Temprature conversion --- C to F
Results 1 to 14 of 14
    Oct 2009
    Utah, USA
    Default Re: Temprature conversion --- C to F
    Hey ByteButcher...
    bear in mind that my code does NOT result in an actual SIGNED value of the Temperature deg F. You end up with the correct temperature in the variable "tempF" and the sign of that value in the variable "sign". It is sutable for display on an LCD or something like that. But you will have to know the value of the "sign" if you want to do further calculations on the value.
    PS. I posted the wrong INCLUDE statement...
    YOU would use ...
    INCLUDE "Temp_Convert.pbp"
    (I tried to modify Darrels code to simplify it to only include the needed code to convert C to F and eliminate the Kelvin part. I was really tight on code space for my project.)
    There is some good informaiton about temperature conversion here (towards the bottom of the page)... http://www.rentron.com/PicBasic/one-wire2.htm
    @Normnet... is it really that simple to convert degrees C to degrees F? across the whole range of -55C to +125C ??
    Dwight
    I was thinking on the run above but the following is complete.
    C value is * 1000 to hold 4 places.
      C VAR LONG
      F VAR LONG
      iSIGN VAR BIT
      GOTO MAIN
      subC_TO_F:
        F = C * 9
        F = F / 5
        IF iSIGN = 1 THEN 'if the sign bit is "1" is minus C
          IF F > 320000 THEN
            F = F - 320000
            SEROUT2 sSEROUT_PIN,cBAUD,[" -",DEC C/10000,".",DEC4 C," C  = -",DEC F/10000,".",DEC4 F," F",13]
            F = 320000 - F
            SEROUT2 sSEROUT_PIN,cBAUD,[" -",DEC C/10000,".",DEC4 C," C  = ",DEC F/10000,".",DEC4 F," F",13]
          F = F + 320000
          SEROUT2 sSEROUT_PIN,cBAUD,["  ",DEC C/10000,".",DEC4 C," C  = ",DEC F/10000,".",DEC4 F," F",13]
      MAIN:
      SEROUT2 sSEROUT_PIN,cBAUD,[" ",13]
      SEROUT2 sSEROUT_PIN,cBAUD,["START",13]
      iSIGN = 1 'NEG
      FOR C = 100 TO 0 STEP -1 '-.0100 C TO 0 C
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0 'POS
      FOR C = 0 TO 100 STEP 1 '0 C TO .0100 C
       GOSUB subC_TO_F
      NEXT
      iSIGN = 1
      FOR C = 550000 TO 0 STEP -10000 '-55.0000 C TO 0 C  'DO STEP -1 FOR COMPLETE BUT FOREVER
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0
      FOR C = 0 TO 1250000 STEP 10000 '0 C TO 125.0000 C  'DO STEP 1 FOR COMPLETE BUT FOREVER
       GOSUB subC_TO_F
      NEXT
      STOP
    Norm
    Now displays 4 decimals with round up.
    Norm
    C VAR LONG
      F VAR LONG
      iSIGN VAR BIT
      GOTO MAIN
      subC_TO_F:
        F = C * 10
        F = F * 9
        F = F / 5
          IF F > 3200000 THEN
            F = F - 3200000
            F = F + 5
            F = F / 10
            F = 3200000 - F
            F = F + 5
            F = F / 10
          F = F + 3200000
          F = F + 5
          F = F / 10
      MAIN:
      iSIGN = 1
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0
       GOSUB subC_TO_F
      NEXT
      iSIGN = 1
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0
       GOSUB subC_TO_F
      NEXT
      STOP
    California, USA
    Well, I got lost in a world of fire wood this week and haven't had a chance to look through all these great suggestions. But THANKS to everyone for the input so far. Hopefully in the next day or 2 I'll get a chance to try again.
    Norm, you're killing me with those "Longs".... that's going to be tough to implement with my 16F887!
    Quote Originally Posted by Byte_Butcher View Post
    No longs, 2 decimals. no round.
    Enter C value 124.56 as 12456
    Norm
      C VAR WORD
      F VAR WORD
      iSIGN VAR BIT
      GOTO MAIN
      subC_TO_F:
        DISABLE ' Necessary if On Interrupt used
        F = C * 9
        F = DIV32 5
        ENABLE ' Necessary if On Interrupt used
          IF F > 3200 THEN
            F = F - 3200
            SEROUT2 sSEROUT_PIN,cBAUD,[" -",DEC C/100,".",DEC2 C," C  = -",DEC F/100,".",DEC2 F," F",13]
            F = 3200 - F
            SEROUT2 sSEROUT_PIN,cBAUD,[" -",DEC C/100,".",DEC2 C," C  = ",DEC F/100,".",DEC2 F," F",13]
          F = F + 3200
          SEROUT2 sSEROUT_PIN,cBAUD,["  ",DEC C/100,".",DEC2 C," C  = ",DEC F/100,".",DEC2 F," F",13]
      MAIN:
      iSIGN = 1
      FOR C = 100 TO 0 STEP -1 '-1.00 C TO 0 C
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0
      FOR C = 0 TO 100 STEP 1 '0 C TO 1.00 C
       GOSUB subC_TO_F
      NEXT
      iSIGN = 1
      FOR C = 5500 TO 0 STEP -100 '-55.00 C TO 0 C  'DO STEP -1 FOR COMPLETE BUT FOREVER
       GOSUB subC_TO_F
      NEXT
      '12500 IS 125.00 * 100 TO HOLD 2 DECIMAL PLACES
      iSIGN = 0
      FOR C = 0 TO 12500 STEP 100 '0 C TO 125.00 C  'DO STEP 1 FOR COMPLETE BUT FOREVER
       GOSUB subC_TO_F
      NEXT
      STOP
    California, USA
    NORM!
    This works great!
    I tested it with my circuit and it works perfect down to at least -20C (-4F) which is as cold as my freezer goes.
    So that should cover the full range of temperature now.
    I really appreciate the help from all of you.
    I've pondered the problem several times over the last few years but never came up with code that worked over the full range of positive and negative temps.
    This is very cool
    THANKS! THANKS! THANKS!
      subC_TO_F:
        F = C * 9
        F = DIV32 5
        IF C_sign = 1 THEN 'if the sign bit is "1" is minus C
          IF F > 3200 THEN
            F = F - 3200
             lcdout $fe,$2," C = -",DEC C/100,".",DEC2 C,$fe,$c0," F = -",DEC F/100,".",DEC2 F,"   "
            F = 3200 - F
            lcdout $fe,$2," C = -",DEC C/100,".",DEC2 C,$fe,$c0," F = ",DEC F/100,".",DEC2 F,"   "
          F = F + 3200
          lcdout $fe,$2," C = ",DEC C/100,".",DEC2 C,$fe,$c0," F = ",DEC F/100,".",DEC2 F,"   "
        pause 200
    Oh, and this is the first time that I've played with "DIV32". Very handy that is....
    Now with round up, No longs, 2 decimal places.
    Norm
      C VAR WORD
      F VAR WORD
      iSIGN VAR BIT
      GOTO MAIN
      subC_TO_F:
        F = C * 2
        F = F * 9
        F = DIV32 5
        F = F + 1 'ROUND UP
        F = F / 2
          IF F > 3200 THEN
            F = F - 3200
            F = 3200 - F
          F = F + 3200
      MAIN:
      iSIGN = 1
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0
       GOSUB subC_TO_F
      NEXT
      iSIGN = 1
       GOSUB subC_TO_F
      NEXT
      iSIGN = 0
       GOSUB subC_TO_F
      NEXT
      STOP
