What is the difference between using a 20 MHz crystal on a PIC 18F2550 running USB with this configuration:
CONFIG PLLDIV = 5 ;Divide by 5 (20MHz input)
CONFIG CPUDIV = OSC1_PLL2 ;[OSC1/OSC2 Src: /1][96MHz PLL Src: /2]
CONFIG USBDIV = 2 ;Clock source from 96MHz PLL/2
CONFIG FOSC = HSPLL_HS ;HS oscillator, PLL enabled, HS used by USB
DEFINE OSC 48 ' 20 MHz crystal with HSPLL enabled
and just using a 48 MHz crystal?
Is it more efficient? Is extra cost the only difference?
Also, what fuses would I need to change to use a 48 MHz crystal?
Thanks!
