode with Led On.
    It gets stuck in To_TX_Mode: at the TXWait: Loop, I have read the Serout2 to my Pc too see if the packet is being sent.etc.
    I have tried changing address $05 to $02 but, I seem to get stuck here.
    Could you Please tell me if you have any suggestions as to why I am getting stuck?
    Thanks In advance!
    Kind Regard
    Craig
    Feb 2010
    USA, New England
    Hello Craig,
    Have you made any changes to the code? Perhaps added an interrupt that might be pulling it out? If you have made some changes please post your code, it might be somewhat easier than guessing...
    Just to test something, try replacing
    TXWait:
      if nirq = 1 then
          goto TXWait
    with "pause 100" or something like that.
    Also, check with a meter or scope that nIrq actually goes low.
    Best Regards,
    Paul
    Oct 2011
    Hi Paul
    Thanks for the reply, I have used the code exactly like you have written it without any extra interupts etc.
    What I did was remove the TXWait and just put a PAUSE 100 in then it does transmit.
    What is funny is if I put a meter on the nIRQ pin then it keeps sending info on the SEROUT2 and the TX Led remains ON,
    If I take the meter off the pin then it settles down ant the TX Led switches off. What I did was wire an extra LED onto a unused pin on the PIC and then
    monitor this in relation to the nIRQ pin when it goes High or Low.
    I read no voltage on the nIRQ pin but the extra led stays on so there is something weird with this pin?
    Maybe I should rebuild the PCB onto a Veraboard instead on leaving it all on a Bread Board as there seems
    to be a lot of capacitance floating around, I suppose that this could cause a problem on the nIRQ pin?
    What can you suggest Paul?
    Kind Regards
    Craig
    Feb 2010
    USA, New England
    Hello Craig,
    I suspect you've found the problem--capacitance (or other leakage) in the setup. Good job! I think you'll do better on veraboard... For a quick fix try putting relatively high value pull-down resistors (~10k to 1M) on the nIrq and LED pins. From what you describe something is causing one of those pins to float high.
    Best Regards,
    Paul
    Oct 2011
    Cool Re: RFM12 with picbasic_pro
    Thanks Paul
    I will rebuild and see how it goes.
    Kind Regards
    Craig
