bootloader does not work..
Results 1 to 23 of 23
    Default Re: bootloader does not work..
    Hi bmmilk,
    i dont have schematic of my pic setup.but it works well when i use a programmer to program instead of trying to build a bootloader.
    So, when you program it with a programmer, you can get you code to work with your setup?
    I have used the Tiny Bootloader on the same chip, with a RS232 to USB converter and had it work for me. It sounds like you are doing everything else right, so I suspect the wiring. How about a picture of your setup?
    http://www.scalerobotics.com
    Oct 2011
    Quote Originally Posted by ScaleRobotics View Post
    Hi bmmilk,
    Hi bmmilk,
    @ScaleRobotics:
    ya when i program with an external programmer my code can function with the hardware.I hv posted 4 pictures of my connection of max232 and also pic16f877a.i doubt that if my connection is correct is it my usb serial converter spoil or cant work.i dont know.
    here are the pictures,feel free to help me check ya...thank you a lot^^
    http://bmmilk.blogspot.com/2011/10/blog-post_15.html
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 17:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 22:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 17:51
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 12:03
