A less Cumbersome way of manipulating several LEDS?
Results 1 to 16 of 16
    Default Re: A less Cumbersome way of manipulating several LEDS?
    In a similar vein, can I group just two specific leds together for ease of handling? (I always will want two specific LEDS to light/extinguish together - but want to treat them as one entity vs having to duplicate the commands to each port/pin per LED)
    Why not wire them in "anti-parallel" then? One is on when pin is low, the other when pin is high and both are off when TRIS is 1.
    Mar 2009
    Because I need them to light up together....if I'm reading your suggestion correctly, only one LED can be on at a time?
    Sorry, I misunderstood that. I thought you wanted one on when the other was off. I guess I kind of took that for granted because I can't really see the point in using more than one pin. Just wire the LEDs in parallel or, which is probably better, in series. Depends on the powersupply voltage and forward voltage drop of the particular LED.
    Are these some high power blue LEDs? High current and high Vf? Is that the reason you need one pin for each LED? Please tell me what I'm missing :-)
    Mar 2009
    Yes, I'm using high brightness blue leds (fwd voltage 3.2V, my PSU is 4V) in parallel drawing about 20mA, therefore two = 40ma...too much for one PIC pin...hence wanting to treat two pins as one virtual pin in code. But it's no big deal....thought I'd ask - and as ever there is something that exists that can be brought into play, except that I need to control the pin on/off via TRISC to avoid clicking so I can't personally use it.
    Maybe something like this? Not very swanky, but should work.
    LED VAR WORD
    LED = %XXXXX111111111 'ALL LEDS ON
    GOSUB LED_OUT
    LED = %XXXXX000000000 'ALL LEDS OFF
    GOSUB LED_OUT
    Goto Main
    LED_OUT:
    PORTC.6 = LED.0
    PORTB.6 = LED.1
    PORTB.5 = LED.2
    PORTB.4 = LED.3
    PORTC.2 = LED.4
    PORTC.1 = LED.5
    PORTC.0 = LED.6
    PORTA.2 = LED.7
    PORTA.1 = LED.8
    Jan 2006
    Istanbul
    Since you are driving LEDs, why not MIBAM ?
    Mar 2009
    Quote Originally Posted by sayzer View Post
    I have a common dim function in place already (via a PWM driven mosfet)...I don't really need dimming per pin
