Problem with WHILE - WEND
Results 1 to 23 of 23
    Jan 2006
    New Hampshire, USA
    Default Problem with WHILE - WEND
    I attached my program. Can someone tell me what is wrong with the highlited statement, and how can I accomplish the action?
    Use IF THEN instead
    IF (Footsw=1) OR (Ready=1) Then Start
    OR
    While (FootSw=1) OR (Ready=1)
           LOW RENCA
           LOW EJECT
           WEND
    Jan 2006
    Istanbul
    Wink
    First:
    Goto should not be used with "While" statement. Use "IF" instead.
    ex:
    IF Footsw=1 or Ready=1 then Goto Start
    Second:
    Your statement should have been as below.
    While Footsw=1 or Ready=1
    Goto start    'cant'be on the same line with While
    Wend
    Jan 2006
    New Hampshire, USA
    Thanks for the replies. I had tried IF - THEN but did not do that right either!
    1. Parenthesis are important in most case
    2. I would never jump out of a WHILE statement using a GOTO. Using a flag or Validate the Conditions to get out of the WHILE/WEND loop is, IMHO, a better practice.
    Could be also..
    Start:
        LOW RENCA
        LOW EJECT
        While (FootSw=1) OR (Ready=1) : WEND
    OR
    Start:
        LOW RENCA
        LOW EJECT
        SpinHere: If (FootSw=1) OR (Ready=1) then SpinHere
    You may notice that one method generate less code space than the other.
    Jan 2006
    New Hampshire, USA
    Here is my problem: I tried the spinhere loop, it works but the following statements are a loop. I want the program to stay in the loop but as soon as either footsw or ready goes high, the program jumps back to the spinhere loop. I don't want it to do that. How do I do it?
    SpinHere:
        LOW RENCA
        LOW Eject
        While (FootSw=0) OR (Ready=0)
              '    Do your loop here
              wend
        goto Spinhere
    Jan 2006
    New Hampshire, USA
    I have not explained my problem properly: I want a momentary switch closure (footsw) to cause the program to jump to a loop (freq. I don't want it to jump out of the loop when the switch opens.
    Last Post: - 18th February 2010, 14:46
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 19:12
  3. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  4. while wend problem
    By Russ Kincaid in forum mel PIC BASIC Pro
    Last Post: - 19th March 2007, 02:53
  5. 1 slave 1 master 1 MAX232 1 problem ?
    By SuB-ZeRo in forum mel PIC BASIC Pro
    Last Post: - 31st July 2005, 22:59
