Help needed - MOSFET driven by PWM
Results 1 to 9 of 9
    Feb 2003
    Sydney, Australia
    Default Help needed - MOSFET driven by PWM
    Hi All,
    I am currently working on an LED dimmer using a MOSFET on the PWM output of a 16F87 - I have some IRF540A devices that I am using with a 1k res from the PWM out to Gnd as recommended in this thread - http://www.picbasic.co.uk/forum/showthread.php?t=2782.
    What I am concerned about is that these are not Logic Level MOSFETs and I am mighty confused about the optimum drive for the MOSFET.
    Based on a lot of google work and some stuff I have read I think I might have a problem with not enough drive to turn the Mosfet Hard On. I want to scale this up to do ~5A, but I am concerned that as I am only driving them with 5v that they might not be fully tuned on and this will cause the Ron to rise and also reduce the total current rating.
    I know you could just say "Get some logic level mosfets", but here in Australia it is hard to find them without paying $8-9 each.
    So any of you analog guys want to comment on driving ~5A from a 5v logic out on a IRF540A ??
    bill.
    Lightbulb
    Hi, Bcd
    Have a look to this :
    http://www.picbasic.co.uk/forum/atta...7&d=1202029322
    you'll find some Igbt ( quite as Mosfets for drive ) simple driving ... note the Optocoupler is not compulsory !
    Mar 2008
    Texas, USA
    I've used the IRF540's for years in high amp motor drives and 5 volt gate drive. You are right about the effects of not saturating the gates. I got around it by using one 540 for every 10 amps (peak) of draw. I'd typicaly use 8 for an 80 amp draw. I don't think you'll see much, if any probelms using 5v gate drive and 5 amp draws. The 540's are going to get warm running at 5 amps and fast chop rates.
    If you have a source available at 10v or more, I'd do something like was shown above, though I'd just transistor buffer (darlington best) the drive. I don't think opto isolation will be needed for what you're doing.
    Acetronics, you ever make ESC's for brushed motors? The description above ran an Astro FAI 035 with a 9x6 direct-drive on 7 cells :0 That was power... back in them days!
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    Wink
    as Gary made me think a while ...
    it would be easy to make a simple diode-pump voltage doubler with the OSCout as a clock source ...
    in the SEARCH ... I remember something was posted on this topic ... sent to Trent Jackson ...
    Mar 2008
    Texas, USA
    Yep, I was thinking of that when I posted and forgot to get it in the post.
    BINGO !!!
    http://www.picbasic.co.uk/forum/atta...8&d=1190450941
    Hi, Gary ... Still have a wonderful ESC with a LM 358, LM339 and 4 IRFZ's 30 !!! ...
    Jun 2007
    Sydney, Australia
    Hey Bill,
    Remember the piezo driven off a MAX232? ... +/- 10V for not much extra work. Just reference the output to ground to get +10V. You have any spare lines on your level converter?
    Phil.
    Duck sensing headlights! Quack, quack, Bing!
    Feb 2003
    Sydney, Australia
    Bing ! The sound of a light bulb coming on.
    The Mosfets seems to function ok at 5v, but I hate the idea of underdriving the gate. I've found IRL540 from Futurlec here in Oz whcih have the logic drive input - and for only $0.70 each.
    bill.
    Jan 2007
    Houston, TX
    For years now I have been running IRF530's with only 5V on the gate 1-3A drain to source current for cheap switchmode devices, I just wanted to second that this does work, not as well as logic level but, for cheap low current switch mode stuff I have had no problem (I always included snubber/flashback diode (D-S) of coarse but for the poor man, linear range is good enough.
    Padawan-78
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. MOSFET expert needed
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 27th September 2009, 21:51
  3. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  4. Newbee Hardware PWM clarification needed
    By emmett brown in forum General
    Last Post: - 9th July 2006, 10:18
  5. MOSFET control using PWM & 16C711?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 03:24
