Bcd Fomat Help
Results 1 to 17 of 17
Thread: Bcd Fomat Help
    Italy
    Definition:
    BCD represents each of the digits of an unsigned decimal
    as the 4-bit binary equivalents.
    UNPACKED BCD:
    Unpacked BCD representation contains only one decimal digit per byte.
    The digit is stored in the least significant 4 bits; the most significant
    4 bits are not relevant to the value of the represented number.
    PACKED BCD:
    Packed BCD representation packs two decimal digits into a single byte.
    Example values:
    Decimal------Binary---------Unpacked BCD----------Packed BCD
    0-----------0000 0000---------------0000 0000-----0000 0000
    1-----------0000 0001---------------0000 0001-----0000 0001
    2-----------0000 0010---------------0000 0010-----0000 0010
    3-----------0000 0011---------------0000 0011-----0000 0011
    4-----------0000 0100---------------0000 0100-----0000 0100
    5-----------0000 0101---------------0000 0101-----0000 0101
    6-----------0000 0110---------------0000 0110-----0000 0110
    7-----------0000 0111---------------0000 0111-----0000 0111
    8-----------0000 1000---------------0000 1000-----0000 1000
    9-----------0000 1001---------------0000 1001-----0000 1001
    10----------0000 1010-----0000 0001 0000 0000-----0001 0000
    11----------0000 1011-----0000 0001 0000 0001-----0001 0001
    12----------0000 1100-----0000 0001 0000 0010-----0001 0010
    13----------0000 1101-----0000 0001 0000 0011-----0001 0011
    14----------0000 1110-----0000 0001 0000 0100-----0001 0100
    15----------0000 1111-----0000 0001 0000 0101-----0001 0101
    16----------0001 0000-----0000 0001 0000 0110-----0001 0110
    17----------0001 0001-----0000 0001 0000 0111-----0001 0111
    18----------0001 0010-----0000 0001 0000 1000-----0001 1000
    19----------0001 0011-----0000 0001 0000 1001-----0001 1001
    20----------0001 0100-----0000 0010 0000 0000-----0010 0000
    Decimal to Packed BCD:
    Example decimal 16 to Packed BCD
    decVal= 16 decimal
    Formula:
    Packed_bcdVal = (decVal / 10) << 4 + (decVal // 10)
    (decVal / 10)
    00010000 / 00001010 = 00000001
    Shifts the result left 4 places
    00000001 << 4 = 00010000
    (decVal // 10) modulus
    00010000 // 10 = 00000110
    (00000110 , Dec 6 is the remainder).
    00010000 + 00000110 = 00010110
    Result: 00010110
    (00010110 represent the Packed BCD value for decimal 16)
    Packed BCD to Decimal:
    Example Packed BCD 00010110 to decimal
    Packed_BCD = 00010110
    Formula:
    decVal = (Packed_BCD_high_nibble * 10) + Packed_BCD_low_nibble
    Packed_BCD_high_nibble = 0001
    Packed_BCD_low_nibble = 0110
    0001 * 1010 = 1010
    1010 + 0110 = 00010000
    Result: 00010000
    (00010000 = decimal 16)
    Best regards,
    Luciano
    Packed, unpacked, I graduated from college in '83, let's see, that's 5 years ago?
    I never used that in 20 years as programmer, forgot that basic stuff. I'm looking at your 2 digit conversion example and trying to figure how you'd go about converting 6 decimal digits to binary in 2 bytes. Now my brain hurts...
    Question
    Woah, the more I read about converting, the more confused I get. When I counted binary, it went like this:
    09. 0000 1001
    10. 0000 1010
    11. 0000 1011
    12. 0000 1100
    13. 0000 1101
    14. 0000 1110
    15. 0000 1111
    My problem is that this data will be used for addressing on external memory chips; 24C256.
  1. DS1302 16F628 Woes
    By idtat in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 14:15
  2. BCD problem
    Last Post: - 14th September 2008, 16:36
  3. Rotary BCD
    Last Post: - 15th October 2007, 03:04
  4. Real time clock... what a headache!
    By Eng4444 in forum mel PIC BASIC
    Last Post: - 8th June 2006, 21:56
  5. Leading 0's or BCD
    By RYTECH in forum mel PIC BASIC Pro
    Last Post: - 28th December 2005, 01:06
