Changing the sines frequency?
Results 1 to 33 of 33
    Default Re: Changing the sines frequency?
    OK, I don't know from where I got that you had 72 steps in the lookup table. Now I know it's 90. If can live with fewer steps you'll be able to increase the output frequency.
    I'm pretty sure you're simply running out of time. I made some quick tests here but in order to do so I had to change your code a little bit (don't have 4431 handy to test on). So I'm not sure exactly how much we can depend on these.
    I'm using a 18F4520 @20Mhz.
    The interrupt routine itself runs in about 70us, the overhead introduced by the interrupt system (DT-ints) is from previous tests I've done about 29us (again at 20Mhz) at interrupt entry and I would guess about the same on exit. This means each interrupt takes a total of ~130us.
    1/0.000130 = 7700Hz
    I've verified this by specifying InterruptFrequency of 7700Hz and it works, I get 7700 Hz with nice, steady pulses. If I specify 8500Hz I can see on the scope that the trace is starting to get jittery indicating that it's starting to overrun it self, missing pulses so think I'm pretty close to the absolute max at 7500-8000Hz.
    Now, in theory, since you're running at 40MHz you should be able to get twice that, ~15kHz but apparently you're not. Can you set a pin high at the beginning of the interrupt service routine and set it low just before @INT_RETURN, then measure how long that output is high. That will tell you the execution time of the actual handler (where I got 70us).
    Are you sure that the PIC is running at 40Mhz? Simply specifying DEFINE OSC40 doesn't make it run at 40MHZ, you need to enable the PLL thru the CONFIG bits as well.
    1/0.000130 = 7700Hz
    With this :
    ' PWM calculation and update interrupt (Timer 1)
    pwmint:
    T1CON.0 = 0                             ' Stop TMR1
    TMRCopy.HighByte = TMR1H                ' Copy value of TMR1 registers
    TMRCopy.LowByte = TMR1L
    TMRCopy = TMRCopy + TimerReloadValue    ' Add reload value (compensates for overhead)
    TMR1H = TMRCOPY.HighByte                ' And back to TMR1
    TMR1L = TMRCopy.LowByte
    T1CON.0 = 1                             ' Restart Timer
    TOGGLE PORTD.7
    @INT_RETURN
    And a interrupt freq of 10800Hz, I get an output square wave of 720Hz on the oscilloscope.
    Here is my config bits in MPLAB :
    Note I'm using the HS oscillator with PLL enabled. My crystal (40MHz) is connected between OSC1 and OSC2 pins, with 2*47pF ceramic capacitors. On the oscilloscope, it's okay, I can see the oscillation.
    Something must be wrong with your setup. I tried the same ISR as your one, with InterruptFrequency = 10800:
    ' ---------- Interrupt handler ------------
    TimezUp:
    PortB.3 = 1
    PortB.3 = 0
    @ INT_RETURN
    And I get ~10500Hz even when running at 20Mhz. Here you can see that I, instead of using TOGGLE set the output high at the entry point and low at the exit which allows me to measure the execution time of the code in between. This exact code executes in ~3us on this 18F4520 running at 20MHz, if you try the same on yours it should be 1.5us - if it's not then you're not running at 40MHz.
    You say you have a 40MHz x-tal, is that really correct? To run at 40MHz with the PLL you should use a 10MHz x-tal.
    Try the above, what's the pulsewidth on the output? If it's not 1.5us you're not running at 40MHz.
    TimezUp:
    PortB.3 = 1
    PortB.3 = 0
    @ INT_RETURN
    With your exact code (the same you're using) and a INTF of 10800Hz, I get 2,76ms between each pulse. Very weird, and very slow. I've disabled the PLL, the oscilator is configured as a HS oscillator.
    1) What's the width of the pulses? Not the time between them but the width?
    2) What's the value stamped on your x-tal?
    3) The timing calculations that I provided are based on the fact that your chip is SUPPOSED to run at 40MHz, if it's not running at 40MHz then the timing will be wrong and the interrupt frequency will wrong as well.
    4) Please don't quote the complete message you're responding to. It clutters the thread and it gets hard read because everything is quoted all the time - that's my personal view.
    The pulses are very very thin :
    The width of a pulse is 4,4µs.
    Of course the crystal is stamped at 40MHz, I've difficulties with the setup of this timer, but I hope I'm not an idiot
    The circuit :
    Well, then that is likely the problem - or one of them... If you look at page 355 in the datasheet you'll see that the maximum x-tal frequency WITHOUT PLL is 25 MHz and with using the PLL it's 10MHz (resulting in 40Mhz). You're trying to use 40Mhz which is out of specs in both cases.
    The fact that your pulses are 4.4us wide while mine are 3us means that your chip is running way SLOWER than mine while in fact it "should" be running twice as fast.
    Get the oscillator sorted and verify that the PIC is running at the speed you think. One way to do that is a simple program like:
    DEFINE OSC 20    'Don't forget to DEFINE the correct OSC speed.
    TRISB.0 = 0
      PortB.0 = 1
      Pause 1
      PortB.0 = 0
      Pause 1
    Goto Main.
    If you DON't get a 500Hz signal with 1ms wide pulses the chip isn't running at the correct and/or DEFINE'd oscillator speed.
