Direct PIC to PC without MAX232
Results 1 to 15 of 15
    Dec 2010
    Default Re: Direct PIC to PC without MAX232
    Quote Originally Posted by swr999 View Post
    Of course you're right! Why didn't I think of that? ;-\
    I'm just using a 3-wire connection, so I suppose, aside from a dedicated RS232 translator chip (MAX232 etc), I could use any scheme to hardware-invert the Rx and Tx lines?
    Thanks for the helpful responses!
    You can use any scheme to invert the signals and it will work, bearing in mind that you might encounter an interface that it won't work with because it doesn't strictly meet the spec. You'll have more success with a 5V PIC, and you should protect any input from overvoltage on whatever device you use. I do this all the time for one way communication out of the PIC for dumping status logs or other information that doesn't require a response from the computer. Typically, I use an N-channel FET to do the inversion, but a spare comparator or op-amp will do too.
    Quote Originally Posted by Charlie View Post
    ..., I use an N-channel FET to do the inversion...
    Not P-channel?
    Dec 2010
    P-Channel devices are usually more expensive and have other design considerations, so I design 99% of the time with N-channel and have several devices rolling around my parts bin when I need one. It's 6 of one, a half dozen of the other. You might be able to save a little power by using one or the other, since a comms channel is usually idle a lot - I have not had a design where I needed to care about power and also needed a cheap comms interface, so I really have not thought it through.
    Oct 2006
    About the protection of PIC input pin lets go remember that generally input pins already have positive and negative clamp diodes built in the chip. I have tested even without a series resistor but 470R will do the job. The great majority of legacy RS232 ports already are 0- 5v compatible for input and are current limited for output.
    Aug 2011
    Here's a good example of the strange things that can happen when you get creative and choose not to pay attention to the specs...
    PIC16F1847 HFINTOSC Slow and Unstable
    Note that this guy WAS limiting the current with a series resistor.
    Mar 2008
    Back to my original question:
    Turns out that the 12F1xxx family (and likely others) have an option to invert data from the TX/CK pin. The control is the SCKP bit (bit 4) in the BAUDCON register, described on page 279 of the 12F1822 data sheet.
  1. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 23:04
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  5. PIC and MAX232 in/out
    By The Master in forum Serial
    Last Post: - 29th March 2008, 21:41
