Temprature conversion --- C to F
Results 1 to 14 of 14
    California, USA
    Default Re: Temprature conversion --- C to F
    Well, I got lost in a world of fire wood this week and haven't had a chance to look through all these great suggestions. But THANKS to everyone for the input so far. Hopefully in the next day or 2 I'll get a chance to try again.
    Norm, you're killing me with those "Longs".... that's going to be tough to implement with my 16F887!
    Quote Originally Posted by Byte_Butcher View Post
    No longs, 2 decimals. no round.
    Enter C value 124.56 as 12456
    Norm
      C VAR WORD
      F VAR WORD
      iSIGN VAR BIT
      GOTO MAIN
      subC_TO_F:
        DISABLE ' Necessary if On Interrupt used
        F = C * 9
        F = DIV32 5
        ENABLE ' Necessary if On Interrupt used
        IF iSIGN = 1 THEN 'if the sign bit is "1" is minus C
          IF F > 3200 THEN
            F = F - 3200
            SEROUT2 sSEROUT_PIN,cBAUD,[" -",DEC C/100,".",DEC2 C," C  = -",DEC F/100,".",DEC2 F," F",13]
            F = 3200 - F
            SEROUT2 sSEROUT_PIN,cBAUD,[" -",DEC C/100,".",DEC2 C," C  = ",DEC F/100,".",DEC2 F," F",13]
          F = F + 3200
          SEROUT2 sSEROUT_PIN,cBAUD,["  ",DEC C/100,".",DEC2 C," C  = ",DEC F/100,".",DEC2 F," F",13]
      MAIN:
      SEROUT2 sSEROUT_PIN,cBAUD,[" ",13]
      SEROUT2 sSEROUT_PIN,cBAUD,["START",13]
      iSIGN = 1
      FOR C = 100 TO 0 STEP -1 '-1.00 C TO 0 C
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0
      FOR C = 0 TO 100 STEP 1 '0 C TO 1.00 C
       GOSUB subC_TO_F
      NEXT
      iSIGN = 1
      FOR C = 5500 TO 0 STEP -100 '-55.00 C TO 0 C  'DO STEP -1 FOR COMPLETE BUT FOREVER
       GOSUB subC_TO_F
      NEXT
      '12500 IS 125.00 * 100 TO HOLD 2 DECIMAL PLACES
      iSIGN = 0
      FOR C = 0 TO 12500 STEP 100 '0 C TO 125.00 C  'DO STEP 1 FOR COMPLETE BUT FOREVER
       GOSUB subC_TO_F
      NEXT
      STOP
    California, USA
    NORM!
    This works great!
    I tested it with my circuit and it works perfect down to at least -20C (-4F) which is as cold as my freezer goes.
    So that should cover the full range of temperature now.
    I really appreciate the help from all of you.
    I've pondered the problem several times over the last few years but never came up with code that worked over the full range of positive and negative temps.
    This is very cool
    THANKS! THANKS! THANKS!
      subC_TO_F:
        F = C * 9
        F = DIV32 5
        IF C_sign = 1 THEN 'if the sign bit is "1" is minus C
          IF F > 3200 THEN
            F = F - 3200
             lcdout $fe,$2," C = -",DEC C/100,".",DEC2 C,$fe,$c0," F = -",DEC F/100,".",DEC2 F,"   "
            F = 3200 - F
            lcdout $fe,$2," C = -",DEC C/100,".",DEC2 C,$fe,$c0," F = ",DEC F/100,".",DEC2 F,"   "
          F = F + 3200
          lcdout $fe,$2," C = ",DEC C/100,".",DEC2 C,$fe,$c0," F = ",DEC F/100,".",DEC2 F,"   "
        pause 200
    Oh, and this is the first time that I've played with "DIV32". Very handy that is....
    Now with round up, No longs, 2 decimal places.
    Norm
      C VAR WORD
      F VAR WORD
      iSIGN VAR BIT
      GOTO MAIN
      subC_TO_F:
        F = C * 2
        F = F * 9
        F = DIV32 5
        F = F + 1 'ROUND UP
        F = F / 2
          IF F > 3200 THEN
            F = F - 3200
            F = 3200 - F
          F = F + 3200
      MAIN:
      iSIGN = 1
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0
       GOSUB subC_TO_F
      NEXT
      iSIGN = 1
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0
       GOSUB subC_TO_F
      NEXT
      STOP
