Direct PIC to PC without MAX232
Results 1 to 15 of 15
    Oct 2006
    Smile Direct PIC to PC without MAX232
    A good idea in order to have a direct PIC and a PC bilateral communication using the PIC's UART and HSERIN and HSEROUT without an external inverter like MAX232 is choose a PIC with Comparator Module like the 16F877A or 16F88 or 16F628.
    You just need configure the comparator module as "Two Common Reference Comparators with Outputs" where the output of comparators are redirected to pins. Then the TX pin used to HSEROUT is hardwired to the input of comparator 1 . The inverted output (true) is now outputed in the C1.
    To receive from PC serial is directed to input of C2 and output is hardwired to RX pin used by HSERIN.
    Both comparators may use the internal reference (Comparator Voltage Refrence Module enabled and routed to C1, C2 ) or use an external.
    I already have tested this trick with 16F88 with good results.
    Of course this is not the true level converter like the MAX232 but works fine in my PC.
    I hope this be useful for some users.
    ACJacques
    Dec 2005
    Neat idea.
    I was hoping to use it with a 16F688 but C2OUT and TX share RC4.
    Mar 2008
    Default Re: Direct PIC to PC without MAX232
    Thank you for this idea!!
    Also, would the following work:
    HSEROUT - First invert all bits in the data byte, then send with HSEROUT.
    HSERIN - Read the data as usual, the invert the data byte prior to using.
    Thanks!
    Dec 2010
    Quote Originally Posted by swr999 View Post
    Thanks!
    Sorry, won't work. You need to invert everything, including the idle state, start and stop bits, etc.
    No risk of overvoltage on PIC?
    Aug 2011
    Yes, this exceeds the max voltage spec on the pins. Bad idea, esp the negative voltage.
    RS232 levels could be as much as +/-25V, although you normally won't see them anywhere near this high out of your typical PC.
    If you're interested, read TB3013 (http://ww1.microchip.com/downloads/e...tes/93013a.pdf). Then see if you still want to recommend doing this.
    Mar 2008
    Quote Originally Posted by Charlie View Post
    Of course you're right! Why didn't I think of that? ;-\
    I'm just using a 3-wire connection, so I suppose, aside from a dedicated RS232 translator chip (MAX232 etc), I could use any scheme to hardware-invert the Rx and Tx lines?
    Thanks for the helpful responses!
    Dec 2010
    You can use any scheme to invert the signals and it will work, bearing in mind that you might encounter an interface that it won't work with because it doesn't strictly meet the spec. You'll have more success with a 5V PIC, and you should protect any input from overvoltage on whatever device you use. I do this all the time for one way communication out of the PIC for dumping status logs or other information that doesn't require a response from the computer. Typically, I use an N-channel FET to do the inversion, but a spare comparator or op-amp will do too.
  1. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 22:04
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  4. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  5. PIC and MAX232 in/out
    By The Master in forum Serial
    Last Post: - 29th March 2008, 20:41
