first program 12f683
Results 1 to 16 of 16
    Jan 2014
    Default Re: first program 12f683
    i solved... the problem was from CONFIG . MCLRE must be off and measured pulse is in 10us.
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    ansel = 0
    wpu = 0
    cmcon0 = 7
    signal var word
    pulsin gpio.3,1,signal
    if signal > 160 then high gpio.0
    you also must add in your program the condition for the led to be off ...
    as outputs are bistable kind ... they will stay on the last programmed state, otherwise stated ...
    Jan 2014
    Thx Alain! I try to learn about microcontrolers and any info are welcome.
