bootloader does not work..
Results 1 to 23 of 23
    Jan 2007
    Brazil
    sorry.. again, ok?
    i'm using a pic16f88, with an external crystal of 20MHz. The RX ad TX pins are connected throught RS232. This one is connected at COM1 of my windows XP. I cant get it to work. Could you help me?
    as i wrote on the first topic, pic is sending some data.. so i think the problem is in the code..
    The code is attached..
    Thanks..
    Dec 2005
    How are TX & RX connected? PC TX -> PIC RX and vice versa.
    Jan 2007
    Brazil
    i've solved that problem.. and now i'm getting something new..:
    Connected to \\.\COM1 at 115200
    HEX: 5 min old, INHX8M,16Fcode+cfg, total=136 bytes.
    Searching for PIC ...
    Found:16F 88
    WARNING: PCLATH not initialised before GOTO! ... sucessfully repaired.,
    Could not write
    ERROR!
    does anyone have the same error?
    thanks..
    Jan 2007
    Brazil
    thanks mister_e..
    i have already read this post but nothing helpfull..
    dont know what to do to make it to work...
    thanks again..
    Oct 2010
    How did you solved the problem of "pic sending unknown data: "K" <> F0h=ð". I have the same problem with tiny bootloader. Plz plz plz help me. I am using PIC 16F877A with 20Mz crystal. Tx and Rx connected to COM1(RS232) of my PC running Windows XP. I got the bootloader code from tiny bootloader, did some modification on processor type, XTAL frequency and Baud rate. I am using MPASM Assembler.
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
