first program 12f683
Results 1 to 16 of 16
    Apr 2011
    Default Re: first program 12f683
    here is the steps I have taken in MPLAB
    1.click project wizard and select 12f683 and save project as test-12f683.mcp
    2. copy file 12f683.bas to folder and rename it test-12f683.bas
    3. click finish and project is complete
    add 2 lines of code
    press f-10 to compile and the program chokes
    then I comment out several items and now it will compile
    this does not seem right
    my code will run on the micro. just want make sure that this is the right way
    Quote Originally Posted by sparkness View Post
    No, you are not supposed to put code in, and compile the guts of PBP, like this file. Please re-read posts above.
    Apr 2011
    so I should not add the source file 12f683.bas to the project and create an empty file called test-12683.bas in this example?
    Apr 2011
    my mistake, I was adding the .bas file to the project
    I was using the steps required for an Assembler project
    Again, that is not a sample or test code. You should not be trying to run it, it is a file PBP needs to help compile code.
    Restore the file to its original state and try one of the smples I linked you to.
