Mosfet stable Volt out
Results 1 to 8 of 8
    Puerto Rico
    Question Mosfet stable Volt out
    MosFet out volt
    i need help how stable Volt out with PWM and MosFet
    the out put is up and down for one volt
    example: v1.0
    v1.1
    v1.0
    Bat: 7.2v souce
    HEIN.. have you some schematic and/or more details of your stuff ???
    I really try to understand but... not sure enough to provide a good answer to that.
    Try to tell us what you really expected as output swing... can i understand you want from 0 - 1 Volt or a 0.1 volt steps with a 7.2V battery as power source???
    if i'm right... if not please somebody slap me
    7.2 / 256 = 0,028125 volts by 8 bit PWM definition duty step
    to get 0.1 volt: duty = 0.1/0.02823529 = 3.55555 = 3 or 4 test it
    to get 1 volt : duty = 1/0.02823529 = 35.5555 = 35 or 36 test it
    to get 1.1 volt: duty = 1.1/0.02823529 = 39.1111 = 39
    Puerto Rico
    Question Volt out
    I am driving a dc motor with MosFet and when i read the volt out clamp to the motor is up and down so me robot a fast and slow ...
    Example : out v is shut be 2.0 and not 2.1 but after liter of time change to 2.1 so my robot run i liter fast for a second and then go back so is not stable
    my source is 7.2v
    my MOSFET is Rectifier IRLU3103
    I use 10K resistor, with a 12K resistor gate to ground. Higher gate to ground
    resistance reduces resolution of the byte Duty Cycle variable.
    mmm, in all my motor speed control, i read the voltage on the motor with an A/D input of the PIC. Kinda feedback control.
    Once you have the voltage reading from the motor, simply monitor it and do the according change in your PWM statement or routine.
    10K in serie look a bit high... is 220 Ohms to 1K do the same with the same pull down on the gate?
    May be a stupid question but, is your PIC output is an open drain?!? RA4 ???
    Puerto Rico
    Question Volt out
    Hi ken you send schematic or some help who i made that...
    my pic is pic18f252 and i conect to the pwm pin with 2 res. one to ground and the other to the gate in the same line like a volt divider..
    my code
    MotorDC VAR CCPR1L
    MotorOut VAR PORTC.2
    MotorOn CON %1111110 '16 Pre/Scale
    MotorOff CON %1111010
    MotorEnable VAR T2CON
    PumpDcSet=15
    CurrentStep = 0 to 100 of rc pulse
    MotorScaleFactor = 255 - 15
    MotorScaleFactor / CurrentStep
    MotorDC = MotorScaleFactor / 100 * CurrentStep + PumpDcSet
    Pause PauseScalefactor * 1000 / MotorScaleFactor Factor
    here's something to play with
    ' PIC18F2220
    DEFINE OSC 20
    TRISC = 0 ' PORTC as output
    TRISA = 3 ' RA0 & RA1 as input
    PR2=$FF ' load frequency period (PWM freq=1.2 KHZ)
    ADCON1 = %00001101 ' Set RA0 & RA1 as analog
    ADCON2 = %10000110 ' Right justified result
                       ' Fosc/64
                       ' Tad = 0
    ADCON0.0 = 1       ' enable a/d
    TMR2DutyVar     var word
    AdResult        var word
    Voltage         var word
    Source          var word
    SelectedVoltage var word
    Quanta          con 125 ' (5Volt/1024)*256=0.125 = 125
    SelectedVoltage = 110 ' mean 1.1 volt
    tmr2dutyvar = 156 ' according duty to get 1.1Volt = (1.1/7.2)*1024
    Start:
        gosub InitPWM
        ' Read Motor voltage supply line
        ADCON0 = %00000101 'select channel 1
        pauseus 100
        ADCON0.1 = 1 'start conversion
        while ADCON0.1 ' wait for end of conversion
        wend
        Adresult.highbyte = ADRESH
        adresult.lowbyte = ADRESL
        Source = (adresult */ quanta )
        Source = source * 288 ' to have a range of 7.2volt
        Source = div32 100
        ' Read feedback motor voltage
        ADCON0 = %00000001 ' select channel 0
        pauseus 100
        ADCON0.1 = 1
        wend
        voltage = (adresult */ quanta )
        voltage = voltage * 144 ' to have 7.2V range
        voltage = div32 100
        voltage = source - voltage
        ' Voltage regulation
        if voltage < selectedvoltage then
           if tmr2dutyvar < 1023 then TMR2DutyVar=TMR2DutyVar+1
           gosub initpwm
        if voltage>Selectedvoltage then
           if tmr2dutyvar then TMR2DutyVar=TMR2DutyVar-1
           gosub initpwm
        goto start
    InitPWM:
        'set Duty cycle
        CCP1CON.5=Tmr2dutyvar.1
        CCP1CON.4=Tmr2dutyvar.0
        CCPR1L =(tmr2dutyvar>>2)
        T2CON=%00000110 ' start timer 2
                        ' set prescaler = 16
        CCP1CON = %00001100 ' pwm mode for CCP1
    Puerto Rico
    Lightbulb MosFet out volt
    Hi thanks for the help...
    Hi what type of software do you use for draw the Schematics ...
    Hi jetpr, I use P-CAD. I heard also some good comment on something called EAGLE.
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. Help needed - MOSFET driven by PWM
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 06:02
  3. Mosfet problems
    By Agent36 in forum General
    Last Post: - 2nd February 2008, 23:37
  4. Driving a mosfet directly?
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 12th July 2007, 08:45
  5. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 13:27
