ADCIN and PIC18F4331 Arghhhhh !
Results 1 to 8 of 8
    Jul 2007
    Question ADCIN and PIC18F4331 Arghhhhh !
    Hi, I'm puzzled
    I had no problem with the following code until I changed PIC from 18F4620 to 18F4331. Seem's like it always read ADC channel 0
    Tried many variations of the defines but basically this is what I'm using:
    DEFINE ADC_BITS 10
    DEFINE ADC_SAMPLEUS 50
    DEFINE ADC_CLOCK 3
    ADCON2.7 = 1 'Right justified A/D
    ANSEL0 = %11000011 'ADC pins: AN0,AN1,AN6,AN7
    ADCON0 = %00000011
    ADCHS = %01000100
    then I have the four subroutines called by the program:
    GetDure:
    adcin 1, duration
    duration = (duration*2) + 70
    GetDpth: 'Return Depth
    adcin 7, DPTH
    dpth = 1024-dpth
    DPTH = (dpth*5)/21
    GetStrk: 'Return Stroke length
    adcin 6, STRK
    STRK = (STRK*20)/51 '0 to 401
    STRK = STRK + 80 '80 to 480 (1 to 6 inches)
    GetSPD: 'Return speed
    adcin 0, PulseLen
    PulseLen = ((1026-PulseLen)*4) + 35 '35 to 4100
    The program compile fine and worked very well before with PIC18F4620, (using different define to match PIC). Now, It looks like it always read channel 0, for all 4 subroutines. It doesn't care about the value for the channel, after the ADCIN. What I'm missing ???
    J-P
    Jul 2007
    Default Incredible, could someone explain this ?
    Well, here is what is working:
    DEFINE OSC 16
    TRISB = %00000000
    '----- Set ADC ---------------------------------------------
    DEFINE ADC_BITS 10
    DEFINE ADC_SAMPLEUS 2
    ADCON1 = %00000111         'ADC on channel AN0 to AN7
    '----- Set LCD ---------------------------------------------
    DEFINE LCD_LINES 4
    define LCD_DREG PORTD
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 2
    line_1 con $80
    line_2 con $C0
    line_3 con $94
    line_4 con $D4
    PAUSE 1000
    LCDOUT $FE, 1
    A0 VAR WORD
    A1 VAR WORD
    A2 VAR WORD
    A3 VAR WORD
    A4 VAR WORD
       ADCIN 0, A0
       ADCIN 1, A1
       ADCIN 2, A2
       ADCIN 3, A3
       lcdOUT $FE,1, LINE_1, #A0
       lcdOUT $FE, LINE_2, #A1
       lcdOUT $FE, LINE_3, #A2
       lcdOUT $FE, LINE_4, #A3
    BUT !!!!!!!!! this is NOT working
    DEFINE OSC 16
    TRISB = %00000000
    DEFINE ADC_BITS 10
    DEFINE LCD_LINES 4
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 2
    line_1 con $80
    line_2 con $C0
    line_3 con $94
    line_4 con $D4
    PAUSE 1000
    LCDOUT $FE, 1
    A0 VAR WORD
    A1 VAR WORD
    A2 VAR WORD
    A3 VAR WORD
    A4 VAR WORD
       ADCIN 0, A0
       ADCIN 1, A1
       ADCIN 6, A2
       ADCIN 7, A3
    The only difference is that I'm using channel 1,2,6 and 6 instead of 1,2,3,4
    Jul 2007
    Wink Nasty Beast, I got you !
    Maybe it's a bug, maybe I'm really missing something but I found a real strange way to have it work on ADC channel 5 to 8
    DEFINE OSC 16
    TRISB = %00000000
    DEFINE ADC_BITS 10
    'ADCON1 = %00000111         'ADC on channel AN0 to AN7
    ANSEL0 = 255
    ANSEL1.0 = 1
    ADCHS = %01010110   'group select bit to channel 5-6-7-8
    DEFINE LCD_LINES 4
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 2
    line_1 con $80
    line_2 con $C0
    line_3 con $94
    line_4 con $D4
    PAUSE 1000
    LCDOUT $FE, 1
    A0 VAR WORD
    A1 VAR WORD
    A2 VAR WORD
    A3 VAR WORD
    A4 VAR WORD
       ADCIN 0, A0
       ADCIN 1, A1
       ADCIN 2, A2
       ADCIN 3, A3
    I Said Channel 5 to 8 !
    Actually what is amazing is that this is wired to channel 5 to 8 (physical pin 7 to 10) And even if I wrote ADCIN 0, this will actually read channel 5 !!!!
    This is certainly linked with the ADCHS register.
    But there is a faint smell of bug around here, don't you think?
    J-P
    It's not a bug. The newer 18F4331, 4431, etc, have more registers
    associated with the advanced A/D, and ADCIN doesn't address this.
    Microchip moved things around on this series, so you'll need to configure
    A/D registers manually.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Not sure if this will help (you probably already figured this out), but this PIC is
    really nice. Here's an example of reading 4 x A/D channels simultaneously on a
    18F2431.
        DEFINE OSC 20
        DEFINE DEBUG_REG PORTC
        DEFINE DEBUG_BIT 6
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0 ' 1 = inverted, 0 = true
        CH1 VAR WORD
        CH2 VAR WORD
        CH3 VAR WORD
        CH4 VAR WORD
        ' Analog setup
        ' Single shot, multi-channel, simultaneous Mode2, Groups A+B, then C+D
        ADCON0 = %00011101
        ' Set +/- Vref to AVdd/AVss, FIFO buffer enabled
        ADCON1 = %00010000
        ADCON2 = %11001111   ' Right justified, 24 Tad, Frc
        ADCON3 = 0           ' Disable all triggers
        ADCHS = 0            ' Channel select for AN0,1,2,3
        ANSEL0 = %00001111   ' AN0,1,2,3 analog input, rest digital
        ADCON0.1 = 1         ' Start the conversion
        WHILE ADCON0.1=1     ' Wait for it to complete (all 4 channels)
        WEND
        ' FIFO buffer holds all 4 channels. Reading ADRESH & ADRESL automatically
        ' increments the buffer pointer (on read of ADRESL) to the next channels
        ' storage location.
        CH1.HighByte = ADRESH ' get result from AN0
        CH1.LowByte = ADRESL  ' Increment buffer pointer
        CH2.HighByte = ADRESH ' get result from AN1
        CH2.LowByte = ADRESL  ' Increment buffer pointer
        CH3.HighByte = ADRESH ' get result fron AN2
        CH3.LowByte = ADRESL  ' Increment buffer pointer
        CH4.HighByte = ADRESH ' get result from AN3
        CH4.LowByte = ADRESL  ' clears buffer pointer
        ' show 4 A/D channel results
        DEBUG "A/D ch 1 = ",DEC CH1,13,10
        DEBUG "A/D ch 2 = ",DEC CH2,13,10
        DEBUG "A/D ch 3 = ",DEC CH3,13,10
        DEBUG "A/D ch 4 = ",DEC CH4,13,10
        PAUSE 5000
        GOTO Main
    Man, the more I play with this one, the more I like it.
    -Bruce
    tech at rentron.com
    Jul 2007
    Default Agreed
    Thanks for your help.
    Actually I'm using the code from post #3. (with pbp adcin). But I will certainly investigate the ADC special features of this PIC.
    I've actually switched from 18F4620 to 18F4331 mainly because of the REALLY NICE QEI module. But if I've read the datasheet correctly we can't use the 4x PLL with the internal clock?
    J-P
    Yep. The 4 x PLL doesn't work with the internal oscillator.
    -Bruce
    tech at rentron.com
    Hangover, Germany
    Cool
    ADCIN doesn't work on PIC18Fxx31.
    Look here:
    http://www.picbasic.co.uk/forum/show...6903#post96903
    PBP 2.50C, MCS+ 3.0.0.5, MPLAB 8, MPASM 5.14, ASIX Presto, PoScope, mE mikroBasic V7.2, PICKIT2
