USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Default USBDemo, something to learn USB a little bit
    Hi all,
    Since the USB stuff is coming more and more popular, and as we see more and more questions, i decided to post my little contribution.
    OK OK You already asked... but i'm in a good moon today, so let me believe it never been asked before
    The whole thing will use a PIC18F4550 and a 4MHz crystal + few Leds, 2 trim pot... you should be able to figure this out easy.
    There we go, here's the PC interface,
    <img SRC="http://www.mister-e.org/Pics/USBDemo.JPG">
    Sounds good eh?
    With this you can
    1. play with both CCP (PWM) duty cycle and show it on 2 leds attach to your PIC CCP i/o (PORTC.1, PORTC.2)
    2. modify each PORTB bits status as you wish.
    You can also
    1. see the results of AN<1:0> ADC results in the progress bars
    2. monitor the status of those push-buttons attach to PORTA<5:2> inputs (with pull-down resistors)
    3. receive text string
    4. Display your VendorName and ProductName.
    So almost everything EASY will be covered in both code.
    I tried to stay away of the cryptic-fashioned coding but i couldn't resist to use some macro etc etc. Eh, maybe you'll learn from it? Who knows?
    In attachment, you'll find ALL FILES. PBP source code and VB6 source code AND a ready to run USBDemo.exe file. Everything is hardly commented so, read it carefully... it won't hurt!
    The original folder was c:\PBP_PROG\USBDemo but it shouldn't cause any problem... well i guess. If so, you know where to send them.
    NOTE: If you're going to use LONG variables, you MUST copy the PIC18Xxxxx.BAL file in your source directory as well, unless you'll receive some compilation errors.
    The .BAL file is located in \PBP\USB18 directory.
    Those who want to use PIC18F2455, 18F2550, have a look at post 99.
    http://www.picbasic.co.uk/forum/show...8&postcount=99
    Enjoy!
    Bombay, India
    Default Question on MCHID.DLL
    Hi Steve
    Thanks for sharing your work with us. I for one have never designed around USB till now, but, have something to back me up now.
    Anyway, I looked at the VB code and have a question. There is a MCHID.DLL on which the code depends. Where do I get this? On the Microchip site or is it something you built?
    I hope you see this the first thing on the 1st morning of the new year. So, I wish you and the community here a HAPPY NEW YEAR in anticipation.
    Jerson
    skimask's Avatar
    skimask Guest
    Default USBDemo
    No kidding! I've been a bit weary of trying out a bit of playing around with a PIC and a USB. Previously, I've only used the FTDI chips or the CP2102/2103 combo's. This little application could save me a fair amount of PCB space.
    Question in regards to the onchip transceiver. Where would one NEED or prefer to use an external transceiver for the USB, or, conversely, where would one want to use the internal transceiver exclusively?
    And BTW, thanks a lot, mister_e. Now I've got another project to play...like I don't have enough to play with to keep me up late at night as it is
    JDG
    skimask's Avatar
    skimask Guest
    JDG
    I forgot to order USB connectors. The average project will use a USB Type B Female on the box of the side of the project, right? Example....the 'normal' cable that a person would buy down at the local store has Type A male on one end, and Type B male on the other end, or is that wrong too? I know on the last 2 USB projects I've done (and this was just to get rid of the wrong stuff I bought in the first place), I had to go out and get special cables made up because I bought the wrong gender at both ends with the wrong type (A or B) at each end I done good with that one...
    It's up to you guy, you know there's also this tiny model on digital camera ( or PICKIT 2) as well.... i don't remind the name...
    But most of the time, use a 'B type' on the PIC end... if you really want a connector.
    In meantime you can still hack an old USB mouse or buy a few $ USB cable. i got few 6' here in a local electronic store for 2$.
    Please, use an external psu for you tests.... you never know what could happen.
    EDIT.... i thought they could choose a more sophisticated term for those mini-tiny-usb connector... NOP mini-A or mini-B
    http://en.wikipedia.org/wiki/USB
    skimask's Avatar
    skimask Guest
    Mini- connectors - Those seem to be a bit more prevalent these days as opposed to the older/larger types. Will probably switch over to those in due time. A-type at the PC end, B-type female (mini or not) at the device end.
    External power - yes, most definetly. In the past, I've drawn a small bit of power off the USB bus to charge a small AAA NiMH pack, but the bulk of the power for the circuit comes from the AAA NiMH pack.
    Feb 2003
    Oh yes I do
    I have a board that I have been working on and had no problems with it whatsoever until I moved it slightly on the computer desk and my daughter had left a metal hair grip on the desk.
    Now have a PC with 4 dead USB ports on the mobo
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Quote Originally Posted by Jerson View Post
    This DLL comes with Mecanique EasyHID... wich i use all the time to generate those code template. I can't believe it's free
    So just download and install EasyHID HERE and this will solve the problem.
    Quote Originally Posted by Skimask
    indeed, it's a little tricky those first time, but once you have rebooted you computer over 1000 time to solve the USB connection failure, you learn really fast
    Quote Originally Posted by skimask
    Sorry i can't help on that, i never use an external one. But probably THIS or THIS could help ?
    Who need to sleep anyways
    You're welcome AND enjoy!
    malc-c's Avatar
    malc-c Guest
    Thank goodness you didn't choose the 18F2550 -
    Steve, nice project, maybe this should be made a sticky in the main PBP section
    Hehe, but.. will your PicProgrammer be able to program it ?
    First, i wanted to post it in the USB section... But, Code Examples have to be post in the right section...
    Hope you may use some part of it one day.
    Bear in mind it's only a Demo and a 1-2 hours job.. yeah i count the beer, coffe and cigarette breaks, but remove those phone calls i got when doing it... always like that when you don't want to be disturbed
    Mister_E,
    I fart in your general direction ....
    This is all your fault. I've been totally cosumed by this USB stuff for several days now. I've been so affraid of USB for so long. But after your example showed how easy it is, I've been locked in a never ending cycle of, "hmm, what else can I do with it".
    Consequently, I've accomplished nothing else, "including going to work yesterday"
    I haven't answered your ASM question in the other thread (or anyone elses), I haven't eaten much, and Sleep is a requirement that I would have rather done without (wish I could).
    I'd like to say "Thank you for the great example", but it's ruining my life.
    So instead I'll say ...
    Thanks for the Mean, Vicious, Natsy, Brutal, Sadistic, yet Wonderfull piece's of code.
    <br>
    Wink
    Disclaimer
    Mister E assume no responsibility for any addictions caused by the use of this actual thread, program, tutorial...
    call it as you want.
    Mister E don't want to be involve in any of your future or actual health, job and/or girlfriend/wife/boyfriend problem!
    So use with care.
    You read it, you use it... it's your problem what's happen next.
    LMAO!
    \_________________________________________________ ________________________________________________/
    <table><tr><td></td><td>Well Darrel i'm really sorry (yeah right), but at the same time... i'm proud of me. At least you lost this USB fear! And i think, for once, i teached you something... ???
    You know, I already said to few user here and there that PIC are addictive... i thought you took the advice... seems not... so
    TOO BAD FOR YOU !
    </td></tr></table>
    Now, go to sleep, eat and go back to work
    skimask's Avatar
    skimask Guest
    Mister_E,
    <br>
    No kidding! I'm looking forward to reducing my sanity, food intake, sleepy time, and probably the wife soon after my 18F4550's arrive. So, if mister_e gets a call in the middle of the night from a screamin' female who he doesn't know, this thread is most definetly the reason why.
    I wonder how long it'll take before he's on the 'Jerry Springer' show as the unseen homewrecker.
    Thanks a lot...
    May the demons of evil get confused on their way to your doorstep!
    Talking
    No problem then, my phone number is not hidden anyway... But, LOL, maybe she will have to repeat few times and be patient when i will try to reply to her... yeah my english writing is bad... imagine how bad i talk
    Exclamation USB Bootloader for EasyHID driver?
    Is it possible to use microchip´s bootloader since the driver is different than the one from easyHID?
    Haven´t tried but, is it possible to use MCS bootloader (Serial)? i have a version of 4 MHZ for 18f4550 that comes with MCS but i am not sure if this pic program made by Mister_e is runing 4Mhz or more with some PLL (i am newbie with this concept).
    Thanks AGAIN.
    Lightbulb Two devices easyHID?
    Hello, i have done great things with this demo from Mister_E Thanks always. Its a great playground
    Now i made some changes and created my own device, its working already BUT how do i manage two of the same devices with my software? Where are we choosing one from another? if they both have the same ID, etc?
    Thanks for your replies,
    DJC
    Oct 2007
    Hi....i'm new in 18f4550..
    Can picbasic pro program this PIC?
    How to open the USB port on this PIC?
    Thanks a lot....
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by thye View Post
    Thanks a lot....
    Read the thread...the WHOLE thread.
    It's all there. A complete project from start to finish.
    Many others have done it, I've done it, you can do it.
    However, I wouldn't expect others to do it for you.
    Mar 2009
    Colorado
    Default Schematic link broken...can you provide??
    Hi all,
    Steve, the link to the PC interface schematic as posted in your original is broken. Can you please give me a valid link or email me the schematic at [email protected]? I want to check your USBDemo out!
    Haven't seen him around for awhile.
    His website is gone too.
    Here's the schematic he had previously posted.
    Cool
    Last news for me are stamped August, the 14 th ....
    Steve was telling he still need some " quiet " time.
    But do not hope to read from him before " a certain time " ...
    Much Higher priorities thans solving "problems" ( seen quotes ??? ) when solutions just are "in the Manuals".
    May be he "simply" has to take care of himself, ... for once.
    No Forum for that ...
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. Replies: 9
    Last Post: - 31st July 2008, 08:56
  4. PICBasic newbie problem
    By ELCouz in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 00:55
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 01:07
