Changing the sines frequency?
Results 1 to 33 of 33
    Default Re: Changing the sines frequency?
    Now you are mixing your original code with Darrels template and what I tried to tell you earlier into a complete mess....
    Yes, and to do that you change the reload value which you load TMR1 with at each interrupt. In the timer1 intterupt stop the timer, add your reload value to the value of the timer and restart it. Then do whatever else needs to be done in the ISR. Did you try the code I posted in my first reply?
    Of course I've readed your first reply, and it's how I integrated your routine into my code :
    ' PIC initialization
    DEFINE OSC 40
    DEFINE LCD_DREG PORTC
    DEFINE LCD_EREG PORTD
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_EBIT 0
    DEFINE LCD_RSBIT 1
    DEFINE LCD_COMMANDUS 4000
    DEFINE LCD_DATAUS 1000
    ' BAS includes
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INCLUDE "Sine_table.bas"
    ' Port registers configuration
    TRISB=%11000000   ' PWM 0,1,2,3,4,5 outputs
    TRISC=%00110000   ' +/- buttons
    ' PCPWM registers configuration
    DTCON=%110        ' Deadtime (600ns)
    PTCON0=%0         ' 1:1 postscale, Fosc/4 1:1 prescale, free running mode
    PTCON1=%10000000  ' PWM time base is ON, counts up, 19.45kHz/4
    PWMCON0=%1000000  ' PWM 0,1,2,3,4,5 set in pair mode
    PWMCON1=%1        ' PWM timer sync configuration
    ' PWM calculation variables
    ustep var byte
    vstep var byte
    wstep var byte
    uduty var word
    vduty var word
    wduty var word
    timer var word
    amplitude var word
    carrier VAR word
    flag var bit
    ' Variables definition
    ustep=90          ' 360 degrees phase angle
    vstep=60          ' 240 degrees phase angle
    wstep=30          ' 120 degrees phase angle
    timer=64120       ' Timer adjust
    amplitude=65535   ' Sinewave amplitude adjust (65535=max amplitude)
    carrier=1023      ' Carrier frequency adjust (1023=13kHz)
    flag=%0           ' Menu flag
    ' PWM carrier frequency register configuration
    PTPERL=carrier.lowbyte
    PTPERH=carrier.highbyte
    ' Interrupt processors
    INT_LIST macro
    INT_Handler TMR1_INT,_pwmint,PBP,yes
    INT_CREATE
    ' Timers configuration
    T1CON=%1
    ' Interrupts enable
    @INT_ENABLE TMR1_INT
    ' Main program loop
    mainlp:
    ' Debug display
    if flag=0 then
    LCDOUT $FE,$2,"Freq. adjust :"
    LCDOUT $FE,$C0,DEC timer
    if PORTC.4=1 then timer=timer-1
    if PORTC.5=1 then timer=timer+1
    IF PORTC.4 AND PORTC.5=1 then flag=%1
    LCDOUT $FE,$2,"Amp. adjust :"
    LCDOUT $FE,$C0,DEC4 amplitude
    if PORTC.4=1 then amplitude=amplitude-1
    if PORTC.5=1 then amplitude=amplitude+1
    goto mainlp
    TimerShadow VAR WORD
    TimerReload VAR WORD
    TimerReload=64000 'Test
    ' PWM calculation and update interrupt (Timer 1)
    pwmint:
    ' Timer 1 update
    TMR1L=timer.lowbyte
    TMR1H=timer.highbyte
    T1CON.0 = 0  'Stop TMR1
    TimerShadow.HighByte = TMR1H
    TimerShadow.LowByte = TMR1L
    TimerShadow = TimerShadow + TimerReload
    TMR1H = TimerShadow.HighByte
    TMR1L = TimerShadow.LowByte
    T1CON.0 = 1  'Restart TMR1
    ' PWM U phase calculation
    uduty=sine[ustep]
    uduty=uduty<<4**amplitude
    ' PWM V phase calculation
    vduty=sine[vstep]
    vduty=vduty<<4**amplitude
    ' PWM W phase calculation
    wduty=sine[wstep]
    wduty=wduty<<4**amplitude
    ' PWM U, V and W update
    PDC0L=uduty.lowbyte
    PDC0H=uduty.highbyte
    PDC1L=vduty.lowbyte
    PDC1H=vduty.highbyte
    PDC2L=wduty.lowbyte
    PDC2H=wduty.highbyte
    ' Phase angle calculation
    ustep=ustep-1
    vstep=vstep-1
    wstep=wstep-1
    ' Phase angle reinitialization
    if ustep=0 then ustep=90
    if vstep=0 then vstep=90
    if wstep=0 then wstep=90
    @INT_RETURN
    It doesnt work at all, but I think it's how I integrate your routine in the code, badly I think.
    And with this :
    pwmint:
    toggle PORTD.7
    @INT_RETURN
    I get a 100Hz output frequency on PORTD.7.
    Yes, but you still need to keep the reloading code in the interrupt routine otherwise the timer will "freewheel" again.
    In your code, as the very first thing in the ISR, you are currently overwriting the TMR1 register with the value of a variable called timer.
    pwmint:
    ' Timer 1 update
    TMR1L=timer.lowbyte     '<---This is overwriting the TMR1 registers!
    So, once the code gets to "copying" the TMR1 registers and adding the reload value to it you have overwritten it with something else.
    I've just tested the following code here:
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    INCLUDE "IncPID.pbp"
    TMRCopy VAR WORD
    TimerReloadValue VAR WORD
    TimerReloadValue = 63000
            INT_Handler   TMR1_INT,  _TimezUp,   PBP,  yes
        INT_CREATE              ; Creates the interrupt processor
    @ INT_ENABLE  TMR1_INT      ; enable Timer 1 interrupts
    TRISB.0 = 1                 ' +button
    TRISA.4 = 1                 ' -button
    TRISB.3 = 0                 ' Output to measure interrupt frequency
    CMCON = 7
    ADCON1 = %00001111          ' No analog inputs.
    T1CON.0 = 1                 ' Start TMR1
    If PortB.0 = 0 then
      TimerReloadValue = TimerReloadValue + 1
      LCDOUT $FE,1,#TimerReloadValue
    If PortA.4 = 0 then
      TimerReloadValue = TimerReloadValue - 1
    Pause 20
    Goto Main
    ' ---------- Interrupt handler ------------
    TimezUp:
      T1CON.0 = 0                             ' Stop TMR1
      TMRCopy.HighByte = TMR1H                ' Copy value of TMR1 registers
      TMRCopy.LowByte = TMR1L
      TMRCopy = TMRCopy + TimerReloadValue    ' Add reload value (compensates for overhead)
      TMR1H = TMRCOPY.HighByte                ' And back to TMR1
      TMR1L = TMRCopy.LowByte
      T1CON.0 = 1                             ' Restart Timer
    Toggle PortB.3
    @ INT_RETURN
    And it works fine. Pushing the buttons connected to PortB.0 and PortA.4 increases/decreases the reload value for the timer and the interrupt frequency.
    But, again, a change of 1 at the "top" will not result in the same change in interrupt frequency as a change of 1 at the "botton".
    pwmint:
    ' Timer 1 update
    DEFINE OSC 20
    TMRCopy VAR WORD
    CMCON = 7
    If PortB.0 = 0 then
    If PortA.4 = 0 then
    Pause 20
    Goto Main
    TimezUp:
    Toggle PortB.3
    @ INT_RETURN
    Tried this in my code with the sines, it works.
    So what the point since the first program? It is impossible to change proportionally this interrupt frequency in run time? Or any math relation/equation to calculate the correct timer value according to the desired frequency?
    Like you said, I can make a lookup table, but this program is intended to make a 3-phase VFD AC motor drive, adjustable from 0 to 120Hz with 0.1Hz increments... so if I use a lookup table, it will take 1200 variables! Doesn't sure that my PIC had enough memory capacity...
    And how to calculate the "correct preload value"?
    The difference is that it takes the overhead of saving all the PBP system variables into account. There's nothing you can do about the non linearity really - it's just the way it is. One way to reduce the effect of it is to have less "steps" in the SIN table, that willm bring the interrupt frequency down which makes the relationship between interrupt frequency and reload value more linear.
    You CAN calculate the reload value at runtime, Darrels timer template even shows you HOW to do it (at compile/assembly time) but you need to play some tricks to do it runtime. The following is NOT tested:
    Dummy VAR WORD
    Dummy2 VAR WORD
    Dummy3 VAR WORD
    ReloadInstructions VAR BYTE
    Frequency VAR WORD
    ReloadInstruction = 0  'Number of instructioncycles it takes to actually reload the timer. I don't know how many it is in this case. Tune later.
    'For 40Mhz operation and 1:1 prescaler the timer ticks at 10Mhz
    Dummy2 = 10000     'These can not be constants because
    Dummy3 = 10000     'constants doesn't work with DIV32
    Frequency = 200    'Lowest possible frequency is ~153Hz. Don't go below that.
    Dummy = Dummy2 * Dummy3        'Intermediate result is now 10.000.000
    TimerReload = DIV32 Frequency       'Divide 10.000.000 in Frequency (200 in this case)
    TimerReload = 65535 - TimerReload + 1 + ReloadInstructions  ' =15536 for 200Hz
    'Reloading the timer with 15536 makes it time out in 50000 ticks, one tick is 0.1us so
    'it times out it 5000us or 5ms, 1/0.005=200Hz which is the frequency we wanted.
    This should calculate the reload value, at runtime (don't do this IN the interrupt service routine). But I don't think you'll get 0.1Hz resolution at the top end.
    Thanks, I will make some experiments with this code.
    Unfortuntely, it doesn't works.
    The problem is that TimerReload variable overwrites TimerReload EXT constant, defined later in DT routine.
    DEFINE OSC 40
    DEFINE LCD_EBIT 0
    DEFINE LCD_RSBIT 1
    ' BAS includes
    ustep var byte
    vstep var byte
    wstep var byte
    uduty var word
    vduty var word
    wduty var word
    amplitude var word
    carrier VAR word
    flag var bit
    flag=%0           ' Menu flag
    Dummy VAR WORD
    Dummy2 VAR WORD
    Dummy3 VAR WORD
    ReloadInstruction VAR BYTE
    Frequency VAR WORD
    Frequency = 5000    'Lowest possible frequency is ~153Hz. Don't go below that.
    TimerReload = 65535 - TimerReload + 1 + ReloadInstruction  ' =15536 for 200Hz
    INT_LIST macro
    INT_Handler TMR1_INT,ReloadTMR1,ASM,no
    INT_CREATE
    @Freq=4050
    @Prescaler=1
    T1CON=$00
    ' Interrupts enable
    GOSUB StartTimer
    ' Main program loop
    mainlp:
    ' Debug display
    if flag=0 then
    LCDOUT $FE,$C0, DEC frequency
    if PORTC.4=1 then frequency=frequency-1
    if PORTC.5=1 then frequency=frequency+1
    goto mainlp
    pwmint:
    uduty=sine[ustep]
    vduty=sine[vstep]
    wduty=sine[wstep]
    PDC0L=uduty.lowbyte
    PDC1L=vduty.lowbyte
    PDC2L=wduty.lowbyte
    ustep=ustep-1
    vstep=vstep-1
    wstep=wstep-1
    @INT_RETURN
    ' Timer1 interrupt handler
    ReloadInst=8
    MaxCount=65536+(ReloadInst/Prescaler)
    TimerReload=MaxCount-(OSC*1000000/4/Prescaler/Freq)
    ' Timer1 variables
    @Timer1=TMR1L
    Timer1 VAR WORD EXT
    'TimerReload VAR EXT
    TMR1ON VAR T1CON.0
    ' Timer1 reload
    ReloadTMR1
    MOVE?CT 0,T1CON,TMR1ON
    MOVLW LOW(TimerReload)
    ADDWF TMR1L,F
    BTFSC STATUS,C
    INCF TMR1H,F
    MOVLW HIGH(TimerReload)
    ADDWF TMR1H,F
    MOVE?CT 1,T1CON,TMR1ON
    INT_RETURN
    ' Timer1 start/stop control
    StartTimer:
    Timer1=TimerReload
    TMR1ON=1
    StopTimer:
    TMR1ON=0
    Yes of course it does. I thought we came to the conclusion that you couldn't use Darrels timer template because it calculated the reload value at build time and you wanted to calculate it at runtime. Now you're trying to use it anyway....I don't get it.
    InterruptFrequency VAR WORD
    Dummy VAR WORD
    Dummy2 VAR WORD
    Dummy3 VAR WORD
    TMRCopy VAR WORD
    Dummy2 = 10000
    Dummy3 = 10000
    InterruptFrequency = 5000
    CMCON = 7
      TimerReloadValue = Div32 InterruptFrequency
      TimerReloadValue = 65535 - TimerReloadValue + 1
      LCDOUT $FE,1,"F: ", #InterruptFrequency, " Reload: ", #TimerReloadValue
     Pause 20
    Goto Main
    TimezUp:
    Toggle PortB.3
    @ INT_RETURN
