A less Cumbersome way of manipulating several LEDS?
Results 1 to 16 of 16
    Default Virtual Ports
    LEDs  VAR WORD
    INCLUDE "VirtualPort.bas"
    MyPortPins  macro               ; these define which bits go with which pins
        Vpin   0, PORTC,6
        Vpin   1, PORTB,6
        Vpin   2, PORTB,5
        Vpin   3, PORTB,4
        Vpin   4, PORTC,2
        Vpin   5, PORTC,1
        Vpin   6, PORTC,0
        Vpin   7, PORTA,2
        Vpin   8, PORTA,1
    Init:
    @   OutputPort  MyPortPins             ; Set Pins to Output
        LEDs = %000010011
    @   WritePort  _LEDs, MyPortPins
        PAUSE 1000
        LEDs = 0
        LEDs = LEDs + 1
        @  WritePort  _LEDs, MyPortPins    ; write pattern to Virtual Port
        PAUSE 250
    GOTO Main
    I haven't tried it on the 16F1's, but I think it should work.
    The VirtualPort.bas file is in this thread ... http://www.picbasic.co.uk/forum/show...3158#post83158
    Like 80% of everything I've done in this forum, the post got destroyed. But the file's still there.
    Mar 2009
    Default Re: Virtual Ports
    Excellent Darrel - many thanks....does it add much in the way of delay? (ie if I was sequencing 8 leds fast would this start slowing stuff up)
    Default Re: A less Cumbersome way of manipulating several LEDS?
    how fast human eye is btw? vport is nowhere near to be that slow
    Quote Originally Posted by HankMcSpank View Post
    VirtualPort will be faster than using lists of HIGH/LOW since it doesn't set the TRIS bits each and every time.
    That in itself may be a problem when running at 32Mhz and the old R-M-W issue may come into play.
    Let me know if it does and I'll change it to use the LAT registers on the 16F1's.
    In a similar vein, can I group just two specific leds together for ease of handling? (I always will want two specific LEDS to light/extinguish together - but want to treat them as one entity vs having to duplicate the commands to each port/pin per LED)
    The pin list macro can have multiple pins assigned to each bit.
    In this example both RC6 and RB3 would turn on and off according to bit0 of the value passed to WritePort.
        Vpin   0, PORTC,6
        Vpin   0, PORTB,3
        Vpin   1, PORTB,6
        Vpin   2, PORTB,5
    Mar 2009
    Hi Darrel,
    That's fantastic (ie two pins handled as one virtual pin...I'm figuring that the maximum number of Virtual Port bits is 8? if so, wouldn't you just know that I have 9 LEDs!)
    re VirtualPort and the TRISC settings ...hmm, maybe I can't use your funky routine after all - one thing I observed when using the HIGH/LOW command, was excessive audible clicking attributed to the port.pin switching state (I work with low level guitar signals, which often pass in close proximity to a PIC, guitar signals often get treated with enormous gain so I'm perhaps more aware/sensitive to such clicks than others!) The only way I was able to stop such clicking was to to use TRISC command instead of the high/low command, for example, this would result in clicking....
    TRISC.6 = 0
    HIGH PORTC.6
    whereas this doesn't...
    PortC.6 = 1
    TRISC.6 = 0
    ....whacky. (so to turn an LED on/off, I don't use high/low, but just set the pin as output or input)
    Why not wire them in "anti-parallel" then? One is on when pin is low, the other when pin is high and both are off when TRIS is 1.
    Mar 2009
    Because I need them to light up together....if I'm reading your suggestion correctly, only one LED can be on at a time?
    Sorry, I misunderstood that. I thought you wanted one on when the other was off. I guess I kind of took that for granted because I can't really see the point in using more than one pin. Just wire the LEDs in parallel or, which is probably better, in series. Depends on the powersupply voltage and forward voltage drop of the particular LED.
    Are these some high power blue LEDs? High current and high Vf? Is that the reason you need one pin for each LED? Please tell me what I'm missing :-)
