Bcd Fomat Help
Results 1 to 17 of 17
Thread: Bcd Fomat Help
    Santana's Avatar
    Santana Guest
    Question Bcd Fomat Help
    Hello everyone
    Could someone be kind enough to explain to me how i can subtract from a BCD format number.
    Here is the problem, i designed a data logger which needs the user to select a logging interval between 1 minute and 24Hrs
    my pic make s a measurement and store the result in a serial eeprom .
    i am using a DS1307 RTC to stamp the data with date & Time.
    the problem is my circuit now works ok but i have got a 4 seconds overhead as the measurement takes 4 seconds to complete so if the user selects a reading interval of 1 minute the reading would be taken every 1 minute & 4 secs example
    (12:00:00,12:01:04,12:02:08)
    What i would like to do is to minus 1 from the user entered minutes then default the seconds to 56 seconds so that
    instead of the user 1 min it is now 56 seconds but do know how to do this with BCD format
    This is how i take the user enters
    HSerout [" Set Minutes Interval (00 - 59) Type S01 for 1min ,S13 for 13mins etc",10, 13]
    IF A1minS =0 Then
    HSerin[WAIT("S"),HEX2 A1minS ]
    EndIF
    HSerout [" Minutes Set to : ",HEX2 A1minS," Mins",10, 13]
    HSerout [10, 13]
    A1minS =A1minS-$01
    write A1minS_flag,A1minS ' stored ALARM MINS in A1minS_flag
    pause 10
    A1sec =$56
    But this don't work is there some thing i am doing wrong with BCD numbers
    Santana's Avatar
    Santana Guest
    binhold = (( A1minS & $f0)>>4*10)+( A1minS & $0f) 'covert bcd to binary
    binhold =binhold -1
    How do i now convert back to bcd ?
    Whould the result be correct?
    Convert BCD to decimal... assume variable RTCSeconds holds the seconds in BCD format...
    First let's deal with the TENS value (Bits 4,5 and 6)...
    DecimalSeconds=RTCSeconds & $70
    DecimalSeconds=DecimalSeconds>>4
    DecimalSeconds=DecimalSeconds*10
    And finally add-in the UNITS value...
    DecimalSeconds=DecimalSeconds+(RTCSeconds & $0F)
    To convert Decimal back to BCD, reverse the Process...
    RTCSeconds=DecimalSeconds DIG 1
    RTCSeconds=RTCSeconds<<4
    RTCSeconds=RTCSeconds+(DecimalSeconds DIG 0)
    Incorporate the above into a General Purpose Subroutine and use the same single routine to convert Seconds, Minutes, Hours etc etc.
    Melanie
    Are you sure about that?
    I'm trying to convert a 6 digit decimal number into binary and found this thread. If I take 32 for example and manually run it through your code, I get lost.
    DECNUM = 32
    BINNUM = DECNUM dig 1 : 0000 0011
    BINNUM = BINNUM<<4 : 0011 0000
    BUNNUM = BINNUM+(DECNUM dig 0) : 0011 0010
    But if I use my calculator, 32 = 0010 0000.
    I don't see how you can just split the decimal digits and concatenate theM to make a binary number. Or am I missing something in your formula?
    Robert "Dazed 'n confused'
    WOW!
    Check out this guy's idea:
    http://www.is.wayne.edu/olmt/binary/page3.htm
    Dec 2003
    Storrs, Ct.
    Default My 2 cents.
    Don't know if this can help but this is what I use to go back and forth between a ds1302, a pic, a Siteplayer and an LCD.
            k = rtcmin : gosub h2d : decmin = k   'or k = rtchr, rtcsec, etc...
                                 'Subroutine to convert from Hex to Dec
    h2d:    ' Convert Hex coded time data -> decimal data
             K = (K & $F )+((K>>4)*10)
            k = decmin : gosub d2h : rtcmin = k  'or k=dechr, decsec,etc..
                               'Subroutine to convert from Dec to Hex
    d2h:    ' Convert Decimal -> Hex coded time data
            K = (K DIG 1) * $10 + (K DIG 0)
    Hope it helps.
    I found this nice Assembler routine here:
    http://www.piclist.com/techref/micro...b-5d16b-ph.htm
    And best of all, he explains it all for people like me. He boasts it takes only 33 cycles in all to complete, which I consider fantastic compared to any of the alternatives I can possibly write in BASIC Pro (after it converts into Assembler).
    He says it's free, I'm using it as an include and keeping all his credits; he deserves it. I don't like using someone else's free code, I like using my 'own stuff'', but this routine is just awesome. 5 bytes in, 2 bytes out, and no temporary variables, pretty sleek stuff.
    And for those like me that don't know how to tie this into our BASIC programs, chapter 8.2 is where it's at.
    ; 5 digit decimal to 16 (17) bit binary. By Peter Hemsley, March 2003.
    ; Input decimal digits in D0 (LSD) to D4 (MSD)
    ; Output 16 bit binary in NUMHI and NUMLO
    ; No temporary variables required
    ; Code size: 33 instructions
    ; Execution time: 33 cycles (excluding Call and Return)
    ; Returns carry set if > 65535 (and NUMHI-LO MOD 65536)
    dec2bin16
    movf D1,W ; (D1 + D3) * 2
    addwf D3,W
    movwf NUMLO
    rlf NUMLO,F
    swapf D2,W ; + D2 * 16 + D2
    addwf D2,W
    addwf NUMLO,F
    rlf D4,W ; + (D4 * 2 + D3) * 256
    addwf D3,W
    movwf NUMHI
    rlf NUMLO,F ; * 2
    rlf NUMHI,F
    swapf D3,W ; - D3 * 16
    subwf NUMLO,F
    skpc
    decf NUMHI,F
    swapf D2,W ; + D2 * 16 + D1
    addwf D1,W
    addwf NUMLO,F
    skpnc
    incf NUMHI,F
    swapf D4,W ; + D4 * 16 + D0
    addwf D0,W
    rlf NUMLO,F ; * 2
    rlf NUMHI,F
    addwf NUMLO,F
    skpnc
    incf NUMHI,F
    movf D4,W ; - D4 * 256
    subwf NUMHI,F
    swapf D4,W ; + D4 * 16 * 256 * 2
    addwf NUMHI,F
    addwf NUMHI,F
    return ; Q.E.D.
    Italy
    Definition:
    BCD represents each of the digits of an unsigned decimal
    as the 4-bit binary equivalents.
    UNPACKED BCD:
    Unpacked BCD representation contains only one decimal digit per byte.
    The digit is stored in the least significant 4 bits; the most significant
    4 bits are not relevant to the value of the represented number.
    PACKED BCD:
    Packed BCD representation packs two decimal digits into a single byte.
    Example values:
    Decimal------Binary---------Unpacked BCD----------Packed BCD
    0-----------0000 0000---------------0000 0000-----0000 0000
    1-----------0000 0001---------------0000 0001-----0000 0001
    2-----------0000 0010---------------0000 0010-----0000 0010
    3-----------0000 0011---------------0000 0011-----0000 0011
    4-----------0000 0100---------------0000 0100-----0000 0100
    5-----------0000 0101---------------0000 0101-----0000 0101
    6-----------0000 0110---------------0000 0110-----0000 0110
    7-----------0000 0111---------------0000 0111-----0000 0111
    8-----------0000 1000---------------0000 1000-----0000 1000
    9-----------0000 1001---------------0000 1001-----0000 1001
    10----------0000 1010-----0000 0001 0000 0000-----0001 0000
    11----------0000 1011-----0000 0001 0000 0001-----0001 0001
    12----------0000 1100-----0000 0001 0000 0010-----0001 0010
    13----------0000 1101-----0000 0001 0000 0011-----0001 0011
    14----------0000 1110-----0000 0001 0000 0100-----0001 0100
    15----------0000 1111-----0000 0001 0000 0101-----0001 0101
    16----------0001 0000-----0000 0001 0000 0110-----0001 0110
    17----------0001 0001-----0000 0001 0000 0111-----0001 0111
    18----------0001 0010-----0000 0001 0000 1000-----0001 1000
    19----------0001 0011-----0000 0001 0000 1001-----0001 1001
    20----------0001 0100-----0000 0010 0000 0000-----0010 0000
    Decimal to Packed BCD:
    Example decimal 16 to Packed BCD
    decVal= 16 decimal
    Formula:
    Packed_bcdVal = (decVal / 10) << 4 + (decVal // 10)
    (decVal / 10)
    00010000 / 00001010 = 00000001
    Shifts the result left 4 places
    00000001 << 4 = 00010000
    (decVal // 10) modulus
    00010000 // 10 = 00000110
    (00000110 , Dec 6 is the remainder).
    00010000 + 00000110 = 00010110
    Result: 00010110
    (00010110 represent the Packed BCD value for decimal 16)
    Packed BCD to Decimal:
    Example Packed BCD 00010110 to decimal
    Packed_BCD = 00010110
    Formula:
    decVal = (Packed_BCD_high_nibble * 10) + Packed_BCD_low_nibble
    Packed_BCD_high_nibble = 0001
    Packed_BCD_low_nibble = 0110
    0001 * 1010 = 1010
    1010 + 0110 = 00010000
    Result: 00010000
    (00010000 = decimal 16)
    Best regards,
    Luciano
    Packed, unpacked, I graduated from college in '83, let's see, that's 5 years ago?
    I never used that in 20 years as programmer, forgot that basic stuff. I'm looking at your 2 digit conversion example and trying to figure how you'd go about converting 6 decimal digits to binary in 2 bytes. Now my brain hurts...
    Question
    Woah, the more I read about converting, the more confused I get. When I counted binary, it went like this:
    09. 0000 1001
    10. 0000 1010
    11. 0000 1011
    12. 0000 1100
    13. 0000 1101
    14. 0000 1110
    15. 0000 1111
    My problem is that this data will be used for addressing on external memory chips; 24C256.
    Quote Originally Posted by Melanie View Post
    Melanie
    Thanks a lot. I was breaking my head from last few days to learn this. You have really explained it very nicely.
    BUT
    I am facing slight problem in my simulation (I am using proteus).
    My code looks like this when program starts for the first time:
    Rtcget		var byte[8]
    Rtcsec		var Rtcget[0]
    Rtcmin		var Rtcget[1]
    Rtchr		var Rtcget[2]
    Rtcday		var Rtcget[3]
    read 30,check
    if check=0 then
    	pause 50
    	I2CWRITE SDA,SCL,$D0,$00,[$00,$00,$12,$01,$00,$00,$00,$90]
    	pause 50
    	write 30,1
    	I2CREAD SDA,SCL,$D1,$00,[STR Rtcget\8]
    		pause 50
    		sec=Rtcsec & $70
    		sec = sec>>4
    		sec=sec*10
    		sec=sec +(Rtcsec & $0F)
    		minu=Rtcmin & $70
    		minu = minu>>4
    		minu=minu*10
    		minu=minu +(Rtcmin & $0F)
    		hrs=Rtchr & $30
    		hrs=hrs>>4
    		hrs=hrs*10
    		hrs=hrs+(Rtchr & $0F)
    		if Rtcday=$01 then days=1
    		if Rtcday=$02 then days=2
    		if Rtcday=$03 then days=3
    		if Rtcday=$04 then days=4
    		if Rtcday=$05 then days=5
    		if Rtcday=$06 then days=6
    		if Rtcday=$07 then days=7
    & when user changes the time it looks like this
    Rtcmin=minu DIG 1
    					Rtcmin=Rtcmin<<4
    					Rtcmin=Rtcmin+(minu DIG 0)
    					Rtchr=hrs DIG 1
    					Rtchr=Rtchr<<4
    					Rtchr=Rtchr+(hrs DIG 0)
    					if days=1 then Rtcday=$01
    					if days=2 then Rtcday=$02
    					if days=3 then Rtcday=$03
    					if days=4 then Rtcday=$04
    					if days=5 then Rtcday=$05
    					if days=6 then Rtcday=$06
    					if days=7 then Rtcday=$07
    				I2CWRITE SDA,SCL,$D0,$00,[$00,Rtcmin,Rtchr,Rtcday,$00,$00,$00,$90]
    				PAUSE 20
    The problem is that during simulation, the frequency of the pulse changes once I set the time (coming from DS1307 - I want 1Hz)
    Please point out the problem in my code if any, or is it the simulation software which is not correct (Proteus 6.9)
    ___________________
    WHY things get boring when they work just fine?
    Anyone there?
    ___________________
    Nov 2012
    Default Re: Bcd Fomat Help
    Hi! Melanie
    Is this write to convert seconds to bcd from decimals so that it can be written to ds1307.
     (((ssec & 0x70) >> 4) * 10) + (ssec & 0x0F)
    What is the dec2bcd codes for minutes, hours, day, weekday, month, and year?
    The Queen has not been here for awhile, but maybe this will help
    READ_RTC:
        I2CREAD DS_SDA, DS_SCL, RTC, SEC_REG, [sec,mins,hr,day,date,mon,yr]
        SEC_T = sec & $70
        SEC_T = SEC_T>>4
        SEC_O = sec & $0F
        MIN_T = mins & $70
        MIN_T = MIN_T>>4
        MIN_O = MINs & $0F
        HR_T = hr & $70
        HR_T = HR_T>>4
        HR_O = hr & $0F
        MON_T = mon & $70
        MON_T = MON_T>>4
        MON_O = mon & $0F
        DATE_T = date & $70
        DATE_T = DATE_T>>4
        DATE_O = date & $0F
        YR_T = yr & $70
        YR_T = YR_T>>4
        YR_O = yr & $0F
    Nov 2012
    READ_RTC:
        SEC_T = sec & $70
        SEC_T = SEC_T>>4
        SEC_O = sec & $0F
        MIN_T = mins & $70
        MIN_T = MIN_T>>4
        MIN_O = MINs & $0F
        HR_T = hr & $70
        HR_T = HR_T>>4
        HR_O = hr & $0F
        MON_T = mon & $70
        MON_T = MON_T>>4
        MON_O = mon & $0F
        DATE_T = date & $70
        DATE_T = DATE_T>>4
        DATE_O = date & $0F
        YR_T = yr & $70
        YR_T = YR_T>>4
        YR_O = yr & $0F
    You have given RTC Read function. It used Bcd2Dec. I need Dec2Bcd for RTC Writing.
    is this RTC Read code correct
     ssec = ((sec & 0x70) >> 4) + (sec & 0x0F)
    Nov 2012
    In the following code what is DIG, DIG 1, and DIG 0?
    Quote Originally Posted by jayanthd View Post
    That will give you the ones place.
    From the manual
    4.17.7. DIG
    DIG returns the value of a decimal digit. Simply tell it the digit number (0 - 4 with 0 being the rightmost digit) you would like the value of, and voila.
    B0 = 123 ' Set B0 to 123
    B1 = B0 DIG 1 ' Sets B1 to 2 (digit 1 of 123)
  1. DS1302 16F628 Woes
    By idtat in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 14:15
  2. BCD problem
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 14th September 2008, 16:36
  3. Rotary BCD
    Last Post: - 15th October 2007, 03:04
  4. Real time clock... what a headache!
    By Eng4444 in forum mel PIC BASIC
    Last Post: - 8th June 2006, 21:56
  5. Leading 0's or BCD
    By RYTECH in forum mel PIC BASIC Pro
    Last Post: - 28th December 2005, 01:06
