DS1820 display with 7-seg 4 digits
Results 1 to 13 of 13
    May 2005
    Default DS1820 display with 7-seg 4 digits
    Hi every one i would lioke to share with my project.
    I did make temperature display and show on 7-seg.[ 45.5C ]
    Define LOADER_USED 1
    @ Device pic16F877A, xt_OSC, BOD_OFF, PWRT_ON, WDT_OFF, PROTECT_OFF 'WRT_On
    Segments Var PORTC
    Digits Var PORTD
    i Var Byte
    n Var Byte
    Value Var Word
    ' Allocate variables
    command var byte ' Storage for command
    J var byte ' Storage for loop counter
    temp var word ' Storage for temperature
    T VAR WORD
    DQ var PORTd.4 ' Alias DS1820 data pin
    DQ_DIR var TRISd.4 ' Alias DS1820 data direction pin
    read_done var byte
    Lastdata var word
    TRISc = $00 ' Set segment pins to output
    TRISd = $f0 ' Set digit pins to output
    TrisB = $00
    Portb = $00
    portd = $ff
    OPTION_REG = $50 ' Set TMR0 configuration 1:64
    INTCON = $A0 ' Enable TMR0 interrupts
    'On Interrupt Goto display
    'ADCON1 = 7 ' Set PORTA and PORTE to digital
    ' Lcdout $fe, 1, "Temp in degrees C" ' Display sign-on message
    'debug ====
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 12 ' 19200 Bauds ,4 m
    'debug ====
    ' Mainloop to read the temperature and display on LCD
    mainloop:
    'goto display
    'Goto mainloop
    Gosub init1820 ' Init the DS1820
    command = $cc ' Issue Skip ROM command
    Gosub write1820
    command = $44 ' Start temperature conversion
    Gosub write1820
    'Pause 2000 ' Wait 2 seconds for conversion to complete
    Gosub init1820 ' Do another init
    Gosub write1820
    command = $be ' Read the temperature
    Gosub write1820
    Gosub read1820
    'Display the decimal temperature
    'HSEROUT ["Temp = ",dec (temp>>1),".", dec (temp.0*5)," C",13,10]
    'T = ((temp>> 1)*100)+((TEMP.0*5)*10)
    'HSEROUT ["Temp = ",dec T ,13,10]
    value = ((temp>> 1)*100)+((TEMP.0*5)*10)
    GOTO DISPLAY
    Goto mainloop ' Do it forever
    ' Initialize DS1820 and check for presence
    init1820:
    Low DQ ' Set the data pin low to init
    Pauseus 500 ' Wait > 480us
    DQ_DIR = 1 ' Release data pin (set to input for high)
    Pauseus 100 ' Wait > 60us
    If DQ = 1 Then
    'Lcdout $fe, 1, "DS1820 not present"
    PORTC = $39
    LOW DIGITS.0
    PAUSE 150
    PORTC = $0
    Pause 150
    Goto mainloop ' Try again
    Endif
    Pauseus 400 ' Wait for end of presence pulse
    ' Write "command" byte to the DS1820
    write1820:
    For i = 1 to 8 ' 8 bits to a byte
    If command.0 = 0 Then
    Gosub write0 ' Write a 0 bit
    Else
    Gosub write1 ' Write a 1 bit
    Endif
    command = command >> 1 ' Shift to next bit
    Next i
    ' Write a 0 bit to the DS1820
    write0:
    Low DQ
    Pauseus 60 ' Low for > 60us for 0
    ' Write a 1 bit to the DS1820
    write1:
    Low DQ ' Low for < 15us for 1
    @ nop ' Delay 1us at 4MHz
    Pauseus 60 ' Use up rest of time slot
    ' Read temperature from the DS1820
    read1820:
    For i = 1 to 16 ' 16 bits to a word
    temp = temp >> 1 ' Shift down bits
    Gosub readbit ' Get the bit to the top of temp
    Next i
    ' Read a bit from the DS1820
    readbit:
    temp.15 = 1 ' Preset read bit to 1
    Low DQ ' Start the time slot
    If DQ = 0 Then
    temp.15 = 0 ' Set bit to 0
    Endif
    Pauseus 60 ' Wait out rest of time slot
    '================== 7 seg ment display ==============================
    display:
    'value = ((temp>> 1)*100)+((TEMP.0*5)*10)
    PORTC = $39 'Show C on display
    LOW DIGITS.0
    PAUSEUS 1500
    PORTC = $0
    'value = 125
    For i = 1 To 4 ' Loop through 4 digits
    n = Value Dig i ' Get digit to display
    ' Gosub display1 ' Display the value
    Digits = $ff
    Lookup n, [$3F, $06, $5B, $4F, $66, $6D, $7D, $07, $7F, $6F,_
    $77, $7C, $39, $5E, $79, $71, $0FF], Segments
    If i = 2 then segments = segments + 128 'Digit 2 show dot
    Digits = ~Dcd i
    NEXT I
    goto mainloop
    Jun 2006
    California
    Default Centigrade/Fahrenheit
    So do you have code for Fahrenheit ??
    Feb 2003
    Just convert Centigrade to Farenheit
    C/5*9+32=F
    although to maintain a bit more accuaracy with PBP integer maths I would do
    C*9/5+32=F
    then display the result followed by "F" instead of "C"
    Keith
    www.diyha.co.uk
    www.kat5.tv
    SWITZERLAND (french speaking)
    Default Why the octal buffer?
    Hello chai98a,
    Why did you use the 74HC541 octal buffer?
    Is it because of a power issue between PIC and display?
    Roger
    Jan 2006
    Istanbul
    Hello chai98a,
    I had asked the same question before.
    AND I think the answer was that he had seen a design with 74HC541 somewhere. That was why.
    Sep 2007
    philippines
    Default 7-segment display counter
    hi!!!
    im new in pic programming.. please give me sample codes for a circuit that counts from 0 - 99 (2 seven segment display) when a sensor is triggered. and alarms if the sensor is not triggered or idle for about 10 seconds.. thanks!!
    Talking
    Hi, Gimo
    That's not sample you request, but a complete application ...
    How much do you offer ???
    Jan 2006
    Istanbul
    Hi, Gimo
    Hey gimo,
    I will accept 1 buck less then what Alain accepts.
    That is, of course, IF the OFFER is > 1 buck.
    Sep 2007
    philippines
    Wink
    hahaha... just give it for free please???
    Mar 2008
    How can you get the DS1820 and LCD to display actual 10ths of a degree?
    My code I use for displaying the results of the conversion is
     LCDOUT $FE,$C0,"Temp", $fe, $C7, dec (temp >> 1), ".", dec (temp.0 * 5), $DF, "C"
    but it only seems to measure in 0.5degree steps not 0.1 degree steps
    so it will never show room temperature as 19.7șC it will instead show 19.5șC is there a way to fix this?
    Rest of the conversion code is
    ' Initialize DS1820 and check to see IF I was stupid enough to forget the DS1820
    init1820:
            Pauseus 500             ' Wait > 500us
            Pauseus 100             ' Wait > 100us
            If DQ = 1 Then
                    Pause 500
            Endif
    write1820:
                    Else
                    Endif
            Next i
    write0:
            Low DQ
    write1:
    read1820:
            Next i
    readbit:
            If DQ = 0 Then
            Endif
    Also:
    How can you use 2 DS1820's and have them display the results on 2 different lines of the LCD, I know they are 1wire and should work fine, but how do you talk to each one individually and get the results from each one?
    Quote Originally Posted by gimo View Post
    hi!!!
    I'm a newbie just teaching myself about Pic's and programming, mainly by using snippets of other people's code and changing a few things to see what happens and try and figure out how to make it work
    but the request you made can be found in numerous places, loads of sample codes contain that, and come on, its not that hard to work out, even for a wanna be blonde!
    Wink
    Hi, Karen
    AS the DS18x20 has a +/- .5 degrees precision ... is it useful to show the tenths of degree ???
    Now, take the DS 1820 Datasheet ... How much degrees for 1 Count ???
    Are you able to show the 1/10 degree ???
    ( Check if your DS 1820 is a DS1820 , a DS18B20, a DS 18S20 ??? )
    Take the DS 18B20 Datasheet ... How much degrees for 1 Count ??? Can you read .1 degree NOW ???
    NOW, for 2 DS 1820 ... Two solutions :
    1) each has its DATA PIN
    2) you have to address them by using their DEV i.d. before sending them commands ...
    Make your choice ...
    Mar 2008
    Thanks ,
    but I've never programmed anything before and have only heard of stamp not used it.
    I'm just teaching myself by trial and error as I go along.
    hmm I can see some research coming up on how to address each device by device ID and how I find the device id to start with!
    Lightbulb
    Have a look here ...
    http://www.rentron.com/PicBasic1.htm
    Bottom left of the page ... just the other side you went from ...
    And Thanks to Bruce !
  1. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 19:30
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Big 7 seg LED display
    By shahidali55 in forum General
    Last Post: - 12th December 2007, 06:13
  4. Time display on 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 5th March 2007, 08:24
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
