ADCIN and PIC18F4331 Arghhhhh !
Results 1 to 8 of 8
    It's not a bug. The newer 18F4331, 4431, etc, have more registers
    associated with the advanced A/D, and ADCIN doesn't address this.
    Microchip moved things around on this series, so you'll need to configure
    A/D registers manually.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Not sure if this will help (you probably already figured this out), but this PIC is
    really nice. Here's an example of reading 4 x A/D channels simultaneously on a
    18F2431.
        DEFINE OSC 20
        DEFINE DEBUG_REG PORTC
        DEFINE DEBUG_BIT 6
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0 ' 1 = inverted, 0 = true
        CH1 VAR WORD
        CH2 VAR WORD
        CH3 VAR WORD
        CH4 VAR WORD
        ' Analog setup
        ' Single shot, multi-channel, simultaneous Mode2, Groups A+B, then C+D
        ADCON0 = %00011101
        ' Set +/- Vref to AVdd/AVss, FIFO buffer enabled
        ADCON1 = %00010000
        ADCON2 = %11001111   ' Right justified, 24 Tad, Frc
        ADCON3 = 0           ' Disable all triggers
        ADCHS = 0            ' Channel select for AN0,1,2,3
        ANSEL0 = %00001111   ' AN0,1,2,3 analog input, rest digital
        ADCON0.1 = 1         ' Start the conversion
        WHILE ADCON0.1=1     ' Wait for it to complete (all 4 channels)
        WEND
        ' FIFO buffer holds all 4 channels. Reading ADRESH & ADRESL automatically
        ' increments the buffer pointer (on read of ADRESL) to the next channels
        ' storage location.
        CH1.HighByte = ADRESH ' get result from AN0
        CH1.LowByte = ADRESL  ' Increment buffer pointer
        CH2.HighByte = ADRESH ' get result from AN1
        CH2.LowByte = ADRESL  ' Increment buffer pointer
        CH3.HighByte = ADRESH ' get result fron AN2
        CH3.LowByte = ADRESL  ' Increment buffer pointer
        CH4.HighByte = ADRESH ' get result from AN3
        CH4.LowByte = ADRESL  ' clears buffer pointer
        ' show 4 A/D channel results
        DEBUG "A/D ch 1 = ",DEC CH1,13,10
        DEBUG "A/D ch 2 = ",DEC CH2,13,10
        DEBUG "A/D ch 3 = ",DEC CH3,13,10
        DEBUG "A/D ch 4 = ",DEC CH4,13,10
        PAUSE 5000
        GOTO Main
    Man, the more I play with this one, the more I like it.
    -Bruce
    tech at rentron.com
    Jul 2007
    Default Agreed
    Thanks for your help.
    Actually I'm using the code from post #3. (with pbp adcin). But I will certainly investigate the ADC special features of this PIC.
    I've actually switched from 18F4620 to 18F4331 mainly because of the REALLY NICE QEI module. But if I've read the datasheet correctly we can't use the 4x PLL with the internal clock?
    J-P
    Yep. The 4 x PLL doesn't work with the internal oscillator.
    -Bruce
    tech at rentron.com
    Hangover, Germany
    Cool
    ADCIN doesn't work on PIC18Fxx31.
    Look here:
    http://www.picbasic.co.uk/forum/show...6903#post96903
