Problem with WHILE - WEND
Results 1 to 23 of 23
    1. Parenthesis are important in most case
    2. I would never jump out of a WHILE statement using a GOTO. Using a flag or Validate the Conditions to get out of the WHILE/WEND loop is, IMHO, a better practice.
    Could be also..
    Start:
        LOW RENCA
        LOW EJECT
        While (FootSw=1) OR (Ready=1) : WEND
    OR
    Start:
        LOW RENCA
        LOW EJECT
        SpinHere: If (FootSw=1) OR (Ready=1) then SpinHere
    You may notice that one method generate less code space than the other.
    Jan 2006
    New Hampshire, USA
    Here is my problem: I tried the spinhere loop, it works but the following statements are a loop. I want the program to stay in the loop but as soon as either footsw or ready goes high, the program jumps back to the spinhere loop. I don't want it to do that. How do I do it?
    SpinHere:
        LOW RENCA
        LOW Eject
        While (FootSw=0) OR (Ready=0)
              '    Do your loop here
              wend
        goto Spinhere
    Jan 2006
    New Hampshire, USA
    I have not explained my problem properly: I want a momentary switch closure (footsw) to cause the program to jump to a loop (freq. I don't want it to jump out of the loop when the switch opens.
    Talking Cookbook available ???
    Hi, Steve
    Keep cool ... keep cool ...
    Hi,Russ
    Could you explain EXACTLY what you want to do ...
    I mean : the switch closure lead to jump into the loop, OK ... but what happens if switch released ??? stay in the loop ??? go where ??? do you test your switch continuously after jumping off the loop ??? or just once at the beginning of your program ???
    We're not at school ... no one will copy your project !!!!
    Problem written is half the solution ....
    Jan 2006
    New Hampshire, USA
    I want a momentary switch closure to jump to a loop and stay there, regardless of further action by the switch. Perhaps an interrupt is what I need? I don't exactly know how to do that, but will experiment. I prefer to use portb.5 for interrupt input, the data sheet says the RBIF flag will be set regardless of the state of the INTCON enable bit?
    Jan 2006
    New Hampshire, USA
    I tried this interrupt. READY is always low; when FOOTSW goes low, the freq loop runs but only as long as FOOTSW is low. When FOOTSW goes high, the clock stops; it will start again when FOOTSW goes low again. I don't understand this.
    'device: 16F627A master clear is on pin#4 (RA5)
    TRISA = %00010000 ' port A all outputs, except MCLR is input
    TRISB = %00111111 'PORT B ALL INPUT, EXCEPT 6 & 7 OUTPUT
    option_REG = %01111111 'enable weak pullups on port B
    FOOTSW var portb.5 'Foot switch OR CCREADY must be high
    READY var portb.4 'at start
    T var word
    J VAR WORD
    RENCA var portb.7 'FREQUENCY OUTPUT TO J1 PIN 13
    EJECT var portb.6 '100 mS PULSE TO J1 PIN 21
    START:
    WHILE READY = 0
    LOW RENCA : LOW EJECT
    on interrupt goto poo
    poo:
    T = 100 '1mS AT 4 mHZ
    freq:
    PULSOUT RENCA, T 'frequency should be 500 Hz (2mS period)
    PAUSEus T*7
    GOTO freq
    WEND
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. while wend problem
    Last Post: - 19th March 2007, 03:53
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
